corner weighed the car today
Posted by phlat65
March 25, 2010 10:40PM
My co-worker brought his scales in today, so I set the corner weights. Here is where I started:
LF 762 RF 733
LR 661 RR 696
Cross weight 48.9%, 52.4% front 47.6% rear
After 2 adjustments at the rear, here is the final weight:
LF 747 RF 750
LR 680 RR 680
Cross weight 50% side to side 50% Front 52.4% rear 47.6%
Car weighs 2856lbs with all rally equipment, spare, tools, spill, first aid, triangles, extinguishers, Light bar ect, and 1/2 tank of gas.
That was a great experience. I lowered the rear spring perches about 1 inch, but the ride height only changed 1/4 inch. I am going to lower the rear spring rate from 175lb/inch to 150lb/inch to get the rear a little lower, and help the car squat more under acceleration.
Re: corner weighed the car today
March 25, 2010 10:46PM
What happens to the weights when a couple of dudes sit in the seats? Or are those weights with dudes?
March 25, 2010 11:27PM
My co-driver is 20lbs lighter than me, and the fuel tank carries more fuel on the co-drivers side, so I was not too concerned with that, and the seats are within an 1nch of being exactly half way between the front and back wheels
March 25, 2010 11:52PM
mothra
Matt Smith
xr4ti
March 26, 2010 08:15AM
I am interested to hear what you think of the 150 lb rear springs on the merkur. I have been really happy with 175 lb on mine so far. Seems to squat nicely for me.
Matt Smith
March 26, 2010 09:26AM
what are your ride heights set at?
March 26, 2010 10:19AM
Nice. About the same distribution I have, but I was around 200 lbs lighter when I weighed mine, but no clue on fuel, no spare tire, no light bar, and lexan windows. I removed another 40-50 lbs or so from the bottom of the car with spot weld removal and undercoating removal. Have a few more brackets I still need to cut off from the bottom as well.
March 26, 2010 10:24AM
Whew!
My Cossie 4x4 thing with no sump guard and OEM front seats weighed 2720.
I think I'm going to get Sean some 100-125 lb/in "helper' springs for the initial compliance thing. Some of Ford's progresssive rears had an initial rate at around 100-125.
Worth a try.
March 26, 2010 10:27AM
> Whew!
Has anybody weighed those OEM XR4 seats? I think they're about 50 lbs each!
March 26, 2010 10:52AM
fiasco Wrote:
> john vanlandingham Wrote:
> > Whew!
> OEM
Yeah, thassa whats I's stinking, maybe 45lbs and so say we dump them and add a substantial sump gaurd we might be in the same place, so 2720 for 4x4 powertrain and full cage and stitch welding...
How?
> Andrew Steere
> Lyndeborough, NH
> KB1PJY
mothra
Matt Smith
xr4ti
March 29, 2010 11:57AM
No clue of the top of my head....I will measure it when I get home.
Matt Smith
C LePoudre
C LePoudre
G2 VW Golf
March 30, 2010 12:07PM
I find this very interesting, but admit I don't know what the targets should be. Does it matter if it's FWD/RWD/AWD? Where can a fellow (or lass) look up information about this. I'm guessing based on your information that you are targeting 50/50, 50/50?
Thanks, and please accept my apologies for my ignorance on this topic but I'm all about learning.
Chad.
March 30, 2010 02:37PM
Main goal is to get the daigonal weights equal, so the car handles the same entering left or right turns. As little as a 2% split can affect handling, but i will admit i am not good enough to tell probably. Second goal was to know what each wheel is supporting so I can make educated spring rate choices.
March 30, 2010 04:03PM
If you are really getting fancy and building your own 4 link rear, knowing the center of gravity can be used for suspension points to set up anti-dive and anti-squat, I think...
March 31, 2010 09:35AM
> rate choices.
In all honesty, I find that I drive the car diffently entering a right hand turn. I think that on a subconcious level, I'm aware that the trees are farther away entering a left hand turn and I'm more likely to pitch it and pin it.
