mack73
Jason Wine
Re: Golf IRS
February 14, 2010 01:19AM
brianallmotor Wrote:
> WHOA! i was lookin thru the pics from SandBlast
> and this cought my eye. check out the rear
> tire.......
You mean the black smoke right?
TDI and the exhaust is routed to exit through the side behind the door
-Jason
Edited 1 time(s). Last edit at 02/14/2010 01:04PM by mack73.
Re: Golf IRS
February 14, 2010 10:47AM
gkd Wrote:
> Pete, the only reason that Honda and Toyota
> stepped down to this type of rear suspension was
> to reduce costs and compete with other OEMs price
> wise. One other benefit of the twist beam rear
> suspension design is that it takes less space and
> so trunk volume is usually better with this
> suspension.
Right. It's cheaper and offers more interior room in otherwise cramped vehicles. As I said, it took them long enough to realize the benefits.
No, it's not 100% perfect. It's an economy car, who cares?
brianallmotor
Brian R. Barton
Mazda 323 BP-T
Re: Golf IRS
February 14, 2010 05:44PM
nope. i mean the wheel off the ground.
Re: Golf IRS
February 14, 2010 06:49PM
"nope. i mean the wheel off the ground."
Standard VW rear suspension. Lack of travel.
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: Golf IRS
February 14, 2010 08:23PM
Is the 9+ inches of STOCK rear wheel travel not enough?
I think you meant to say something else related to roll center because travel is definitely not the problem.
One. Class -- 2WD
www.quantumrallysport.com
brianallmotor
Brian R. Barton
Mazda 323 BP-T
Re: Golf IRS
February 14, 2010 09:25PM
ohh my god. it's not the standard travel. it's dodge neon rear independent suspension on that TDI... i posted the picture to inspire posts like "maybe that neon stuff aint working" or "wow, that geometry is perfect."
whats the thoughts on how it's performing?
Edited 1 time(s). Last edit at 02/14/2010 09:31PM by brianallmotor.
Re: Golf IRS
February 14, 2010 10:10PM
If it is really that huge of an issue, why didn't they change it at VW Motorsport is my question.
turoc
Ozgur Simsek
working on a Veedub
Re: Golf IRS
February 14, 2010 10:41PM
> __________________________________________________
> _________
> Demon Rally Team :: Fine Tuning
> RalleyTuned | Meister Gauge Faces | Spitfire EFI |
> Product Apparel
> JVAB Imports | Techtonics Tuning | 034 Motorsport
> | Les Schwab
> Myspace or Facebook
> Next Event: Wild West Rally Sept. 26-27th 2009
Homologation?
brianallmotor
Brian R. Barton
Mazda 323 BP-T
Re: Golf IRS
February 14, 2010 11:28PM
pics of SE-R ? start the build thread. suspense is killing me.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: Golf IRS
February 15, 2010 02:06PM
M-sport's R2 fiesta also keeps the twist beam rear suspension.
Re: Golf IRS
February 15, 2010 02:57PM
Pure curiosity on my part since I don't drive or own any front wheel drive vehicles. Is the tuning for rally similar to FWD road racing cars where you add on a crap-load of rear roll stiffness with a huge rear swaybar to keep the front tires working as best as possible and help the car rotate?
If so...it a true IRS any advantage when the rear wheels are going to be locked together with a big (please note that "big" is a relative term since I understand the weight transfer will be much smaller on gravel than tarmac) rear swaybar?
-Tim
Re: Golf IRS
February 15, 2010 03:26PM
> suspension.
So does the Civic R3 from JAS, but they recently came up with an evolution for the tune of €17000, in where it basically splits the beam in the middle in order to have independent movement. Improvements on bumpy or broken terrain are reported to be astonishing and making the car competitive again against the Clio.
Andrew_Frick
Andrew Frick
Re: Golf IRS
February 15, 2010 04:06PM
Cosworth Wrote:
> rear
> > suspension.
Is this is the same suspension that the Touring car guys designed to get and independent suspension while keeping the stock mount points?
Re: Golf IRS
February 15, 2010 04:17PM
> rotate?
> -Tim
No, just the opposite. On the Omnis I always cut the rear sway bar off the GLH rear beams. You want to keep all the wheels on the ground for better grip. Too stiff in the rear and the car will be much too loose. You can make the car rotate just fine by left foot braking.
But really, the rear wheels on a FWD car are just there to keep the rear bumper off the ground. JV and I proved many years ago that you don't even need both rear wheels to go down a rally stage quickly.
Re: Golf IRS
February 15, 2010 05:00PM
> points?
That, I do not know. I just know so, cause Renault Sport mentioned it when I was there for some tests back in December.
