brianallmotor
Brian R. Barton
Mazda 323 BP-T
fake the heat difference check
January 20, 2010 07:04PM
http://rally-america.com/RuleBulletin/Rule_Bulletin_2010_002.pdf
How does one fake the heat difference check ??? the only thing i could come up with is wrapping exhaust tape around the inlet pipe.......
Re: fake the heat difference check
January 20, 2010 07:10PM
You could weld a lump of steel inside the split open can of a domestic cat. It would retain more heat than the front sheetmetal and show up some degrees hotter.
You could just lobby and refuse to play stupid games.
January 20, 2010 07:31PM
Just put some wire mesh over your tailpipe and call it good! Sure looks like a grid to me...
January 20, 2010 07:40PM
They say they want to see at least a 1 degree differential front to back and they take that to mean its working...Whatever!
January 20, 2010 08:17PM
Nah, they axed that part. Now they just want to see a grid.
January 20, 2010 08:57PM
> see a grid.
In related news, the sale of steel window screen took a surprise jump today...
impfected
Alan Petersen
maybe a Hillman Imp
January 20, 2010 08:59PM
Are they asking to see you exhaust before it is installed or at the event?
Regardless, what is to prevent you from replacing the cat after it's been viewed? A special seal on the nuts of the cat.?
What about those cats (audi A6 and such) that need to have the engine pulled to replace/view them?
Painful.... Glad I have an old car..
January 20, 2010 09:04PM
Brian,
You are an idiot. Several Rally America scrutineers read this forum.
Why not just install a real cat and save yourself the trouble? There is no significant performance loss and you will be legal.
Do the right thing.
RallyTaco
Chris Lanctot
just a wannabe
January 20, 2010 09:52PM
Rallymech Wrote:
> Brian,
> Do the right thing.
> Robert.
> "You are way too normal to be on Rally Anarchy."
> Eddie Fiorelli.
Wow. I took the OP's post as a real question as in "There is this rule change citing people faking a thing and I don't even get how you would do that?" not "Please tell me how to fake the temp rise to beat a now defunct rule."
Am I missing a back story or something?
[jvl] Ohh noooohs! There's an h'off tawpik thread in the gent-urinal dick-cushion four-hum. THINK OF THE CHILDREN!!![/jvl]
January 20, 2010 10:38PM
If'n I was going to try to make the inlet read cooler than the outlet, I'd stick a piece of tubing (with a very close fit) in the inlet.
That's how slip-fit exhaust pipes seal, the inside pipe runs hotter than the outside pipe and expands until it seals, but when it's cold it can slip. So I'd be making the front half a kind of slip fit installation, so the outside pipe will show colder than the inside, and at the back there is no inside pipe to absorb the heat.
January 20, 2010 10:57PM
RallyTaco Wrote:
> Rallymech Wrote:
> > Brian,
> yourself
> performance
> > Do the right thing.
> > Robert.
> Anarchy."
> > Eddie Fiorelli.
F. For all vehicles in all classes for all Performance Rally events, a
functional catalytic converter shall be installed. Functionality shall
be determined by the following: 1) a visible and complete grid within
the catalytic converter, or <REMOVED>. 2) a heat gain of 5% or greater from the
inlet to the outlet of the cat with the outlet being hotter. <REMOVED>
Rationale:
It is too easy to fake the heat difference check, so it is being eliminated.
OP is asking about the Rationale listed in the bulletin.
Rallymech: apologize NOW!!! no hurting internet feelings!!!! how darz yooo!?
Edited 1 time(s). Last edit at 01/21/2010 12:56AM by Jon Burke.
brianallmotor
Brian R. Barton
Mazda 323 BP-T
January 20, 2010 11:14PM
i got a real cat.
January 20, 2010 11:53PM
So now the geniuses have decided I need a cat on a 1969 car with drooling carbs, a/f ratios all over so we know the cat is acomplish nothing.
Geniuses.
January 21, 2010 08:58AM
After wasting 10 minutes of my life waiting for the 40 mb rulebook to download...the original rule.
functional catalytic converter shall be installed. Functionality shall be
determined by the following: 1) A visible and complete grid within the
catalytic converter, or 2) a heat gain of 5% or greater from the inlet to the
The only exceptions that may be granted to the above rule, and then only
if documentary evidence is kept with the vehicle logbook, are:
1. For vehicles running the event powered by diesel fuel.
2. For vehicles that were imported into the USA prior to 1980, and that
did not have a similar model by that manufacturer that was sold in
76
the USA with a catalytic converter.
3. For U.S. vehicles sold prior to an EPA catalytic converter
requirement.
Since somebody closed the browser window on my computer with the rulebook while I stepped away for a few minutes,I can't tell for sure if the bulletin eliminates the exception clauses or not.
January 21, 2010 09:01AM
Never mind, Fiasco supplied the clarification I was looking for above. Older cars that were never equipped with cats don't need them.
Edited 1 time(s). Last edit at 01/21/2010 09:04AM by Doivi Clarkinen.
