mack73
Jason Wine
Re: New engine option for RWD rally cars
July 08, 2010 11:33PM
Dazed_Driver Wrote:
if I could do it again, I'd be building a golf,
> focus, or CRX.
Man grass is always greener. If I were to be doing it again, I'd be going RWD, probably a E36 or Volvo.......
-Jason
July 09, 2010 08:59PM
Picked the car up from getting its shiny new header today...ready for the turbo soon.
July 09, 2010 09:43PM
drool
I'm loving how the 4age sounds at 8k. I can't wait to hear this set up. In the woods or not.
You continue to impress and inspire Tim. Keep it up
Zap zap my ass...
July 09, 2010 11:17PM
Nice looking header. Whats the dogbone shaped fabricated tube at the end of the head?
July 10, 2010 10:47AM
> Feisty Peacock?
That's part of the unfinished mounting of the engine. It's also going to be part of holding up the twin-scroll Mitsubishi turbo Dave wants on the car. That's why the primary tube pairing looks so weird.
hudson
Andrew McNally
Way to think outside of the box
July 10, 2010 12:38PM
This seems like a no duh idea, I bet there's lots of people wondering why they hadn't thought of this before. Seems like the best way to solve the torque, rpm, & reverse problem.
You simply can't do a comparable automotive engine that light for that money.
Andrew M
Onterrible
30ish
Jay
Jay Woodward
'90 Mazdog Frankenprotege
Jay
July 10, 2010 02:27PM
I'm still wiggin out about how the hp and tq curves are that much higher than the miotter ones....no wonder bigbore crotchrockets are so goddamn fast.
Jay Woodward
Snohomish, WA
Chronologically, 46...
July 11, 2010 02:01AM
Well, for perspective, the 160-odd HP 1000cc in a ZX-10R has a bore twice as big as its stroke, or in other words it has room for valves like most 2-liter car engines. It also has something like 13:1 compression, quad 48mm throttle bodies, staged injection, and some sort of funky variable-length header or something like that, 'cause what you need in a 1-liter sub-400lb bike is more low end torque...
I don't know much about the Hayabusa engine.
What I am seeing is, this is an adapter for this little 1300cc to any trans that takes a Mazda B-engine.
You know what else takes a B-engine? Festivas and Aspires.
I'm thinking giggle factory.
Edited 2 time(s). Last edit at 07/11/2010 02:06AM by Pete.
Jay
Jay Woodward
Jay
July 11, 2010 06:45AM
She's SCREEEMIN fer it!
Jay Woodward
Snohomish, WA
Ted Andkilde
Ted Andkilde
1968 Mini
July 12, 2010 07:38AM
Tim Taylor Wrote:
> With the two piece construction of the adapter I
> can make any bell-housing adapter bolt to any
> transmission by changing that and the removable
> crank snout on our main shaft. The next two on
> the list after the Mazda transmission are VW bus
> transaxle for the sand rail set and Type 9 for the
> Lotus 7 replica crowd.
Great target markets, Type 9 is used primarily by the guys in England, T5 would be the way to go on this side of the ocean.
t
August 02, 2010 12:57PM
Someone put a BUSA motor in this!!
It's 4 feet wide and weighs 650 lbs.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270615515754&viewitem=
August 02, 2010 09:41PM
So Tim....if you did VW then I could convert my FV over to something totally insane to drive?
August 02, 2010 09:57PM
New class - Formula 'Busa
August 02, 2010 11:34PM
Yes, and it's just when, not if we do a VW transaxle adapter. It costs us about $700 out of pocket for parts/scanning on each new application we plan to do. If you have a spare engine and transmission case you want to let us measure I can move it up the list. Michel is already planning to bring by a Golf transmission to see if it will clear the engine case. Lots of high RPM stupidity in the works...
