jamesp
james phillips
Volvo 242 GT (in progress)
B21FT turbo recommendations?
April 30, 2010 04:00PM
I'm going to be picking up a B21FT from fellow Volvophile Matt Miller, and word has it, it needs a new turbo.
The motor has an IPD turbo cam, stock ECU, etc. Is there a favorite, or "right" blower for this beasty? It will likely be my gp5 motor, asumming I eventually blow up the really nice gp2 one that John's building for me. Otherwise, it will be gratuitously swapped into a wagon or something winking smiley
Looking at Matt's notes, it looks like it currently has a 16G turbo fitted, and the motor itself came from a K.C. car and was recently rebuilt.
james phillips
Volvo 242 GT (being built...)
Scooby killing 04 Dodge Neon SRT Rallycross monster
Lincoln, NE
Re: B21FT turbo recommendations?
May 01, 2010 12:04AM
I am still at the bottom of the learning curve on turbos, but I think 16G is kinda huge, was this one of those turbobricks.com drag racing motors that starts to spool at 3500 rpm? I have a pile of turbos that might be more rally flavor.
jamesp
james phillips
May 03, 2010 03:19PM
Should I call? We could discuss turbos. I'm driving down to Wichita Saturday night to pick everything up, I'll be back on Sunday with an inventory and pictures.
james phillips
Lincoln, NE
May 03, 2010 03:59PM
gt3071r or gt3076r would be my pick of the garrett bunch.
But I'd get a s252 or s256 BorgWarner cos I like them better.
Edited 2 time(s). Last edit at 05/03/2010 04:03PM by pikespeakgtx.
May 03, 2010 04:50PM
> bunch.
> them better.
> Michael LeCompte
> Edited 2 times. Last edit at May 3, 2010 by
> pikespeakgtx.
All of those turbos are a bit big for a gravel car.
May 03, 2010 04:58PM
The open class Tiburon's ran the 3071. But that was a full open class car capable of the tuning and testing to get it to work well. The 28 series stuff is probably better suited to privateer level.
May 03, 2010 05:30PM
I like the fact that the 30 series is t3 exhuast side. Not a fan of the t28 housings.
They come in assorted trims. But yeah they are on the big side for sure on a gravel car.
The motor is 2.1 liter, I figured it be enough displacement to spool the 3071r.
On the smaller end, you've got the gt2560rs (T25 exhuast side),the gt2860r and the gt2871r and gt2876r.
See the pattern? The begining is the code for the exhuast housing. gt28=t28 gt25=t25, gt30=t3. The end part is the compressor side in MM.
Edited 2 time(s). Last edit at 05/03/2010 05:33PM by pikespeakgtx.
May 03, 2010 06:01PM
I've seen the GT2860RS with T3 exhaust housings before.
May 03, 2010 06:09PM
> before.
> Grant Hughes
> Denver, CO
Even better ATP now has a T3 twin scroll housing for even faster spooling if you make a proper manifold for it.
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-102&Category_Code=GTH
Edited 2 time(s). Last edit at 05/03/2010 06:11PM by Tim Taylor.
May 03, 2010 06:15PM
Like this beautiful but uber-expensive unit for the Merkur...
http://www.bo-port.com/index.php?act=viewProd&productId=14
May 05, 2010 03:15PM
Tim Taylor Wrote:
> housings
> > before.
> > Grant Hughes
> > www.nocoastmotorsports.net
> > Denver, CO
> manifold for it.
> Edited 2 times. Last edit at May 3, 2010 by Tim
> Taylor.
That's new! Cool, so you could swap between 2860,2871,2876 CHRAs w/ T04b compressor housings if they have 53.8(76 trim) wheels and use the same exhuast housing. That's really neat. You could have 60mm,71mm, and 76mm on the shelf if you were so inclined.
So the A/R on the exhuast side there on the twin scroll is .82, They also make .64 and .48 on the gt2871r but not twin scroll...
Though it is twin scroll it's got a large a/r ratio, so it would be interesting to see spool comparisons and the top end hp comparisons on the smaller A/R turbos without twin scroll.
Edited 2 time(s). Last edit at 05/05/2010 04:35PM by pikespeakgtx.
DJackson
Dawud Jackson
Watching from the sidelines
May 25, 2010 01:15AM
Any reason you opposed to the Stock Volvo or marginally larger XR4Ti Journal bearing T3? Kind a plus it bolts up to the stock manifold and wont' cost a fortune to rebuild or replace if you blow the thing up! Maybe even get a Cossie style housing for it? I got one on my XR4Ti and like it alot, got the whole turbo for $60 bucks! I get boost under 3 grand where it counts.
Name: Dawud Jackson (DJ)
Occupation: Computer dude.
jamesp
james phillips
May 25, 2010 07:46AM
there's nothing wrong with (IMHO) with using a stock turbo, I'm just looking for feedback smiling smiley
james phillips
Lincoln, NE
May 25, 2010 08:07AM
> james phillips
> monster
> Lincoln, NE
Cossie turbo on a flat milled manifold.
Best damn all around compromise.
Get a 4x4 one for a little more upgrade on the compressor side than the 2wd is.
I guarantee you'll love it.
jamesp
james phillips
May 26, 2010 02:37PM
So, where would I find a working Cossie turbo? (bet you got one in your pile o'parts smiling smiley)
james phillips
Lincoln, NE
