Macro Poxy Application Advice?
Posted by token-negro
Re: 3m Seam Sealer application
December 27, 2009 03:38AM
token-negro Wrote:
> NoCoast Wrote:
> > Looks like caramel. Cool for a street car
> but I
> > won't be doing this to my rally car.
> > Grant Hughes
> > www.nocoastmotorsports.net
> > Denver, CO
> Yeah probably to much effort for you.
ooooooh someone smell smoke? lol
December 27, 2009 11:31AM
Haha. No, not the effort but it takes too much time and effort clearing all that shit out to just put something back in. The seam sealer that is. The epoxy stuff seems like a fine idea.
token-negro
Kendrick Gray
December 27, 2009 11:39AM
> Grant Hughes
> Denver, CO
Well yeah, just to put the epoxy on way to much work, but i took it all down to weld up the seams, those pictures i left out. So stripped, seam welded, then sealed it back up with the seam sealer, then the epoxy top coat.
token-negro
Kendrick Gray
Re: Macro Poxy Application Advice?
December 27, 2009 01:27PM
So what i learned-
Temp as been covered make sure everything is up to temp, it says 40 degress, but i would shoot for 50-60 surface temp.
I would advice aginst rolling or brushing this stuff, if you want it to come out smooth, and look professional, spray it! Much more of a PITA but the results will be worth it. Rolling it the material was so thick it was really hard to work with. Pickup some thinner and thin it down. I know for rally cars u guys dont go for looks but this will help in overall ease of use.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
December 28, 2009 08:37AM
How long does it take to dry and what was the pot life like?
token-negro
Kendrick Gray
December 28, 2009 03:02PM
Pot live depends on temp, everything with this stuff depends on the temp. If u google it and find the material form on it, you will get a lot of info from that.
Jim Breazeale
Jim Breazeale
1988 Audi 90 Quattro and The Devil Bunny of Caer Bannog
December 28, 2009 05:54PM
Well done! It looks good and we all have learned something. Round of applause from the gallery.
Diamond Jim
Co-Driver in the Double Zero course opening car
Charter Member of O.U.C.H.
Organized Union of Cat Herders
token-negro
Kendrick Gray
January 04, 2010 02:02AM
Second coat applied today, i kept the material inside for 4 days to warm it up, then kept it in front of a small heater when mixing. Kept the temp up and the second coat went on a lot better then the first. It was much thinner when warmed up.
January 07, 2010 02:16PM
January 07, 2010 02:19PM
Yeah... So... Umm...
I'm REALLLLY glad I asked about spraying it. The guys at Sherwin-Williams were toting the benefits of spraying it when I asked about pressure settings and tip sizes for my HVLP gun... Then they went silent.
To spray this stuff, you need a big specialized machine/gun. Rental fee and pain in the ass to clean = me brushing it on.
January 07, 2010 02:23PM
What type of temperatures are we talking about here?
I just finished the final touches insulating the garage.
I can do 50 degrees for cheap, 60 costs a bit, and 70 is going to cost me about $3 a day.
token-negro
Kendrick Gray
January 07, 2010 06:40PM
70 Just keep the cans warm with a little heater or a warm place in ur house 4-5 days before u start working with it.
Re: MacroPoxy ROCKS!!!
January 18, 2010 08:26AM
Thanks for all the advice Chris.
Okay, I love the stuff!
The first coat was like trying to spread glue. The second coat was easy.
Wierd to get used to 'paint' hardening instead of drying. I left it in the bucket ~30 minutes longer than I needed to because I forgot to cover some bolt holes. When I started using it, I thought it was allready hardening. It took about an hour for me to realise that it was just the normal consistancy smiling smiley
Second coat was a basically just a touch-up coat, for areas I'd missed. I still have a couple small places to get to. Once I flip the shell back over, I'll still have to do the Co-Driver side front footwell and rocker.
I protected the bolt holes with tubing or tape wrapped around the threads of bolts.
BEFORE:
AFTER:
Edited 1 time(s). Last edit at 01/18/2010 08:27AM by Daniel Buehler.
token-negro
Kendrick Gray
January 18, 2010 09:50AM
Nice work! id love to be able to spray this stuff i bet the finish would be so awsome. Make sure you give it the 48hrs before you do any touch ups.
January 18, 2010 11:38AM
Looks awesome man!
Stuff stinks doesn't it!
You had a good weekend for painting!
