token-negro Kendrick Gray Godlike Moderator Location: Renton, WA Join Date: 04/20/2009 Age: Midlife Crisis Posts: 176 |
derek Derek Bottles Ultra Moderator Location: Lopez Island/ Seattle WA Join Date: 12/20/2005 Age: Possibly Wise Posts: 853 Rally Car: Past: 323, RX2, GTI. Next up M3 ? |
I have used Ballard Sheet Metal many times for SS work, not sure if they have a water or laser cutter but they always got my bits made at fair prices and quickly.
They would at least know who to talk to if they can not do it. In the long run reality always wins. |
derek Wrote:
------------------------------------------------------- > I have used Ballard Sheet Metal many times for SS > work, not sure if they have a water or laser > cutter but they always got my bits made at fair > prices and quickly. > > They would at least know who to talk to if they > can not do it. > > See me go at: > www.11tenths.com > In the long run Reality always wins. They said they dont do laser or plasma cutting in house. |
Laser-cut NW just north of Auburn airport.
Used them a lot. Pricey on onsey twosies but you know to expect that. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Tim Taylor Tim Taylor Infallible Moderator Location: Oakland, CA Join Date: 02/02/2007 Age: Possibly Wise Posts: 622 Rally Car: Mazda 323 GTX |
Rallymech Wrote:
------------------------------------------------------- > I would prefer water jet cut over laser just > because I am nervous about bending across a heat > affected zone. That is not a problem with nitrogen assist laser cutting and even less a problem in normal grades of stainless. Don't worry about that and get your parts laser cut because they will be cheaper, the edges will be cleaner, and the features will be more square. -Tim |
Dazed_Driver Banned Ultra Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
Tim Taylor Wrote:
------------------------------------------------------- > Rallymech Wrote: > -------------------------------------------------- > ----- > > I would prefer water jet cut over laser just > > because I am nervous about bending across a > heat > > affected zone. > > That is not a problem with nitrogen assist laser > cutting and even less a problem in normal grades > of stainless. Don't worry about that and get your > parts laser cut because they will be cheaper, the > edges will be cleaner, and the features will be > more square. > > -Tim Does the nitrogen act as a shielding gas and keep the cut cool? Welcome to the cult of JVL drink the koolaid or be banned. |
SteelSolutions William Timmins Elite Moderator Location: Redmond WA Join Date: 02/26/2008 Age: Midlife Crisis Posts: 648 Rally Car: 3 xr4ti/74 capri/02 bug eye |
nitrogen is very good at preventing oxidation. copper oxidizes and becomes porous
and contaminated on my cutting tips. ss will have a porous and black cut on the back with plasma and very little with laser and no nitrogen. I know of 3 shops that might do it one off what are you making? this was cut with just air it cleaned up fine just you cant do directional grind material because you have to clean the edges. ![]() TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
DirkaDirkaJack Jack Russell Senior Moderator Location: Downtown Seattle Join Date: 06/05/2008 Age: Midlife Crisis Posts: 206 Rally Car: phil's GTI |
place in Redmond dose it all and the owner is awesome and showed me all his stuff
for 2 hrs after he got one of my clients because I cant compete with there work. http://automatedmetaltechnologies.com/ TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
token-negro Wrote:
------------------------------------------------------- > I ended up using Terrene Inc, in Mukilteo they do > laser but no forming that will have to be done at > another shop. > Oh, yeh, for a box I really think only the finest CNC laser cutting will do. And for welding a box Robert was right, the loss of strength in the HEAT AFFECTED ZONE could be catastrophic... Boxes are critical, gawddammit CRITCAL!!!!!!!! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Aaron Luptak Aaron Luptak Mega Moderator Location: SLC Join Date: 02/15/2008 Age: Midlife Crisis Posts: 776 Rally Car: Civic... |
I think for a critical piece like this, machining the thing out of a single block of billet alu is the only reasonable method of manufacture.
![]() ![]() http://www.utahrallygroup.com |
Aaron Luptak Wrote:
------------------------------------------------------- > I think for a critical piece like this, machining > the thing out of a single block of billet alu is > the only reasonable method of manufacture. > > > It’s a stainless steel tank for methanol, so aluminum isn’t the best choice. |
token-negro Wrote:
------------------------------------------------------- > Aaron Luptak Wrote: > -------------------------------------------------- > ----- > > I think for a critical piece like this, > machining > > the thing out of a single block of billet alu > is > > the only reasonable method of manufacture. > > > > > > > > It’s a stainless steel tank for methanol, so > aluminum isn’t the best choice. > > I used to do sheet metal fabrication as my job. We mainly used galvanized, but we also used stainless. I understand your wanting to get it cut via laser/water/plasma. The waterjet parts were SO nice to make (well, besides the company using shitty tolerances), compared to fabricating boxes and vents by hand, which takes forever. Especially with stainless. Welcome to the cult of JVL drink the koolaid or be banned. |
