Conangelo asked:
June 23, 2010 07:52PM
Mike said someplace:
Hi.
I'm going through a Sentra rally car that I recently picked up and I'm planning on replacing all of the wheel studs as part of preventive maintenance.
Which wheel studs and lug nuts do you recommend for rally racing? I'm assuming that closed-end lugnuts are a must to avoid contaminating the stud threads. Any particular stud length? Any preferred vendors?
Thanks in advance!
Annswer:
Bugpack 2.2" long M14x 1.5 studs available in Sea-tac on Hiway 99 a few blocks South of 188th at the VW place on the left side of the road.
Nuts. M14 nuts, I have 200 or so here.
Note, why ask over at that other place?
Re: Conangelo asked:
June 23, 2010 08:22PM
Does anyone know if anyone makes those spiffy stock car style double-cone lug nuts in 14x1.5?
June 23, 2010 08:29PM
Sorta boubt it.
Somehow I've just barely managed to surviver with plain old VW bus nuts since 1988 or so....
What the fuck you need double ended nuts for??
> Pete Remner
> Cleveland, Ohio
> 1984 RX-7 (rallycross thing)
> 1978
> Silence is golden, but duct tape is silver.
June 23, 2010 09:27PM
You can't put them on backwards, is all, so that means three less brain cells needed when you're slamming the wheel on. Not strictly necessary but it's a nice feature.
June 23, 2010 11:18PM
Get real.
June 24, 2010 12:23AM
> Hi.
> maintenance.
> vendors?
> Thanks in advance!
> Annswer:
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.rallyrace.net/jvab
> CALL +1 206 431-9696
> Remember! Pacific Standard Time
> is 3 hours behind Eastern Standard Time.
> Pete Remner
> Cleveland, Ohio
> 1978
> Get real.
> John Vanlandingham
> Sleezattle, WA, USA
lolz
Edited 1 time(s). Last edit at 06/24/2010 12:24AM by Dazed_Driver.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
June 25, 2010 02:10PM
I have had very good luck with ARP wheel studs. Just measure the knurl diameter and they should make one that fits your car. The Focus used the same studs as a mid 90s GM F-body so they are super cheap.
June 25, 2010 03:42PM
> super cheap.
Why not upgrade to what is known to be the gravel rally standard M14?
I am an ARP dealer so sure if there was a compelling reason to stick with the street car size, like class restrictions but if the rules allow, why not something enormously stronger, especially if it is qood quality and cheaper??
At some point it seems wise to incorporate the knowledge that some have made efforts to dig up and disseminate.
DR1665
Brian Driggs
Keyboard. Deal with it.
June 25, 2010 05:34PM
How often do rallyistas lose wheels due to broken wheel studs?
M14 sounds like a stud diameter to me. Anyone know sizing on stock Mitsu studs?
When does one start considering ARP hardware for this, that, and the other?
brianallmotor
Brian R. Barton
Mazda 323 BP-T
June 25, 2010 08:50PM
?? why wouldn't you
if you do anything with a head on a motor, throw some ARP crap at it while you are in there. it sucks to have an overheating motor cause you assembled it with used stretched headbolts and saved $30.....
we use ARP wheel studs on our mazda... bigger brakes lead to wheel spacers which lead to longer wheel studs......
June 26, 2010 01:50PM
> wheel studs?
I can think of several times.
Want to find out what it's like?
They are likely M12
Well when it comes to studs seems some people do it just for the longer studs and the security blanket of having spent money.
Rod bolts, sure since OEM are usually more expensive, and unknown quaility---ie they themselves usually say replace after 1 use.
Head studs---depends on the OEM things price---maybe it's just as smart to replace every time---cause how often are you rebuilding the motor??
Flywheel bolts, naw, they aren't that stressed and OEM are usually good, but maybe check price. I use a Mercedes flywheel bolt on all the Fords I build, costs less than Ford and is a nicer fastener.
Main caps--no OEM is fine on the stuff I build.
As for these wheel studs, I've used the Bugpack studs on lots of vehicles since 1988 with never a problem, they are bigger and since I see all serious rally cars using 14mm I figure WHY NOT go bigger?
The have a nubbin or "lead" and a compact head so clearence is good and the nut is guided on---never cross thread...
> Brian DR1665 | Phoenix, AZ
> 92 GVR4 - daily | 91 GVR4 - endless rally project
DR1665
Brian Driggs
June 27, 2010 12:58PM
brianallmotor Wrote:
> ?? why wouldn't you
Well, I was coming from a place of must-have vs nice-to-have.
I've used ARPs on heads for years, but have I gone ARP-crazy and got their studs for intake and exhaust manifolds, flywheels, bumpers, radio installs, and wheel studs? Nope.
I suspect that these studs fall on the nice-to-have list. I'd say, after the clutch, brakes, suspenders, brake lines, and maybe tuning are taken care of.
Lose a wheel? Eat a little crow, endure a little I-told-you-so, and then order 'em up.
Don't get me wrong, I see the value and would love to get some, but I'll pass for the same reason I'm passing on the dual brake masters, steering quickener, and whatnot.
/making the transition from keyboard rallyist to casual, I-like-to-go-fast-on=dirt kinda guy.
June 27, 2010 08:04PM
> motor??
The OEM bolts on a lot of things ARE one time and throw away use.
You can feel the bolt deforming as you tighten it. My favorite are the super long head bolts VW uses nowadays. The torque is something like 55 ft-lb plus 180 degrees, and when you do the 180 degrees you don't feel the bolt getting "tighter" at all, the torque you feel at the wrench stays constant.
I did an older Mercedes flywheel once (Euro 280SE, neat car) and even that old thing had bolts that stretched noticeably when torqued. Scary.
June 29, 2010 06:13PM
aint plastic deformation a bitch?
MikeColangelo
Michael Colangelo
Spec Miata
July 01, 2010 07:54PM
> Hi.
> maintenance.
> vendors?
> Thanks in advance!
> Annswer:
> John Vanlandingham
> Sleezattle, WA, USA
Great! Start a thread about me and I don't even get an invite! The nerve! winking smiley
As it turns out, I recently bought 60mm NISMO M12x1.25 studs and Gorilla nuts so I think I'm covered in this area. Too bad I didn't see this thread earlier. Admittedly, I do spend more time at the other site.
VW place in SeaTac? I live in SeaTac!
