mellow65
Oliver Klozoff
Nada
thoughts on braided brake lines for half the car
July 08, 2010 02:41AM
so i'm going to reroute my rear brake line through the cab so i can get them away from the underside of the car. i was always planning on just using some decent braided line with some AN fittings. seems like it would be fairly easy to do it this. there are a bunch of pre made stuff out there, fitting, bulk head connectors, ect
but i was having a conversation with another rally guy and he was saying i should stay away from doing the whole rear section with braided lines. i was pretty confused. i have heard of some rally cars having full braided systems, no hard lines what so ever.
are there any thoughts, concerns, information i should know about running soft lines pretty much from the master cylinder back.
i mean clearly the ease of installation is a great draw. but he talked about even though they are braided, there is still flex to the lines. i mean i guess this would be true, but has to be a lot less then normal rubber lines.
Re: thoughts on braided brake lines for half the car
July 08, 2010 05:03AM
It is pointless waste of money to use braided.
It'll cost hundreds to do what 12-15 bucks would do in plain ordinary hard line...
What ADVANTAGE would wasting hundred of dollars for braided give you?
July 08, 2010 10:13AM
Serious waste of time and money. Use as much hard line as possible. I've seen braided leak at the fittings. Hard line is easier to route out of the way. Bend it and it stays there. Easy to patch if needed with a cheap flare tool and a union, stuff available at nearly every parts or hardware store.
mellow65
Oliver Klozoff
Nada
July 08, 2010 10:55AM
ok then, the oldies have spoken. guess i'll yank all the stuff from the legacy i'm parting out to save me even more $$$.
and while i have the attention of 2 of my favorite rally gurus, thoughts about rear brakes. i'm having my axles turned down to fit the front rotors. it was an idea i had after talking to john and saying i should look for something with a good hat to it. low and behold the fronts have a decent hat to them, vented and have the right lug pattern and less parts to carry around because it will share the same rotors. then i thought, well hell if i'm using the front rotors might as well use the front caliper.
ok sure, over kill, yes, ridicules, maybe. but one again less parts to carry, simpler set up in the rear, only having to run hard lines because they are a fixed caliper. and you might be surprised how damn close the tabs line up.
also the way i figured it, and i might be way wrong on my thinking here, but my 1.2" piston 4 pot caliper needs the same fluid as a 2.4" single piston caliper because the 4 pot is moving half the distance then the 1 pot. am i totally wrong here. because i'm trying to think master cylinder too.
the stock 2nd gen rx7 masters are 7/8". i have available up to a 1 1/16 thanks to subaru stuff shockingly fitting just perfect. smiling smiley
thoughts
July 08, 2010 02:17PM
Besides, the braided lines have much more compliance then hard lines.
July 08, 2010 03:14PM
I just got a 25' roll of premium ultra fancy coated 3/16 hard brake line to re-do a friend's rally car for a whopping $20. Fittings run about 30 cents each.
Compare that to $4.59/ft for -3 brake line from pegasus, which is about $115 for 25 feet. And fittings anywhere from $5 to $25 a piece... It gets spendy real fast.
mellow65
Oliver Klozoff
Nada
July 08, 2010 03:51PM
where did you get the roll of tubing from? i just parted out a legacy so i have tons of lines from there. but if i cant get that stuff to work need a back up plan.
whats the best way of bending that stuff with out kinking it?
Doug Heredos
Doug Heredos
July 08, 2010 04:03PM
> kinking it?
Use your hands. Or, bend around something big like your tranny tunnel, or even some roll cage tube depending on what radius you need. But all the stuff in our car was bent just using my hands. Lots of little bends to get it just right. Pretty easy.
Get a good flare tool. Even with a good one it can be a bit of a bitch to get the joints so they don't leak the first time. But it gets easier with practice. At Gene's age, he's probably done 1,000 times the joints that I have. smiling smiley
Doug
July 08, 2010 05:43PM
Your local autoparts store should sell brake line by the roll, thats where I got mine.
I bend it by hand too. Just form a nice radius for each bend and you wont kink it.
July 08, 2010 08:56PM
Doug Heredos Wrote:
> out
> > kinking it?
> easy.
> Doug
Ahem...at my age I've done a bit of asskickin too, you young whippersnapper winking smiley
BTW what the hell is whippersnapper anyway??
July 08, 2010 09:45PM
Me.
July 08, 2010 10:04PM
> Feisty Peacock?
This is true. My Ascona when I got it had the rear axle all plumbed with braided teflon line. After a flat tore that up a bit I replumbed the rear axle with hard line (with just a braided line from the chassis to the axle). Pedal firmness was improved quite noticeably even with that 3 or 4 feet or so of braided line replaced. That's why it surprised me when I was in England at R.E.D. and Ford Boreham and saw the Escort Cossies with the entire brake systems plumbed with braided teflon lines. Faster and easier to plumb if you have a huge budget but it's got to affect the pedal feel I would think.
DirkaDirkaJack
Jack Russell
phil's GTI
July 08, 2010 11:15PM
my mazda only has braided line (i didn't pay for it) and the pedal is plenty firm.
July 08, 2010 11:19PM
This is a preference. My mountain bike had vinyl lines for the hydraulic disc brakes. It now has steel braided lines. I HATE squishy brakes, and that would be reflected in all braided line setups.
July 12, 2010 06:52PM
My Merkur has only braided lines and people have complained about pedal stiffness since they're all used to power assisted brakes. It is more expensive though as others have already pointed out. Three or four years down the road though and I don't even care that I spent that extra money. Shit. Has it really been that long since I did the brake setup.
