JonArmstrong
Jon Armstrong
Rallycross Civic
Re: Passing brake lines through the firewall
December 16, 2009 08:51PM
I just popped open the old Carroll Smith "Nuts, Bolts, Fasteners and Plumbing handbook".
Looks like Carrol Smith recommends 37 degree AN single flares for brake lines. But, they need to be made with a real 37 degree flaring tool.
A quote from his book:
"The standard American double flare is an SAE 45 degree flare and is not suitable for use with the AN fittings which are 37 degree cones. I have spoken with a number of experienced and even respected mechanics who, while they are aware of this difference, ignore it. These people fell that, by graunching down hard enough on the coupling nut, they can seal the assembly. These people are fools!"
Looks like this is what you need for adaptors:
http://www.summitracing.com/parts/EAR-561803ERL/
And one of these for the flares (not cheap):
http://www.toolbarn.com/ridgid-41162.html
token-negro
Kendrick Gray
December 16, 2009 09:00PM
> people are fools!"
I would expect any person able to join and post on this forum would be bright enough not to mix a double flare, or any flare other then an AN with an AN fitting. I guess i have to high of expectations for the members here.
December 16, 2009 09:01PM
Brake lines are double flare because the tube nut runs directly on the outside of the flare. (Technically, they are also only good once) There's a twisting grinding action going on in there.
AN tube nuts have a separate sleeve. The sleeve bears on the outside of the flare without torquing on the flare. A much better, more reliable, and more reusable method of sealing.
A 37deg flare tool isn't that much more expensive than a double-flare tool that works worth a damn.
I know that steel is supposed to be used for brakes, but every drag car I've seen that was done in all-AN has used aluminum tees and bulkheads. Scary!
token-negro
Kendrick Gray
December 16, 2009 09:05PM
Just to add a little story to this, best friend was installing a new cook top the other night and we smelled gas, come to find out the flex line he had installed had jic 37 degree fittings on it but the company failed to use seamless tubing. so here we see the importance of using quality tube with your 37 degree stuff. Once we pulled it all apart you could clearly see the seam in the fared end of the hose, along with a spot that wasnt contacting the face on the male end.
JonArmstrong
Jon Armstrong
Rallycross Civic
December 16, 2009 09:14PM
> an AN fitting.
Advice such as this seems to contradict your hypothesis:
John Vanlandingham Wrote:
>You can completely safely flare the tube to SAE 45 and use it on a AN/JIC 37.5 in >3/16 and even 3/8
December 16, 2009 09:26PM
I would expect any person here to consider what they do for work, and what people within the trades we are speaking of do and say. I would never had even tired this had not more than a couple of people in the hyraulic supply and race car build business said "Consider the angle difference between 37.5 degrees and 45 degrees on a 3/16th flare. It differs by mere ten thousanths of an inch--well less than the average person can be certain that they just did on their flare."
And actual experience has proven them right.
Dozens and dozens and dozens of times over.
Reality MUST count in the end more than a book by an fellow famous for extreme pedantry who works primarily in areas of limitless budgets, and idealised situations.
Of course on larger sizes it would never work.
token-negro
Kendrick Gray
December 16, 2009 09:54PM
Ok so this works ONLY on 3/16 3an stuff and only with SAE double flare? So the odds are this worked for someone who had ZERO knowledge of the thou they are off and it works thus they think they can do this on all AN fittings. Just the way people are. Much safer to just say it does not work and leave the anomoly to the smart guys then.
It's always something, either it works or its right? Ill take right over well it works fine.
Edited 1 time(s). Last edit at 12/16/2009 09:59PM by token-negro.
vbares
Vittorio Bares
Audi 4k (3b conversion)
December 17, 2009 07:36AM
BTW - look around the net, you can find 37 degree flaring tools (quality ones that usually go for $100+) in the $25-$30 range. The one I found was brand new, never been used.
My hydraulic guy has also indicated that in certain sizes 45 and 37 degree are compatible.
December 17, 2009 09:34AM
Lucky for me, since I used to work on aircraft, have a 37 degree flare tool kicking around in my tool box.
December 17, 2009 10:35AM
So many wisecracks, so little time... smiling smiley
JonArmstrong
Jon Armstrong
Rallycross Civic
December 17, 2009 12:26PM
How about sharing some of your awesome deal searching skills with some links...
vbares
Vittorio Bares
December 17, 2009 12:57PM
see there..phlat65 will *give* you one :p
Here's where I found mine:
http://connecticut.backpage.com/ToolsForSale/_25_imperial_eastman_37_and_45_degree_tube_flaring_tool_new_1_860_668_7266/classifieds/ViewAd?oid=2581075
I'm sure there are other sources - the mainstream crapbay ain't gonna cut it though. CL is ok, use www.searchtempest.com for easier searching...
Ratfink
Daniel Llewellyn
I ride shotty in a huge truck
December 17, 2009 07:56PM
I have seen 45 double flare matched to A/N fittings and inevitably they leak. the stainless line will gouge the fitting and after service the seal is shot and leaks.
Boost early and Boost often
JonArmstrong
Jon Armstrong
Rallycross Civic
January 27, 2010 11:05AM
Beating a dead horse here, I know.
Found the SAE flare spec online: http://mecholsky.mse.ufl.edu/EMA4714/Flare%20Tube%20Specifications.pdf
Looks like the diameter difference of the flare between a 45 degree single flare and a 37 degree single flare is indeed pretty small as John has theorized.
-for 3/16" line, there is a 0.026" difference in diameter
-for 1/4" line, there is a 0.030" difference in diameter.
So, using a 45 degree flare tool for a 37 degree fitting, the diameter would have to be crushed by this amount when the tube was mated to the fitting for the first time.
token-negro
Kendrick Gray
January 27, 2010 11:56AM
> theorized.
> diameter
> diameter.
> for the first time.
Thats is all true but what I feel is the issue is when we mix and match aluminum and steel fittings. If you are using stainless tube, and alum tube nuts on an alum bulkhead that extra torque as little as it is now possibly groves up the mating face on your alum fitting. If you are in a pinch with all steel or all alum tube, tube ends, fittings etc then it should work right? THe question is if u cant borrow or afford a 37 Degree flare tool to just do the whole thing right.
