Re: Merkur Oil Cooler
June 28, 2006 04:54PM
> So, everything is on it's way.
> Setrab Oil Cooler 11.75 X 5.75 X 2 with AN-10
> in/out
> Setrab PS Cooler 6.5 X 5.75 X 2 with AN-8 in/out
> Permacool Remote Thermostat (1070)
> Permacool Adapter 1791
> Permacool Remote Filter mount 195
> 8 AN-10 to 1/2" NPT (For filter mount, turbo
> return on block, and remote thermostat, one
> spare)
> 2 AN-10 to 3/8" NPT (For adapter on block)
> 1 AN-6 to 1/2" NPT (for filter mount to turbo)
> These are extras I bought for identifying
> purposes
> 2 AN-6 to 1/4" NPT
> 1 AN-6 to 1/8" NPT
> I got a free big box of various AN hose and
> fittings from a local Nascar team. Deal was I
> could use whatever I wanted and ebay the rest for
> the person who gave it to me. Total cost for all
> of this so far is a bit over $300. I plan to make
> a crossmember to bolt where the ac condenser used
> to that both coolers will mount to. Also going to
> make an additional lower crossmember for skidplate
> mounting and air dams to radiator.
> So John, in your setups are you simply blocking
> off the stock turbo feed/oil pressure gauge? I
> plan to run all of this the same as you state just
> with the remote thermostat and a Setrab cooler.
> Excessive? Probably. I'm sure I could have just
> settled with an RX7 cooler, which has shown to be
> sufficient, but not only am I trying to build to a
> high spec, I'm also trying to lead by example and
> get my other rally friends to not do things
> half-ass.
> Grant Hughes
> Denver, CO
Grant,
Wasting money on brand new coolers and remote thermostats is half assed.
I want to know what you paid for that little tiny cooler and the even tinier PS cooler so I can bitch you out properly.
What the fuck am I slaving over hot cars pulling things pff of cars in the hot wrecking yards for??
And this is the thanks I get!!!
Oi!!!!!
You can pull the adaptor on the head and stick the idiot light send there or just plug it.
(I have like 5 of the Volvo auto trans coolers which are perfect for ther PS cooler)
June 29, 2006 08:36AM
New? No way. Used. Those Nascar guys like to get rid of stuff and give it away kinda cheap to free (see aforementioned free hoses). All the hose has Kevlar/Nomex heat shield wrap too, which will be nice for turbo feed and return.
You know what's worse than sitting in the sun pulling parts from the junkyard. Driving a total of about 40 miles to go to two different junkyard, hauling all of your tools around through the junkyard with a list of parts from about 4-5 different cars that you could use, and not finding one of the cars. Now do this three to four times and you'll see what I've been doing on Saturday mornings. Talk about wasted effort and quite annoying.
June 29, 2006 09:54AM
You need some better junk yards boy!
June 29, 2006 10:18AM
No shit. Sunday morning was the most annoying because I rode my scooter the 12+ miles to the one with a heavy backpack full of tools. Nothing I was looking for was there. Went looking for something else. 4 stores later (furthest at 7 miles from home) with no luck. Gave up and went home, then to work. Pretty much nothing but breakfast and pet food purchasing was accomplished that day. Though I did hear this week about a red XR at a junkyard down south in pristine condition. Place is mainly Subaru, Toyota, Honda so not many Merkur owners have stumbled across it.
John Cassidy
John Cassidy
December 17, 2006 07:17PM
John, what pump are you referring to? I'd like to source the correct one now while the timing is good.
Thanks! John
> Pump chosen was chosen after a nice long talk with
> a oil pump dood at Melling.
> The standard 2.3 TURBO pump is an excellent
> pump, but we are using a BIG oil cooler and some x
> length of hoses, so more volume was wanted.
> If'n youse wuz using a Volvo cooler, I'd say what
> the fuck and go with a notmal TURBO pump which is
> already a HV pump----relative to the base 2300
> pump.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
http://www.lastditchracing.com
http://www.triplecaution.us
December 18, 2006 07:50PM
PAddy Wrote:
> Does nobody make one with AN/JIC ports directly?
> Why does it all seem to be Leaky Pipe Thread?
http://www.mazdatrix.com/b6.htm
Scroll to "Oil Line Adapters for -AN Style Lines".
These are standard parts, too, I know my Aeroquip book lists them. There are two different sizes, 16mm and 18mm, apparently the SA/FB cooler (bungs stick out towards back) are 16mm, the FC (banjo on side, same car you grab the calipers from) are 18mm.
I wouldn't recommend retapping, as the coolers are fairly weak. I've replaced quite a few SA/FB type that were cracked in the bung area. Maybe the FC units are stouter, but still $20 + shipping (maybe less!) is a small price to pay to avoid pipe threads.
