Custom Oil coolers
Posted by token-negro
Re: Custom Oil coolers
January 06, 2010 05:28PM
Jon. Assembling AN lines is super easy. Don't fret about it.
token-negro
Kendrick Gray
January 06, 2010 05:33PM
Check out this link, just the center of the page for socketless hose
http://www.bakerprecision.com/aqp12b.htm
Its really critical here we are on the same page, you need to use the correct hose with those ends, parker,aeroquip,earls,summit, all make pushlock/socketless hose and ends. They all have nice hose without the braid etc. You do not want to use these socketess/push lock ends with regular rubber hose, the correct hose seals correctly. Now if u want to put a clamp on the hose ends u can but they don’t recommend it. I would in your case on your sandwich adapter on your car go from whatever NPT thread to a AN use an adapter then use the appropriate angle/straight hose end, attach the hose and then use the right end on the oil cooler. That’s how about 95% of the street going Subaru’s do it. Seems to work great no leaks, just fire sleeve the line around the header. Does your adapter have a thermostat?
January 06, 2010 11:10PM
> fret about it.
> Grant Hughes
> Denver, CO
Jesus, I look for reasons to assemble AN lines
Ted Andkilde
Ted Andkilde
1968 Mini
January 07, 2010 08:47AM
I'm not a big fan of push lock hose fittings -- you're putting a lot of faith in the integrity of the bond between the rubber and the fabric braid, that a few minutes ago you sliced like butter with your pocket knife...
FWIW, my home shop airlines are made using push lock connectors, they pop off pretty frequently and have to be trimmed back a couple of inches before jamming back together, the sharp barbs on the push lock fittings chew the hose up pretty badly so clamping it would just cause a different kind of failure.
I'm thinking hot oil is much more challenging to seal than shop air.
t
token-negro
Kendrick Gray
January 07, 2010 10:11AM
> kind of failure.
> seal than shop air.
> t
> Pure mathematics is the enemy of every truly
> creative man -- Sir Alec
Either you have some bad hose or bad fittings. 250psi operating pressure and 1000 psi burt, they should not be coming off, if you are using the correct stuff. There are some knock offs out there but using Aeroquip or Parker hose and ends should net you the best results.
January 07, 2010 05:33PM
yes, my adapter will have a thermostat.
I'm doing all my parts shopping on ebay, but looks like Aeroquip parts are a-plenty there.
I can already see the difference between ebay no-name brand:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120509275690&viewitem=&sspagename=STRK%3AMEWAX%3AIT
vs aeroquip
(2 prong vs 3)
and they recommend the Aeroquip AQP hose, which I've also found as well.
sweet, thanks guys.
TerribleOne
Vince McAllister
89 Volvo 244tic
January 13, 2010 12:29PM
Thats a nice looking cooler setup there.
Stroker 2.5 redblock, JE forged blower pistons 8.2:1, Eagle H beams with DSM big end, Avalanche underdrive pulley, 46/40mm valve 530 with Enem C2 turbo cam, Isky db springs, SDS efi w/DIS/wasted spark, PCS digital touch screen dash/logger, 60lb Deka IV's, ATP 60-1 @ 22psi, Tial bov, Walbro 255, Avalanche T-5 adapter, 02 Tremec 5sp, 6puck, 3" driveshaft, modded G80, Painless chassis harness. Corbeau seats.. 300+whp Driven daily..
DJackson
Dawud Jackson
Watching from the sidelines
January 13, 2010 05:07PM
What's wrong with the reusable compression fittings? You just twist them down with a wrench and a vice, and I doubt it would blow off at any point...
Name: Dawud Jackson (DJ)
Occupation: Computer dude.
