Piston slap and a rally engine...
Posted by Daniel Buehler
hudson
Andrew McNally
Just making sure I've got it straight.
January 30, 2010 02:19PM
In another thread we we're talking about Porsche engines being crap and Subaru engines being much better.
Now we're talking about Subaru engines are crap.. so Porsche engines must really suck, or is nothing up to Rally Anarchy standards? winking smiley
Andrew M
Onterrible
30ish
Re: Just making sure I've got it straight.
January 30, 2010 02:27PM
> better.
REALLY?
hudson
Andrew McNally
January 30, 2010 03:24PM
I thought this thread was going on about it:
http://www.rallyanarchy.com/phorum/read.php?7,35969
But I'm sure I was hearing Porsche = Crap, Subaru the best ever somewhere... Maybe I'm just getting old
Andrew M
Onterrible
30ish
January 30, 2010 03:42PM
> old
> Andrew M
> Onterrible
> 30ish
NASIOC?
January 30, 2010 04:47PM
> better.
Subaru engines are fine for the intended purposes: Yuppie granola wannabes driving leisurely to the Esspresso stand prior to driving up the mountain at a super annoyinmg pace holding up 20-40 cars for hours on end.
Everything is marginally sized, very little margin of safety, lightweight, , strange design of piston dish SQUARE DISHES!!!! WTF. skinniest main bearings I have ever seen in an automobile engine.
> Andrew M
> Onterrible
> 30ish
January 30, 2010 05:09PM
Dazed_Driver Wrote:
> Subaru
> getting
> > old
> > Andrew M
> > Onterrible
> > 30ish
> NASIOC?
> Feisty Peacock?
The only problem with Porsche engines is that they cost so much.
January 30, 2010 05:50PM
> Porsche
> much
> > better.
> crap..
> nothing
> for hours on end.
> engine.
> > Andrew M
> > Onterrible
> > 30ish
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.rallyrace.net/jvab
> CALL +1 206 431-9696
> Remember! Pacific Standard Time
> is 3 hours behind Eastern Standard Time.
All true. It takes alot of money and careful assembly to get the motors even half reliable. They need to be maintained religiously. The only beauty with subaru's is that as a PACKAGE, and for their intended puposes, tend to work quite well.
NGTD
Dave Cotie
Re: Piston slap and a rally engine...
January 30, 2010 08:22PM
NGTD Wrote:
> My mom's 2004 Legacy had slap so bad that Subaru
> replaced the shortblock with barely 60,000 kms on
> it. Tech said the engine would not have lasted
> another 10,000 kms. The car sounded like a diesel
> at idle.
> I say run it till chucks. Its a rally car, blow it
> up, get a new one, rinse and repeat!
BTW, just found out my mom's car is getting ANOTHER shortblock swap. The second one is toast also.
January 30, 2010 08:42PM
NGTD Wrote:
> Subaru
> kms on
> lasted
> diesel
> > at idle.
> blow it
> also.
she must be doing 1/4 mile pulls down to the grocery store and/or coffee shop?
January 30, 2010 10:32PM
Man, I beat my 03 Legacy pretty hard, run nothing but the finest oil that's on sale (I do splurge on filters usually), tow firewood loads that weigh more than Randy Zimmer's rally car and trailer, bang it off the rev limiter with some frequency and the thing is GREAT at 130k miles. OK, it does rattle a bit when it's first started, and it does eat 1/2 a quart between oil changes now, and it did have headgaskets and clutch done under warranty 100k miles ago, but I really can't complain about this car (aside from wishing it was a WRX wagon, but my license probably thanks me).
Now it'll blow up tomorrow and I'll be minivan shopping. Maybe I should just delete this before I hit post.
tedm
Ted Mendham
February 01, 2010 02:51PM
MINIVAN?
I heard that New Hampshire just voted in assisted suicide. ;-)
Ted Mendham
www.rensport.net
B-
Barrett Dash
Mazda3, Xrat
B-
February 08, 2010 04:52PM
david amor Wrote:
> john vanlandingham Wrote:
> about
> > Porsche
> being
> > much
> > > better.
> are
> > crap..
> is
> > nothing
> purposes:
> the
> mountain
> cars
> > for hours on end.
> margin
> piston
> > engine.
> > > Andrew M
> > > Onterrible
> > > 30ish
> > John Vanlandingham
> > Sleezattle, WA, USA
> "this is certainly not a game for flyweights or
> ping-pong players-all arguments to the contrary"
> -C.B.
