Axle pin alternatives?
Posted by biggreen96
biggreen96
Chris Caylor
Old Legacy- not very stock.
June 26, 2010 07:54PM
I hate these things with a passion. Does anybody do away with them in favor of something faster to remove and install? Bolt and nut? Zipties? A Twig?
Brap Brap.
EricW
Eric Wages
2002 WRX
Re: Axle pin alternatives?
June 26, 2010 08:08PM
Safety wire?
June 27, 2010 06:40PM
I don't think this is what they're made for, but I thought of these:
http://www.pegasusautoracing.com/productselection.asp?Product=3050
June 27, 2010 06:45PM
5 seconds to tap out the pin takes too long?
biggreen96
Chris Caylor
June 27, 2010 07:47PM
Mine NEVER seem to come out in 5 seconds. I spent 20 mins on one yesterday. My subframe brace doesnt help either.
Brap Brap.
June 27, 2010 07:50PM
They aren't there for load, just to keep the axle from sliding outwards and off the splines. So you could use safety wire or even a smaller diameter pin and a couple wraps of tape to keep it in place. A bonus with the smaller pin or wire is the axle could be installed 180* out then. Much easier in a hurried service.
June 27, 2010 07:52PM
> help either.
http://www.matcotools.com/Catalog/toolcatalog.jsp?cattype=T&cat=2262&page=1&#56191
LT730.
5 seconds is generous.
biggreen96
Chris Caylor
June 27, 2010 08:15PM
You are a god.
Brap Brap.
June 27, 2010 09:18PM
That looks way easier than using drill bits. It's kinda sketchy when they break.
June 27, 2010 10:25PM
Pete Wrote:
> spent
> doesnt
> > help either.
> LT730.
> Pete Remner
> Cleveland, Ohio
> 1984 RX-7 (rallycross thing)
> 1978
> Silence is golden, but duct tape is silver.
I have these: http://www.harborfreight.com/5-piece-long-drive-pin-punch-set-93111.html
and use the 3/16, its just a smidge smaller than the 5mm that the roll pins probably are. No magnetic tip, though.
biggreen96
Chris Caylor
June 27, 2010 10:48PM
No, I'm going for the subaru tool. I've fucked enough 3/16 punches to spend $$ on one again.
Brap Brap.
June 28, 2010 02:21AM
I recommend replacing that time-consuming roll-pin with six bolts per axle, preferably the kind with 12-pt triple-square EZ-Strip heads that are strategically designed to trap any dirt and grease in the nearby vicinity.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 28, 2010 09:18AM
Carl S Wrote:
> I have these:
i use the same set. works awesome. big one to bang it out and then slideit over the smallone to put it back in.
that matco part looks cool too.
EricW
Eric Wages
2002 WRX
June 28, 2010 12:07PM
For pushing the roll pins out on my subie, I just use an appropriately-sized torx head screwdriver where the body is the diameter of the pin and the head fits inside of the pin. It's got a nice shoulder and therefore good bite.
Zero problems.
June 28, 2010 12:16PM
You forgot to mention tearing the boot when the 12pt slips...
