tips to fix leaky subaru legacy fuel tank
Posted by Greg Donovan
Greg Donovan
Greg Donovan
95 Impreza Sedan
September 15, 2010 05:52PM
in order to fund my rally desires i need to sell my 1994 turbo legacy sedan. however, the car is leaking fuel from the top of the tank behind the fuel pump near where the fuel goes in and the vent and breather tubes. might also be leaking from around the fuel pump gasket too. not sure where since the fuel has gotten all the dirt wet. i want to weither fix it before the sale or know how much to drop the price before i sell it without fixing.
in order to better understand the surce of the problem i am considering cutting open the floor of the trunk more around the access port for the fuel pump to have better access to the top of the tank without dropping the tank out of the car. is that a stupid idea? we would use good metal shears not a torch or cutoff wheel around the fuel soaked tank.
Edited 1 time(s). Last edit at 09/15/2010 05:55PM by Greg Donovan.
Re: tips to fix leaky subaru legacy fuel tank
September 15, 2010 06:07PM
Greg Donovan
Duct tape, and lots of it.
Duct tape and spray in fiberglass from a chopper gun.
Then, more duct tape.
Or, run the car till gas tank is empty.
problem solved.
John "the man with all the answers" V
(yeah all the answers but sometimes they may not be exactly match to the question, but wot da fawk doooze youze expect?)
September 15, 2010 06:12PM
Do not fix a gas tank with duct tape, at least not has a permanent fix. That's ghetto, and just fucking lazy.
Is just the driveshaft in the way of dropping the tank? I would drop it and investigate WHY its actually leaking, and fix that.
As for cutting the floor, I don't remember what the floor of a subaru looks like right there, however, I would avoid cutting the body shell just to avoid dropping a tank.
September 15, 2010 06:21PM
Are you really so stupid?
I don't believe you're that stupid.
If you are put your head in the nearest toilet and flush.
Greg Donovan
Greg Donovan
95 Impreza Sedan
September 15, 2010 08:44PM
the rear cross member, rear differential, rear suspension, driveshaft and exhaust are in the way of dropping the tank.
the "door' would only be about 6" x 6", just enough to reach the fittings. i would then rivet in new metal with seam sealer.
dropping the tank is rated as a 2.5 hour job in a shop with a lift and air tools, i have niether. parts are around 200 unless the tank is shot and needs replacing.
i am thinking i should just knock 400 of the price and send the car down the road. however, i am selling it to a person i work with and consider a friend so i want him to have a safe car and it really isnt in its current condition. aside from the leak the car is in god mechanical shape with a recent trans rebuild and new timing belt and pulleys.
Edited 1 time(s). Last edit at 09/15/2010 08:46PM by Greg Donovan.
September 15, 2010 08:50PM
Usually a top of the tank leak is a hose or the module seal. Best to just fix it. Once you start admitting problems and discounting it seems to never stop.
There is a new aerosol duck tape that might work also.
September 15, 2010 08:52PM
Timmah has obviously never worked on a car that's been salted like a bad margarita factory, nor has he had to dump a POS car for cheap money, nor has he a functioning sarcasm meter.
Greg Donovan
Greg Donovan
95 Impreza Sedan
September 15, 2010 09:01PM
i agree. we are allready down from 2 to 17. dont want to go much past 15 but i do want the car gone.
how about i just spray a bunch of spray foam insulation in there and call it a day?
September 15, 2010 09:02PM
One super salted 1930's rolls royce, and a 1969 (I think.. it was the crazy stingray style one) kermit the frog green corvette(The things you see at a classic car restoration shop, haha), but besides that, not really, and the rest guilty, the last one especially today, I'm dead ass tired. He said ducktape, and then kept going with what to add to it. It seemed serious at the time.
RyanHuber
Ryan Huber
2000 Subaru Impreza STi
September 15, 2010 09:35PM
My first legacy had a leak in one of the hard lines coming up from the top of the tank, the steel tube rotted around where the hose attached. It's more likely something like that than the tank itself if the top of the tank is wet with gas in the dirt. It could also just be a cracked rubber line, either one from the pump assembly or one of the cross over lines.
You can drop a tank in the driveway with a jack and stands, it isn't that bad.
Ryan Huber
VA3AWD
September 15, 2010 10:09PM
actually i said duct-tape duct boy duct.
Good to see you're merely exhausted at 6 in the evening and "not yourself"
But I am going to scold you because what should have been glaringly obvious, and to all the grown ups here, was glaringly obvious, you took it to be serious.
I say that is your major problem, you are not opening your eyes, you think that you are smart and want find errors...
YOU may be want to believe somebody might try something like that, but you should at this point know that I am not so stupid that I would actually say seriously to somebody to fix their tank with duct tape.
Regardless of how tired you are.
But you're not looking at the bigger picture AND you are by your constitution trying to "assert yourself' via LOOKING FOR FAULTS, and thus you miss the glaringly obvious...
In short, you will not learn anything until you stop thinking you're so smart, and stop challenging your superiors, which for you is virtually anybody...you can ask question but learn something other than the simple declarative sentence and learn that many people are often joking around via massive exaggeration.
(Go look at Gene Ms add for his Ultra-pimp-ular trailer wheels. You have to ask yourself "why could gene figure out the exactly correct tone to respond to the buyer inquiry?"
Cause he's not a punk looking to prove everybody wrong.
Edited 1 time(s). Last edit at 09/15/2010 10:09PM by john vanlandingham.
September 15, 2010 11:49PM
And I'm going to scold YOU for ASSUMING I'm convinced you aren't that stupid. Because I'm not. But what do I know? The infallible John will set me straight.
Greg Donovan
Greg Donovan
95 Impreza Sedan
September 15, 2010 11:52PM
what i would do is make this hole bigger by cutting straigh back from each side the oval to reach the back of the tank.
not my car, i wish it looked that nice in there.
Edited 1 time(s). Last edit at 09/15/2010 11:53PM by Greg Donovan.
September 16, 2010 12:09AM
That duct tape answer barely even registers on the scale...this is some vintage John V. Turbobricks comedy gold.
The Question:
Originally Posted by VolvoPunch
So I am trying to use dales crank pully but its smaller then the original and none of the belts want to fit. There is too much slack even when the adjustments are put to the max. Anyone know of another way to fix this without buying new belts? If not does someone have the part number for the correct belts at fcp groton.
Dismount the belts, move the accessories to a middle position check how much slack there is.
And the deadpan answer:
Then throw the belts in the washer on HOT, wash them , then heave them in the dryer on HIGH heat, if you time it right, they'll shrink just the right amount..
Probably work better than cutting the excess portion and trying to duct tape them back together, though industrial staples might work.
The best part is that the guy actually tried it confused smiley
September 16, 2010 01:20AM
Simpleminded little pea for brains child, shut the fuck up.
I try and be polite, try to explain why you SEEM like an actual mental retard, and you cannot even read a simple sentence correctly.
Timmy:
F for reading comprehension
F for awareness.
Drop out now and just stay at home for the rest of your life, you're not ready for the world..
Edited 1 time(s). Last edit at 09/16/2010 01:20AM by john vanlandingham.
