kaiser sosa Wrote:
> Dude, you don't have to cut the floor. Peel up the
> sound deadening crap if it's still on there and
> you'll see a circular plug, pry that out. Drill up
> from the bottom with a 12mm bit, go get the
> strongest 12mm bolt you can find just long enough
> to go all the way up without protruding through
> the floor line where you pulled the plug out get
> two nuts and a couple large washers wrench it down
> tight and jam-nut it from the top then cut a
> circular piece of sheet metal 1" larger than the
> plug hole and screw it back down to cover
> everything up.
> That's how I did mine.
> I can get you pics if you need.
Hmm, kinda sounds like you're just bolting to a convenient piece of sheetmetal there. No good, especially for a rally car. The captive nut has at least a bit of reinforcement. The best way to go is a bobbin, the second best is to replace the captive nut, the third best is the bently way, after that you could randomly drill holes and bolt sheetmetal to sheetmetal, but it won't last long on stage.
