Re: And I swore I'd never touch acid again....
December 16, 2009 04:45PM
> Well just moving the loom aside and squirting the
> Liquid N is pretty easy, stop making sense
> www.rallyrace.net/jvab
> CALL +1 206 431-9696
> Remember! Pacific Standard Time
> is 3 hours behind Eastern Standard Time.
The loom!?? We threw that out already. Who doesn't make their own loom???
I am leaning towards LN though just because of the painting issue.
Edited 1 time(s). Last edit at 12/16/2009 04:46PM by david amor.
December 16, 2009 05:27PM
> THEN while they were stipping I could go watch
> some stripping
> "this is certainly not a game for flyweights or
> ping-pong players-all arguments to the contrary"
> -C.B.
Ah yes, that reminds me of my friend sweet Sasha (rest in peace) up in Portland Or. I remember bumping into him at the DMV. You could take a number and leave the building while you wait. He had it all figured out: he got his number, then went down the block to the Dancing Bare. It ended up taking three days.
Don't get me wrong, if I could I would have gotten my shell stripped (probly media blasted), kept it in a heated garage during the build, then a good paint job, but, maybe next time... gotta go get that lottery ticket
Ted Andkilde
Ted Andkilde
1968 Mini
December 16, 2009 07:18PM
Hey David
Don't know if there is anyone your way who offers the service but in Windsor there's a guy who does smaller parts (doors, fenders etc), caustic dip to strip, followed by neutralizing and full-on e-coat. Stuff comes out looking great and gets you nice deep in the crevices rust protection. Be nice if someone had a tank big enough to do full bodyshells. A bunch of my customers have the equipment but would probably get a little cranky if I ran some "furrin" POS through their lines smiling smiley
t
December 16, 2009 07:52PM
Ted Andkilde Wrote:
> Hey David
> t
> Pure mathematics is the enemy of every truly
> creative man -- Sir Alec
The place I talked to in Brampton dips, neutrilizes then applies a water based coating only. They said they do not do any kind of painting whatsoever. I thought I could save time by dipping but now as someone mentioned the painting will be such a huge project and I don't have a booth to do it in. Maybe I should just do the LN. I still need to borrow buy or make a rotisserie as well.
Ted Andkilde
Ted Andkilde
1968 Mini
December 17, 2009 06:48AM
I've seen a serviceable rotisserie constructed out of two Princess Auto engine stands and a couple of 4x4 fence-posts, elegantly affixed to the fingers on the engine stands with big-ass exhaust u-bolts. The only issue it had was it was a little 'tippy', so a couple of long 2x4s were c-clamped to the bottom of the stands as ghetto outriggers.
t
urr
Andrew Sutherland
Subaru, EVO, Honda, Husky
urr
take a bath
December 17, 2009 05:28PM
No rust experience but...
I’ve done the dry-ice, wire wheel on the grinder and torch way....AND….most recently I’ve done the acid dipping way.
Which one is better? It depends…..
Acid dipping a shell in So Cal costs about $1900.
If you’re (or the shop you’re paying) time is worth $40 per hour, you’re losing money if it takes longer than 47.5 hours to clean the shell manually. The cheaper your time is, the longer the available hours to clean it manually.
Does the acid eat everything? It depends….
Straight caustic soda won’t even take the paint off a newer car (according to the acid dipper). A local rally/roadrace guy had a Ford Escort dipped in a weak mix and it hardly took the paint off!!
I had my 2008 Evo X dipped, at a different place than above, and there’s virtually no seam sealer or glue of any kind left!
The car was dipped in caustic soda that was heated to 220 degrees. They let is sit for 24-36 hours in the bath, then pulled it out and sprayed it off. Repeated until clean….about 14 days.
In fact, I forgot to mention that the roof was aluminum to the acid dipping place and when I went to pick the car up, it was completely gone! The caustic soda they used had “additives” and the aluminum roof dissolved like Alka-Seltzer in water!
We’ve started the seam welding and there is zero prep required. All of the seams are clean and easy to weld. I’ll never clean a chassis again by hand…unless it costs me $5 per hour!
Andrew
Edited 1 time(s). Last edit at 12/17/2009 10:10PM by urr.
