wildert Brian Klausen Junior Moderator Location: Denmark Join Date: 03/21/2006 Age: Midlife Crisis Posts: 388 Rally Car: VW Golf GTi 16V |
------------------------------------------------------- > Pete Wrote: > -------------------------------------------------- > > wildert Wrote: > > -------------------------------------------------- > > 2.4 is not a factory size. Basically, every > Ford > > product from about 2003-on that had a four > > cylinder, as well as many, many Mazdas, used > a > > 2.0, 2.3, or 2.5l Duratec. > > > Come on Pete, a mere typo, 'sides he's one a den > Veee Dubya guys so can't 'spect him to pay > attention to Ford?mazda motors---he'd get too > depressed if he did! Heh - I'm kinda not into anything new anyways - except for diesels. And that's only for the chore as a daily. Actually own a Ford as a daily - 2005/2006 Mondeo Estate - but the 130 horsie turbo-diesel. Great tow vehicle by the way - at least in flat Denmark anyway. > > > What's so special about the column? > > > > Electric assist. You can see the motor on > the > > right side. Seriously - looked for it, since I figured it had to be something like it - haven't noticed it. > Opel Corsa stock since what 5-7 years? Something like that - yeah. > > > > > Anyway - with regards to the never > > electrically > > > assisted columns, then that has been > done > > quite a > > > few times. Apparently not too > complicated. > > Opel > > > Corsa/Vauxhall Nova columns have been > grafted > > in > > > to Mk I and Mk II Golf's several times > in the > > UK. > > > ... and those columns are fairly cheap > on > > fleaBay. > > > > Again, essentially all small- and mid-size > General > > Motors cars here from 2007 or so on have > electric > > assist on the column. A lot of other makes > are > > using a motor on the rack, which makes life > easier > > on the steering U-joints. GM had problems > with > > steering shafts even before they decided to > move > > the assist to the column... Well - what I failed to mention - and this was the reason to bringe the Corsa rack up (I was typing it up in a hurry - that's what you get for having your head full of too many things) - is the thing about the black box you mentioned. Apparently it isn't much of a big deal with the Corsa ones. Opel being GM and all that, I would suspect that it would be the same with the US GM models. I've read about quite a few guys - not particularly electronics savy - rigging up something to adjust the assist, or have two levels. So no need to wait for some mysterious black box - it shouldn't be too complicated. > > > > Pete Remner > > Cleveland, Ohio > > > > 1984 RX-7 (rallycross thing) > > 1978 > > Silence is golden, but duct tape is silver. > > > > > > > > Edited 1 times. Last edit at May 29, 2010 by > Pete. > > > > > John Vanlandingham > Sleezattle, WA, USA > > Vive le Prole-le-ralliat > > www.rallyrace.net/jvab > CALL +1 206 431-9696 > Remember! Pacific Standard Time > is 3 hours behind Eastern Standard Time. Brgrds Brian ![]() |
> On what planet are rods and sometimes pistons NOT FAILING? The naturally aspirated, automatic grocery-getter Focus/Escape planet. I'm not saying that they don't need work for performance use, but at least they're available easily enough. wildert Wrote: > > Well - what I failed to mention - and this was the > reason to bringe the Corsa rack up (I was typing > it up in a hurry - that's what you get for having > your head full of too many things) - is the thing > about the black box you mentioned. Apparently it > isn't much of a big deal with the Corsa ones. Opel > being GM and all that, I would suspect that it > would be the same with the US GM models. The US models equipped with it are new enough that it's tied in with everything. I understand that there are tricks for getting a PCM to run without the data network, but it's not as simple as "connect these wires to power/ground". That's a PCM, though. I don't know if the assist control is its own unit or if it is part of a different module. (Hell, you can't even swap radios anymore, they're part of the network) So the simplest way would be an aftermarket controller, or maybe something from a European car that isn't computerized to the point of uselessness. You've got to understand - there seems to be a large anti-Euro thing going on at GM. European designs are used only grudgingly, and usually after a LOT of cost cutting. DeLorean called it the "Not Invented Here" syndrome - we didn't design it, so why should we care if it lives or dies? (Fortunately, this doesn't seem to be the case at Ford) Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 05/29/2010 09:06PM by Pete. |
1fastben Ben Hetland Ultra Moderator Location: Utah Join Date: 09/12/2007 Age: Settling Down Posts: 297 Rally Car: None, right now |
THAT is one killer old tractor, not to mention the packer in tow!
Ben Hetland 1973 Volvo 142 project car (with some cone-smashing on dirt in it's future, however) "No. Rally Racing is a back alley sport filled with jackals, headhunters and thugs!" -Pops Racer (Speed Racer movie) www.utahrallygroup.com |
