Anyone have experience with superchargers and blow through with external wasting?
Posted by hudson
Re: Flow Graph & Calc'ed Req's
April 20, 2010 09:30AM
with the turbo helping to achieve more than 100 percent volumetric efficiency, with no extra load on the crank, how will that cause drag through back pressure?
I remember reading the SAE papers on the Corvair, during the cooling testing, they found that the system needed 2.3 PSI of pressure acting on the cylinder fins to be most efficient, and that flow volume was not as important.
hudson
Andrew McNally
April 20, 2010 10:09AM
> back pressure?
My limited understanding is that there is a pumping loss in turning the turbine. Obviously at the end of the day it's a net positive.
That's interesting... I could waste into a pressurized vessel around the cylinders and then bleed from there. I will have to look into that.
Andrew M
Onterrible
30ish
hudson
Andrew McNally
Vacuum actuator hooked up to a throttle body?
May 12, 2010 03:10PM
Something like this seems to be a possibility to solve snap off throttle and part throttle.
As for boost limiting..
http://www.928m.com/parts/boostlimitervalve.php
Now those are crazy over priced, I could get some made cheaper.. but know you can source similar for around $30.
Andrew M
Onterrible
30ish
