Roof Skin GD Impreza
Posted by token-negro
Re: Roof Skin GD Impreza
February 12, 2010 05:41PM
but that's 7 lbs at the very tippy tippy top of the car!!!....I bet that lowers the over all CoG by what...? what? .....anyone? winking smiley
February 12, 2010 08:04PM
7lbs that high up gives the road race guys wet dreams...
I've been in the room when this has been discussed by guys who weigh their cars by the ounce. But, they've spend 10's of thousands elsewhere to remove all the rest of the weight...
February 12, 2010 08:27PM
> dreams...
When you have pushed every other rule and dollar as far as you can...
When you have developed robot like consistancy...
When you can control the weather...
When you can control tire wear...
When you spend 20 hrs a week in a gym...
When you don't have a 250 lb co-driver...
When you haven't done all of the above worrying about 7 lb or even 70 lbs is really just mental masturbation for the average racer.
But carbon fiber panels do look awfully nifty until the UV rays get to them.
February 13, 2010 02:56AM
yeah....the quickest 30lbs I can lose in my car right now is in my driver's seat.....but only after I sit in it sad smiley
February 17, 2010 06:31AM
Holy shit! I just removed the hood from my gc project and even though I'd done it before I didn't remember what a utter PITA it was. I started with a spot weld drill bit but soon realized the heat from the spot wels had penetrated well beyond the edges of the little tiny dots so ended up using a step drill bit, making ginormous holes the size of nickels in a bazzillion places. Unless you're a body shop with some tricks I don't know, this is full on race car stuff ONLY!
February 17, 2010 07:13AM
> stuff ONLY!
> "this is certainly not a game for flyweights or
> ping-pong players-all arguments to the contrary"
> -C.B.
I just use a regular drill bit (a sharp one!) that's just a bit larger diameter than the spot weld. Maybe about 1/4" or so. I just drill through the first layer (the part you are removing) and do not dill all the way through the second layer. You end up making a little divot in the second layer but do not drill all the way through. You need something to weld the new spot weld to when you put on the new roof skin. Those fancy spot weld drill bits don't work very well in my experience.
February 17, 2010 07:19AM
Spot welds... Hood... huh?
You need to have a drill that goes really, really slow. I use those spot weld cutters all the time, thin metal and thick. I use "Goop" penetration oil as a lubricant (you get in in a spray can at CrapyT). I've never seen the metal change colour.
You need a good drill that can go slow (or a cheap drill you can kill the brushes on) before you try to do tho bobbins on your shell. You'll destroy the metal and the hole saw if your drill is going fast. I bought a cheap 1/2 drill from CrapyTire and just pulsed the triger. But, it started to smoke every 5-10 minutes and it took me about 15 minutes to drill each hole for the bobbins. 25 minutes each for the rear subframe - lots of layers in those rear frame rails...
February 17, 2010 07:22AM
I've got the blue point spot weld cutters, they've been great. But it does get tiring having to grind the spot weld dimples (left by the cutter) before re-welding things back in place.
token-negro
Kendrick Gray
February 18, 2010 11:55PM
Roof Pictures
open | download - WRX_roof_3net.jpg (64.6 KB)
open | download - WRX_roof_2new.jpg (72.1 KB)
open | download - roofinstallednew.jpg (33.5 KB)
February 19, 2010 07:11AM
so... I'm gonna go out on a limb and suggest that that has been layed 0-45-90, bagged, vacumed and baked?
February 19, 2010 08:27AM
That's a nice piece. Too bad it's not legal for rally, though.
token-negro
Kendrick Gray
February 19, 2010 11:23AM
The intresting is the one in the picture is headed to a Rally car team. Hummmmmm.
DR1665
Brian Driggs
Keyboard. Deal with it.
February 19, 2010 01:27PM
Token Negro is actually a white dude?
My whole world is shattered now.
And my inner ricer wants a carbon fiber roof sooooooo bad too.
token-negro
Kendrick Gray
February 19, 2010 03:41PM
> sooooooo bad too.
> Brian DR1665 | Phoenix, AZ
> 92 GVR4 - daily | 91 GVR4 - endless rally project
LMAO, no thats not me in the picture. LMAO that was funny.
February 19, 2010 04:07PM
Maybe they should read the rule book. Or maybe they are just knowingly disregarding it...
