Rust Prevention: What would you do?
February 09, 2010 09:13AM
So what would you do here to prevent rust?
Specimen A
- My cage has a "X" that passes through the firewall and the rain tray. Accessing this area is difficult to say the least.
Specimen B
- I repaired the rear quarter panel rust by welding in a patch (first sheet welding project for me). Part of the area is hard to get at, but I can reach about 75% of the metal easily.
Specimen C
- There is rust underneath this support (which is located at the base of the C-pillar. I've got a patch welded on on the other (accessible) side. I' don't think I can reach this area, certainly not with any dexterity. I got this picture by shoving my camera between the trunk wall and the rear quarter panel.
Here's the patch from the other side (top of the picture).
As always, thanks for you assistance!
Re: Rust Prevention: What would you do?
February 09, 2010 11:12AM
I'm thinking there are three possible ways to deal with it:
1 - do my best to clean it and paint it
2 - spray some oil product on it and forget about it
3 - use a POR-15 or Rust Encapsulator type product right on it
February 09, 2010 11:29AM
> with it:
> it
> right on it
Anything or nothing would be fine.
February 09, 2010 12:07PM
What would you do if it were your car?
Edited 1 time(s). Last edit at 02/09/2010 12:17PM by Daniel Buehler.
February 09, 2010 01:24PM
Well I sure wouldn't have spent all that time seam welding it. Haha. Just kidding.
On my car, I hit it with a wire wheel if I can, then paint it. I can't see the pics and you probably live in a more rust prone area than I do though.
February 09, 2010 02:00PM
por 15 brushed on will go over fairly messy shit if all the loose stuff is more or less knocked off.
February 09, 2010 02:09PM
You just put a grin on my face. Ear to ear...
> though.
Yup, rust grows on trees here.
> Grant Hughes
> Denver, CO
February 09, 2010 02:14PM
the nice part is, there's virtually no loose stuff. this was all 'repaired' with fresh steel right before going in for it's cage, or added as part of the cage.
February 09, 2010 05:22PM
Look around your garage and find the nearest can of spray paint and give it a quick coat as well as you can reach in there. Other than that don't worry about it. You'll roll your car into a little ball long before a significant amount of rust forms.
token-negro
Kendrick Gray
February 09, 2010 05:26PM
> rust forms.
+1
February 09, 2010 05:46PM
You know what would be cool. Smoke bombs that painted. That way you could just seal the bitch up, light the smoke bomb, and run. As long as it didn't smell like a smoke bomb anyhow.
February 09, 2010 06:02PM
> Edited 1 times. Last edit at Feb 9, 2010 by
> Daniel Buehler.
I would spray paint at what can be seen easily and ingnore the rest. As mentioned by that brute Dave the original, you'll likely ball it up years before that rust ever becomes an issue.
SEANT
SEAN TENNIS
SAAB 99, SAAB 96 850, SAAB 99T, SAAB V4
February 09, 2010 06:49PM
Zinc primer coating then rust prevention paint such as KBS coating or POR-15 or ?
If the car doesn't get balled up right away you might want to keep it around for a while and rust prevention is a way to help see to it! Both products can be brushed or sprayed, spraying gets places when a brush cannot ... If you're lacking spray equipment this kind of fix could be dealt with using a Pre-Val sprayer, less then $20 ...
These products go a long way, watch the video at KBS or youtube
As always IMHO
SEAN TENNIS KF7JJR
SEATTLE, WASHINGTON
SAAB 99, SAAB 850
SAAB V4, SAAB 99T
February 09, 2010 07:50PM
> Grant Hughes
> Denver, CO
Now yer talking! I'm picturing those old bug-bomb room fogger cans, but weld thru primer.
February 09, 2010 08:55PM
> SEAN TENNIS
> SEATTLE, WASHINGTON
> SAAB 99, SAAB 850
por15 goes on first