This is a pretty funny thread..Especially since the OP started a thread long ago asking what to use when swapping out the 1.8.smiling smiley Part of the steep learning curve. There is a reason why "take out" 2.5s are cheap, they are all getting ready to shit the bed, unless freshly rebuilt. Don't bet on that knocking 2.5 lasting 10k on stage.
All 2.5 Normally aspirated Subaru engines are the worst of the lot of them. Regardless of SOHC, DOHC, PH 1 or 2, it doesn't really matter. They all see the same fate. Failed head gaskets that lead to over heating, and lower end (bearing failure) issues due to scoring. It doesn't take long to smoke the bearings when you're rolling along at highway speeds w/ no coolant in the car.The block, head gaskets, and bearings are all prone to failure..Very similar to the 3vze Toyota V6.Inherent design flaw with the cast iron block and aluminum heads.The prob with the 2.5 (ej25) is the small head gasket mating surface area
Does that mean all Subaru engines suck.. Not even close. The majority of the other powerplants last well over 100k, usually 200k+ with routine service. This is true of even the EA81 and EA82 GL 1.8L powerplants. The 2.2 (Ej22) is the warhorse and the 1.8 (EJ18) is a close second only due to the lack of power vs. the 2.2. Those engines can last amazingly long getting the crap kicked out of them, low on oil, high revs, etc. Also non-interference, and about $250 for a good running pull-a-part engine. That's usually what a set of questionable 2.5 heads goes for.. Or build a hybrid w/ a 2.2 block and the DOHC heads.
The newer turbo powerplants (EJ20, EJ255, EJ257) are actually more reliable than the NA versions when kept close to stock.
B-
Build the car, race the car, crash the car, fix the car..Repeat
February 08, 2010 06:02PM
I ran a EJ22 engine with 3 quarts of oil short and almost no coolant in it for quite a while. Until Mark ran a red light and totalled it.
tedm
Ted Mendham
NA is for luzers!
February 08, 2010 08:54PM
I'm running an EJ25 turbo as a daily driver, because we don't have a lot of evos round heah. I run it low on oil, bounce it off the rev limiter, take it to the track, turn up the boost and drive it into school buses and econoline vans and it still goes. It's as reliable as death and taxes. Why do people buy the things without a turbo any ways? Penny wise, but pound foolish, I say. It would be like a massage without the happy ending. That AWD crap makes for huge driveline losses. You need all the torques you can get.
Ted Mendham
www.rensport.net
February 09, 2010 12:34PM
Thanks Barret, there's good info in there.
My older threads were to help me decide on which NA engine to use. I have access to a good 1.8l, a couple 2.2l's and a 2.5 that's in my daily driver. One of the 2.2's that I have was a beast. I kicked the crap out of it daily, never had a problem, then the ground met the roof. That was 3 and a bit years ago. The engine has sat on a stand in my garage since then. I don't know enough about engines (This is one area I know virtually nothing about) to know if I should expect problems from the engine having sat for so long. All fluids were drained, and the temps in the garage range from -30c to +30c... It had a leaking headgasket I'm sure, it was a 240,000km engine. But if I knew that sitting for so long would have no effect on it, I'd gladly use it. I have new timing belt pully's and a waterpump for that engine. I'd just do the headgaskets and maintenace and be done with it. I have 2 spare 2.2l harnesess labled and ready to go. I like the 2.2 and I know it has enough umph for me to have fun.
The 1.8l I have is in great shape, a timing belt and general service is all it needs. I don't know what that engine would be like with AWD. It was a heap load of fun with FWD and 13" rims (daily driver for two years). I'm affraid it would just chug, I just don't know what to expect.
If anyone knows what a 1.8l AWD feels like with tall(ish) gravel tires, please let me know!
The 2.5l is sitting in my driveway right now. It's my daily driver (kinda, I carpool with my wife and we take her car 99% of the time). It's a 2002 Impreza Outback sport. In 2003 it was hit hard in the rear - $11,000 in damages. I bought the car almost 2 years ago with a lot of rust where the crappy repair was done. It's slowly rotting away. I've gotten my money's worth and don't think it's woth much to anyone else, that's why I thought about using it as an organ doner for the rally car. Not to mention that all the parts would plug in... well the ODB2 ones at least I can splice in the little things.
Being that I have a few options and that none of them seem to jump out at me as "the best one", I'm having a tough time deciding. But... with a little luck, in a couple weeks, I'll need to know - paint starts this weekend.
Edited 1 time(s). Last edit at 02/09/2010 12:35PM by Daniel Buehler.
