I mean it was just 0,1mm only .004"!!! The horror! a career lost cause of unforgivable catastrophic gross BLUNDERS!!!! I think this is called for: <object width="425" height="350"><param name="movie" value=" &rel=1"></param><param name="wmode" value="transparent"></param><embed src=" &rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object><p><a href="http://www.sal2009.com/view.php?video=EdzqTGmEcZE&feature=youtube_gdata&title=Dirty+Fork" |
mellow65 Oliver Klozoff Senior Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
and now he can't even post you tube links.
for shame john for shame. maybe it's time for more pain killers. ![]()
"Rally racing makes a heroin addiction look like a vague craving for something salty" |
How do we do imbeds_
That video is PERFECT for the feeling I need to convey.... and what I need is more TEA!!! I was up to 0230 working on pressing in bushes for Ozgur, Wildman, Dave Kern and Garth in Portland
Cosworth Paulinho Ferreira Professional Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
Well whatever the piston sizes are you're going to figure out a way to redude rear torque. 5/8 front and 13/16 rear with stock pads might work. If its still too much rear, then just add a prop valve to the rear. Its not ideal but oh well. Do you HAVE to run the same calipers in the rear? Why not do John's Vulva rear calipers. Much better setup.
SgtRauksauff Jorden Godlike Moderator Location: Baraboo, Wisconsin, USA, Terra, Sol, Milky Way Join Date: 01/24/2006 Posts: 372 Rally Car: whichever one i happen to be driving at the time |
Yeah they not sexy but we've used them on a dozen different cars and the balance is just about perfect with any realistically sized fronts. And you can get good pads for the Vulva rear. |
because when i had my axle machined and redrilled they turned the center to fit. its not that i can't go to other rotors. its more about the $$$$ to redo everything i have done.
no i don't HAVE to run the same calipers. all of this came about after talking to john. it started with him saying to find a rotor with a decent hat to it, um ok, the fronts have a good hat, i'll use those, then he said find something with a decent size bore to have a good balance. sadly i have a crap load of random calipers laying around from different cars through out the years. most seemed to be tiny little rear brakes with small bores and then i started laying the front calipers next to the whole thing. it just fit so well i went with it. my problem now as it sits right now is i can't use the volvo caliper because i have a vented rotor. i could then make the rear volvo rotors work, but that would then required some more machining to get the axles right. which isn't bad, but the chances of getting those damn axle bearings off with out effing them up so i can get it in a lathe is the part that scares me a little bit. i'm sorry but those damn bearings were not cheap. so think vented rotor caliper for me. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Tim Taylor Tim Taylor Senior Moderator Location: Oakland, CA Join Date: 02/02/2007 Age: Possibly Wise Posts: 622 Rally Car: Mazda 323 GTX |
yeah like john said. toyota 4x4 this is what i do to GSL axles ![]() i dont like doing that, it makes me not go as fast
ok so john, if i ditch the mazda rotor and caliper in favor of volvo rotor and caliper, what do you think the chances are of making the axle fit the rotor with out removing the bearing. could you still turn it down with the bearing on it. i'm just really not wanting to replace those again. and i haven't found a way of pulling them with out destroying them. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
you say prop valve, are you still taking in to consideration im running a balance bar. or am i giving them to much credit on adjusting front/rear bias. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Lemme get back to you on that. I have to go pick up some pick up axles just now. |
oh and one last thing and i swear i'll shut up.
![]() what say i forgo manual brakes and stick with power brakes. i mean hell tons of those plowing through the woods with no problems. any thoughts on size for mc? the stock 2nd gens were 7/8" but i figure sticking with the big calipers on the rear would need some more fluid. now shockingly subaru power boosters bolt in no problems and those can be had with 1" and 1 1/16" mc. move the push point up to keep the pressure about the same, get a prop valve that will adjust pretty damn low (which i have found already) and call it good. not perfect, but so far there is no perfect answer. its just another answer. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Ooooooooor what about the metric gm caliper. dirt cheap, easy to find, if i remember right the bores 2.5". wilwood also makes a 2" version. thank you circle track racing for making stuff available for a reasonable price.
just more thinking out loud. i know those would work with with my vented rotor and to damn easy to mount. no caliper bracket, just 2 mounting pins "Rally racing makes a heroin addiction look like a vague craving for something salty" |
