derek Derek Bottles Godlike Moderator Location: Lopez Island/ Seattle WA Join Date: 12/20/2005 Age: Possibly Wise Posts: 853 Rally Car: Past: 323, RX2, GTI. Next up M3 ? |
From a theoretical view I expect that the extra volume would help when at relitively low turbo shaft RPM's going from closed throttle to open throttle. However the volume would also hurt when turbo rpm is incressing as it would take longer to build pressure, so they must figure the turbo spools up faster then the tank drops pressure. When we consider that turbos are producing something like 400 CFM or ~7 Cubic Feet per Second we can see even a very large tank would have very little time to be effective. It may also act to lessen the shock of closing the throttle quickly. As I see the tank basically dampins spikes in pressure, both positive and negative changes.
Air temp would be unchanged as we are not seeing a pressure drop in the tank, in fact having the tank lessens the pressure drop vs. a standard tube and thus lessens the temp drop: PV=NRT thus the more V the less T on the other side is going to go down. P=Pressure, V=Volume, N=Number of molecules, R=Universal Gas Constant, T= Temp. One of the more edumecated folks can follow up and correct all the errors that have accumulated in my head since I finished up college a few decades ago if I am wrong. In the long run reality always wins. |
derek Wrote:
------------------------------------------------------- > From a theoretical view I expect that the extra > volume would help when at relitively low turbo > shaft RPM's going from closed throttle to open > throttle. However the volume would also hurt when > turbo rpm is incressing as it would take longer to > build pressure, so they must figure the turbo > spools up faster then the tank drops pressure. > When we consider that turbos are producing > something like 400 CFM or ~7 Cubic Feet per Second > we can see even a very large tank would have very > little time to be effective. It may also act to > lessen the shock of closing the throttle quickly. > As I see the tank basically dampins spikes in > pressure, both positive and negative changes. From a practical point of view, I don't see that the increased volume is going to make enough of a difference with respect to response when the turbo isn't spinning. (For the most part, turbo speed mostly defines boost, not flow.) Adding four liters of volume is eight engine revolutions or so, at 1000rpm this is something like a half-second's worth of air and it's not like the volume needs to be fully discharged to allow pressurized air in, the air that's already in there will be pressurized so it matters even less. Plus, there's no appreciable difference in response when going from a top mounted intercooler to a front mount with 8-10 feet of additional ducting. What I DO see however is a gread reduction of VELOCITY in front of the throttle body. How that is important, is the air in the tube will not have to accelerate as much when going from shut throttle to open throttle, or decelerate as much when you shut that throttle in the first place. Neat setup... Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Mark Mark Malsom Junior Moderator Location: Denver, CO Join Date: 02/06/2006 Posts: 153 Rally Car: Subaru Impreza |
eyesoreracing Dave Coleman Super Moderator Location: Long Beach, CA Join Date: 05/13/2007 Age: Possibly Wise Posts: 448 Rally Car: Mazda3, SE-R Spec-V, 510 |
Do It Sidewayz Chris Martin Professional Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
acrane adam crane Super Moderator Location: Seattle, WA Join Date: 01/28/2006 Posts: 382 Rally Car: corolla GT-yes |
translated a Dutch site,
http://translate.google.com/translate?js=y&prev=_t&hl=en&ie=UTF-8&layout=1&eotf=1&u=http://www.extreme-machines.nl/forum/viewtopic.php%3Ft%3D42653%26sid%3D31ff6f8900aa7868d3e453d8baa173e9&sl=nl&tl=en - there is a pressure reservoir that uses excess boost, and inserts it at low RPMs behind the throttle to increase/maintain boost. or basically pre-pressurize the huge intercooler, and keep the turbine spinning. another explanation from NASIOC -though the "rocket" turbine shit is ridiculous. clearly just a reservoir for compressed gas - no combustion there. the large valve on the flex pipe of the exhaust manifold of the subuaru is pre-turbine, and there is clearly an external waste gate post turbine so i'm guessing that it's where fuel is injected and ignited to spin up the turbo for the anti lag. http://translate.googleusercontent.com/translate_c?hl=en&ie=UTF-8&sl=nl&tl=en&u=http://forums.nasioc.com/forums/showthread.php%3Ft%3D1650384&prev=_t&rurl=translate.google.com&twu=1&usg=ALkJrhhHr_DlSrm-DRvZKpt0KDldSgTaUA watch this video and note the sound and RPM of the subarus also clearly remember the mitsubishi WRC in car from 2007 having a click woosh sound. at 15 seconds when the rpms drop and often afterwards. gardemeister driving. Here is a Skoda WRC, look at the antilag blaster above the exhaust manifold, and how it gets the intake air from the pressure side of the intake. http://forums.vwvortex.com/zerothread?id=4620769&postid=61613935 "I put the hurt on dirt" - adam crane http://CraneRallyCrew.com corolla gt-s "Patches" Op: S.S. Edited 1 time(s). Last edit at 12/17/2009 11:32PM by acrane. |
nick the brit Nick Taylor Elite Moderator Location: North Hollywood, CA Join Date: 01/25/2006 Age: Possibly Wise Posts: 149 Rally Car: 1995 Subaru Impreza WRX |
Jon Burke Jon Burke Ultra Moderator Location: San Francisco, CA Join Date: 01/03/2008 Age: Possibly Wise Posts: 1,402 Rally Car: Subaru w/<1000 crashes |
so my friend just emailed me back:
"Re: technical question for you "Yes it stores boost that's about all I can say." " there you have it folks ![]() I posted this same question over on dirtyimpreza.com and this is the best answer (that makes the most sense to me at least) I heard as well....