Re: take a bath
December 17, 2009 05:41PM
So what'd you pay on that Andrew? Was that the $1900 number?
Did it remove the paint too? Not that I can afford the acid dipping and I've got someone else paying for the Liquid Nitrogen if I can ever get Airgas to actually give me a quote or firm confirmation that they'll sell it to me, and stop telling me they'll call me back later or tomorrow.
hudson
Andrew McNally
Re: take a bath
December 17, 2009 05:42PM
urr Wrote:
> We’ve started the seam welding it there is zero
I think one part that is often over looked in general is the cost of consumables (discs, wheels, paper, electricity).
That stuff can add up fairly quickly.
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Re: take a bath
December 17, 2009 05:43PM
> $1900 number?
> tomorrow.
Sometimes, if you feel that you're getting blown off or the person just can't follow up, showing up in person will get it done.
Andrew M
Onterrible
30ish
urr
Andrew Sutherland
urr
Re: take a bath
December 17, 2009 05:46PM
I got a $100 off since my $950 roof skin dissappeared...so $1800. I'm sure there are cheaper places in other parts of the country.
My understanding is that you can find acid dipping places in areas that have a heavy aerospace roots.
Re: take a bath
December 17, 2009 05:56PM
> acid dipping way.
> water!
> Andrew
Amazing resistance to the simple liquid Nitrogen.
Utterly, and unfathomably amazing resistance.
And don't suggest the fucking dry ice shit is the same....it isn't by a mile.
I guess some people like to throw away thousands for fun.
urr
Andrew Sutherland
urr
Re: take a bath
December 17, 2009 07:35PM
> for fun.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
I looked into the LN. I went as far as buying small dewar's off ebay. Spoke with Airgas and the only way they would give me LN was if I rented a huge ass dewar from them...and then I'd need to fab up a mechanism to get it out of the dewar, without burning off a finger or two! I just seemed like a pain in the ass to me! If you have the equipement already, I'm sure it's a great alternative.
It's a race car...throwing away thousands for fun is what it's all about!!
Edited 1 time(s). Last edit at 12/17/2009 07:37PM by urr.
December 17, 2009 08:14PM
"Caustic soda" makes me think it's nothing more than good old lye, which will definitely dissolve aluminum all by itself, especially at 200+ degrees. It's the direct opposite of acid.
I've seen bearings destroyed when in a spray cleaning tank (think Dishwasher From Hell) for only eight minutes. We use some fancy aluminum-safe chemical from Zep now.
And, yeah some paints it won't even touch, but it will take surface rust off like nobody's business.
I missed out on the part where when the lye solution gets changed, they dump 5 gallons of 95% sulfuric acid into the (200 gallon) tank. It's supposed to be quite *energetic*...
Re: take a bath
December 17, 2009 08:55PM
> $1900 number?
> tomorrow.
> Grant Hughes
> Denver, CO
Yeah, go in person, put on your best friendly guy face and make friends with the guy in charge at your airgas. I think they aren't really supposed to let those liquid N2 bottles just go out the door, usually they deliver them, They are kinda dangerous, you could freeze your foot right off. Also, I think its used for crime, like safecracking, so you have to be pretty straight up about what you are doing.
Re: take a bath
December 17, 2009 09:11PM
urr Wrote:
> Nitrogen.
> resistance.
> the
> thousands
> > for fun.
> > John Vanlandingham
> > Sleezattle, WA, USA
If you'd read the 10 years of posts, you'd see i say "Talk to where you buy your welding supplies"...they'll suggest opening an account backed up with a credit card. You use the stuff and call, they pick up. No charge to me anyway.
Piece of their extra hose to a piece of 1/2 waterpipe smashed flat on one end well thats 2 minutes, then some sorta insulated handle....
Didn't seem too rough when I did it...
5 cars so far and I have all mine.
I just
And stripping the car, hauling it around, waiting a week or more, paying a couple of thousand dollars is convenient?
OOOOooooooooooooOOOOHH.
If you have
> alternative.
If you have read the last 10 years, then you see I lend the thing out.
For fun maybe, for nothing, well..........
I was trying my damnedest to be as polite as possible.
> Edited 1 times. Last edit at Dec 17, 2009 by urr.
