I ran the single line in my car, with a prop valve next to the shifter. I also ran the -6 steel lines for fuel, did them all in a day, and they look great.
AN -3 bulkhead fittings, steel 3/16 brake line. the rear T is outside of the car, and the front T is in the engine compartment. Do purchase a nice double flairing tool, and make sure your stock subie fittings are not bubble flaired. Go to a napa or carquest and get some new fitting ends, they sell bulk brake line for $1 a foot or so. Do an AN bulkhead fitting at each corner, then standard -3 AN brake hose ends are a snap. Buy some AN-3 tube ends and tube sleeves, put them on the tube and flare to standard auto angle, it will seal just fine. for anything bigger than -3 you need an AN 37 Degree flare tool. Good luck |
eyesoreracing Dave Coleman Mega Moderator Location: Long Beach, CA Join Date: 05/13/2007 Age: Possibly Wise Posts: 448 Rally Car: Mazda3, SE-R Spec-V, 510 |
This is on Goodridge PTFE lines:
Stainless Braided PTFE Hose – First recordable data at 0.010% (0.0002932cc/ft) @ 4000 PSI Sorry, here's the source. http://bin.motorarte.com/marcas/goodridge/Goodridge_TechReport.pdf Grant Hughes Edited 1 time(s). Last edit at 02/23/2010 05:54PM by NoCoast. |
KTurner Kevin Turner Mega Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
I had a hill hold in my impreza. just went to the u pull it and took a drivers front hard line from a non-hill hold car and it went right in. If you can get metric replacement lines it was only 18-24" long if that; straight down off the MC then up and around to the mount.
-KTurner Stomp down on the exhilarator and hold on to the wheel. |
Cosworth Paulinho Ferreira Super Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
------------------------------------------------------- > This is on Goodridge PTFE lines: > Stainless Braided PTFE Hose – First recordable > data at 0.010% (0.0002932cc/ft) @ 4000 PSI > > Sorry, here's the source. > > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO > > > > Edited 1 times. Last edit at Feb 23, 2010 by > NoCoast. That article is from an unknown source for sales purposes of Goodridge brakes hoses, no sizes are given, nor conditions of the test. That being said, here at work we use Goodridge hoses on all brake kits we sell, so being a ISO and TS certified we have to test all that crap. I can get data from the QA engineer but of the top of my head I know that the hoses dont take 4000PSI, not even close. As a matter of fact, they start leaking at the fittings just under 2000psi. Independently of what it says, I work with these things everyday, the difference is not just in feel, you can actually see them move. Plus braided is more expenssive, so its a double wammy. Stainless steel polished hardlies with stainless AN fittings and -2 hoses to the calipers. Porn! ![]() |
david amor david amor Junior Moderator Location: Stoney Creek Ontario Join Date: 03/22/2006 Age: Possibly Wise Posts: 458 |
Signor Paulo,
Why are we down to -2 now? I THINK I'm with you on the hardlines although I cannot FEEL any difference whatsoever beetween hardlines and braided on a car with a single master with no booster. Maybe it'll be more apparent on this next car which will have proper dual masters. Is there a reason you can't say where you work BTW? (not being confrontational, just curious since you have some serious brake knowlege) Gone fishing |
Cosworth Wrote:
------------------------------------------------------- > john vanlandingham Wrote: > -------------------------------------------------- > ----- > > I have never understood the "rip everything > out" > > and then re-do 85% the same as it just was > > mentality. > > Thats hoping that they're not going with the loony > idea of putting -3 braided or even worse -4. But > the reason to rip it all out is to maybe re-route > them inside the car cabin. Always wonder why circle track catalogs are full of -4 stuff.... But you know that last time i bought an ex-works Ford sierra Cosworth chassi number MS9000007 it was -3 hard lines and -3 flexie lines to the calipers. What's changed about hydraulics that -2 is the new thing? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Well the -2 thing is because it has less volume. Less volume = less fluid to compress yadda yadda yadda. Its really not a big difference unless you're doing extenssive datalogging like say... in ALMS or even Grand Am.
The circle track guys are most "bubba" you'll ever find. I mean some of those idiots run 2 different compound pads on the front corners with a more agreesive pad in the left. Some even go as far as having smaller pistons on the right front to help the car turn. Stupid *headshaking* But even though they're a bunch of knuckle heads I never seen one of those cars with -4 besides on the oil or fuel lines. Senhor Amor, I'm an engineer and work in the motorsport scene, and deal with brake stuff every single day. |
Ok I'm gonna do hardline in the current car except from the wheel wells to caliper and maybe where the lines attach to the hydro handbrake.
I've asked this before but I need to be sure since I can't be trying out a bunch of MC's till I get it right. The brakes I'm using use 4 (need to confirm for 100% certainty) 40.6mm pistons front and 2 38.1mm pistons rear. I need to know what size masters and pedal box ratio is optimum. I'll likely use Wilwood stuff since it's commonly available and "good enough" Gone fishing |
Ok I can tell you exactly torque values and bias but first I need to know the diameter of the discs and the swept area (radial depth) of the pads. Or just tell me what what calipers they are and I'll figure out what pads it takes.
Are you going to run a floor mount pedal box, underdash, or remote mount? -PF |
token-negro Kendrick Gray Mega Moderator Location: Renton, WA Join Date: 04/20/2009 Age: Midlife Crisis Posts: 176 |
If you are replumbing the subaru, the hard lines will be 3/16ths the flares on the master are 45 inverted. The tube nuts are easy to find on the Ebay they are M10x1.
Im finding using stainless 3/16 line is more difficult to work with then the steel stuff so you might want to just rock the stuff from Napa and cut off one end when you have to. THe rest of the bulkheads etc I would use would be 3an Steel stuff tube nuts, and sleeves. |
This just seems like a good place for this:
http://nocoastmotorsports.net/Build/Resources/designing_4_pot_brakes.pdf I don't doubt that in reality there is some pressure loss. Just as Dave Anton said over on specialstage, it's not a ton and -3 braided lines are super easy to build, especially if they get the thing from summit that spreads the braids. I think I did all of the brake lines in my car in around 2 hours at most. It will cost probably double to do so. In a Subaru, stick to reusing stock lines. Already inside the car! Why are you not plumbing in a hydraulic handbrake Daniel? They're cheap to buy or can be fabricated pretty easily. Grant Hughes |
Daniel Buehler Daniel Buehler Godlike Moderator Location: Beeton, Ontario, Canada Join Date: 01/08/2009 Age: Midlife Crisis Posts: 246 Rally Car: 94 Subaru Impreza, AWD, No Power! |
------------------------------------------------------- > Why are you not plumbing in a hydraulic handbrake > Daniel? They're cheap to buy or can be fabricated > pretty easily. > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO I figured that when people say that I've overbuilt my first car, I can say "What! I don't even have a hydro handbrake!" ![]() I'm not in a hurry because it's an extra $100 or more that can wait for later. I've got a 5spd and probably 120hp. The handbrake locks all four wheels and I don't really have the power to pull out of a slide anyhow... |
