MkII Escort Porn
Posted by Andrew_Frick
wildert
Brian Klausen
VW Golf GTi 16V
Re: MkII Escort Porn
May 29, 2010 05:40PM
> Pete Wrote:
> > wildert Wrote:
> > 2.4 is not a factory size. Basically, every
> Ford
> > product from about 2003-on that had a four
> > cylinder, as well as many, many Mazdas, used
> a
> > 2.0, 2.3, or 2.5l Duratec.
> Come on Pete, a mere typo, 'sides he's one a den
> Veee Dubya guys so can't 'spect him to pay
> attention to Ford?mazda motors---he'd get too
> depressed if he did!
Heh - I'm kinda not into anything new anyways - except for diesels. And that's only for the chore as a daily. Actually own a Ford as a daily - 2005/2006 Mondeo Estate - but the 130 horsie turbo-diesel. Great tow vehicle by the way - at least in flat Denmark anyway.
> > > What's so special about the column?
> > Electric assist. You can see the motor on
> the
> > right side.
Seriously - looked for it, since I figured it had to be something like it - haven't noticed it.
> Opel Corsa stock since what 5-7 years?
Something like that - yeah.
> > > Anyway - with regards to the never
> > electrically
> > > assisted columns, then that has been
> done
> > quite a
> > > few times. Apparently not too
> complicated.
> > Opel
> > > Corsa/Vauxhall Nova columns have been
> grafted
> > in
> > > to Mk I and Mk II Golf's several times
> in the
> > UK.
> > > ... and those columns are fairly cheap
> on
> > fleaBay.
> > Again, essentially all small- and mid-size
> General
> > Motors cars here from 2007 or so on have
> electric
> > assist on the column. A lot of other makes
> are
> > using a motor on the rack, which makes life
> easier
> > on the steering U-joints. GM had problems
> with
> > steering shafts even before they decided to
> move
> > the assist to the column...
Well - what I failed to mention - and this was the reason to bringe the Corsa rack up (I was typing it up in a hurry - that's what you get for having your head full of too many things) - is the thing about the black box you mentioned. Apparently it isn't much of a big deal with the Corsa ones. Opel being GM and all that, I would suspect that it would be the same with the US GM models. I've read about quite a few guys - not particularly electronics savy - rigging up something to adjust the assist, or have two levels. So no need to wait for some mysterious black box - it shouldn't be too complicated.
> > Pete Remner
> > Cleveland, Ohio
> > 1984 RX-7 (rallycross thing)
> > 1978
> > Silence is golden, but duct tape is silver.
> > Edited 1 times. Last edit at May 29, 2010 by
> Pete.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.rallyrace.net/jvab
> CALL +1 206 431-9696
> Remember! Pacific Standard Time
> is 3 hours behind Eastern Standard Time.
Brgrds
Brian
May 29, 2010 09:03PM
> On what planet are rods and sometimes pistons NOT FAILING?
The naturally aspirated, automatic grocery-getter Focus/Escape planet.
I'm not saying that they don't need work for performance use, but at least they're available easily enough.
The US models equipped with it are new enough that it's tied in with everything. I understand that there are tricks for getting a PCM to run without the data network, but it's not as simple as "connect these wires to power/ground". That's a PCM, though. I don't know if the assist control is its own unit or if it is part of a different module. (Hell, you can't even swap radios anymore, they're part of the network)
So the simplest way would be an aftermarket controller, or maybe something from a European car that isn't computerized to the point of uselessness.
You've got to understand - there seems to be a large anti-Euro thing going on at GM. European designs are used only grudgingly, and usually after a LOT of cost cutting. DeLorean called it the "Not Invented Here" syndrome - we didn't design it, so why should we care if it lives or dies? (Fortunately, this doesn't seem to be the case at Ford)
Edited 1 time(s). Last edit at 05/29/2010 09:06PM by Pete.
1fastben
Ben Hetland
None, right now
May 31, 2010 06:48PM
THAT is one killer old tractor, not to mention the packer in tow!
Ben Hetland
1973 Volvo 142 project car (with some cone-smashing on dirt in it's future, however)
"No. Rally Racing is a back alley sport filled with jackals, headhunters and thugs!"
-Pops Racer (Speed Racer movie)
www.utahrallygroup.com
May 31, 2010 08:08PM
meh, gratuitous use of carbonfibre...