Jon Burke - KI6LSW Blog: http://psgrallywrx.blogspot.com/ Edited 1 time(s). Last edit at 12/20/2009 06:30PM by Jon Burke. |
BillyElliot Billy Elliot Mann Infallible Moderator Location: Royal Oak, MI Join Date: 08/11/2008 Age: Midlife Crisis Posts: 557 Rally Car: 1996 Honda Civic with VTEC YO! |
Its part of a very expensive anti-lag/pre-spool system. The tube dumps air into the exhaust (there's a valve controlling it somewhere down there), and the big cylinder sitting in front of the intake manifold is some kind of combustion chamber that feeds in fire. That's the word on the street, at least. Still trying to figure out how an aluminum tube has the structural wherewithal to be a combustion chamber, and I still don't see how its connected to the system, so probably that's all BS...
-Dave |
The antilag system we ran for a short time in the hill climb Audi used a HKS bypass valve, dumped air directly into the exhaust manifold. Then super retard the timing so the spark hits when exhaust valves are fully open and BANG! Loudest and most violent antilag I've ever heard. The benefit was retaining engine braking as the spark was literally that late. Never really ran with it as it was seriously that violent. Like worried about breaking out the windows in the shop and it made it scary to go near it. If we had a turbo sponsor, maybe would have left it and went with it...
Grant Hughes |
------------------------------------------------------- > The antilag system we ran for a short time in the > hill climb Audi used a HKS bypass valve, dumped > air directly into the exhaust manifold. Then > super retard the timing so the spark hits when > exhaust valves are fully open and BANG! Loudest > and most violent antilag I've ever heard. http://www.bufkinengineering.com/Umluft.htm I don't think we're looking at the same piece on the Subaru setup, though. There IS a device to dump charge air into the exhaust stream but the technical question (I thought) is, what's up with the huge diameter piping between the intercooler and throttle body? Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Looking at the picture, that aluminum "combustion" chamber has a rubber hose (unless it's a stainless covered in rubber?) going to it from the turbo area. I've got a bunch of WRC Subaru engine bay pics that can give different angles. Let me get them uploaded... Pics are 2007, 2007, 2003-2005, 2006.
That reservoir looks like it's coming from the power steering on other generations of the engine bay. ![]() ![]() ![]() ![]() |
Daniel Buehler Daniel Buehler Godlike Moderator Location: Beeton, Ontario, Canada Join Date: 01/08/2009 Age: Midlife Crisis Posts: 246 Rally Car: 94 Subaru Impreza, AWD, No Power! |
http://forums.nasioc.com/forums/showthread.php?t=1650384&highlight=wrc+rocket
^^^ That other thing - not the boost tube. Edited 1 time(s). Last edit at 12/23/2009 10:18AM by Daniel Buehler. |
If that's the article Dave mentioned. I don't think there is combustion in that chamber, it just holds pressurized air in it? It's just a clever way of doing ALS with not so much BANG BANG.
Bit off topic, but new WRC cars more go "chirp chirp" but is that just due to the lack of a blow off valve and the noise is compressor surge? |
