Recommended Alignment Settings for a FWD Car
Posted by MikeColangelo
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
Re: Recommended Alignment Settings for a FWD Car
August 16, 2010 04:18PM
Thanks Josh! smiling smiley
SeanP
Sean Lane
2000 Dodge Neon G2, bruised
April 28, 2012 02:23PM
Bumping this. Just dropped off my neon for some alignment work. I requested 0 camber all around and about 1/16-1/8th toe in for the front and 0 toe in the rear. The prior owner of my car like front toe out and Chris greenhouse suggested front toe out, but I just didn't like the squirrely nature on the fast sections. I value the advice here for newbies of keeping it close to neutral and making very slow changes.
SteveL
Steve Leitch
Can't decide which to use...
April 28, 2012 06:22PM
I'd say it all depends on the age of the bushings, old sloppy bushings, toe out,
new poly/delrin bushings, 0" toe.
SteveL
April 28, 2012 09:17PM
I think a bit of negative camber would be good. Rally cars are floppy, so you may end up with 1-2 degres positive while cornering.
April 29, 2012 12:16PM
yep .5 degree of camber and 0 toe has been good for me, we destroy the corners of the tires a bit less that way.....reading tires helps alot when setting up camber and toe.
April 29, 2012 12:32PM
Second Tom's comments.
The ol saw about lots of camber originated back in the day of flexy sidewalls.. Since the arrival of real Michelin rally tires back in maybe 1990 or so, not needed now. so maybe 1/2 degree....
Personally I like a smidge toe IN so that with normal bush compliance---it always pushes BACK, the effective to goes to about zero....and I have a LOT stiffer bushes than all you boys with struts.
Rear zero or in a smidge for same reason as front. car goes forward, force goes rear on arms and toes goes a smidge out, so you want zero, start IN a red c**t hair
April 30, 2012 03:16AM
John, on a FWD car the fronts wheels/control arms are pulling forward under power and push back under braking. A bit of toe in prevents it from going toe out under braking for stability.
Josh Wimpey
Josh Wimpey
Sneak the Golf
April 30, 2012 11:16AM
Paul, depends on where the compliance is relative to the tie-rod.
On a VW, the rear bushing on the control arm is BEHIND the tie-rod which is angled slightly forward at straight-ahead steering...And attaches to the rear of the hub/upright. With this setup, you get toe-IN during braking (wheels move rearward in the wheel-well but tie-rods remain the same length) and toe-out under acceleration.
See picture below--Top of pic is front of car. Rear bushing is the one that deflects, front might as well be solid....
One. Class -- 2WD
www.quantumrallysport.com
