XRATTY build
Posted by frumby
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
December 05, 2010 11:29PM
Long talk with JVL yesterday.. Lots of fun and good discussions (not all car related!). Came away with some sloped bitchin front brakes, and a cossie turbine housing!
Popped the head and pan off my nasty motor. As bad as the cooling system looks the oil side looks really nice. Pistons and valves/chambers are clean and lots of crosshatch is visible. Head is obviously brand new with roller cam etc. Heard its not as hot a cam as the stocker, but that's what is in there. Huh. Seems to me a hot tank and new seals, everything else should work.
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
December 13, 2010 08:23PM
Where do you turbo ford guys find the best deal on engine rebuild bits? Big bits are ok, but seals, rings, bearings, timing, water pump type stuff.
SteveL
Steve Leitch
Can't decide which to use...
Re: XRATTY build
December 13, 2010 09:49PM
Here...
http://www.rockauto.com/catalog/x,carcode,1204670
SteveL
Re: XRATTY build
December 13, 2010 10:12PM
Got everything for my last 2 builds at my local carquest.
I don't mind paying a bit more for the face time, then when you need to dig through the catalog to find a suitable replacement tie rod end you can.
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
December 17, 2010 04:47PM
Engine management. Realistically sticking with what I've got or going LA3+big VAM... however, anybody have info on a Megasquirt type thing that doesn't require a computer/tuning genius to get it running right?
DIYautotune.com
or.. http://www.wmsracing.com/wmsweb/product1547.html
Re: XRATTY build
December 17, 2010 05:22PM
If you do anything stand alone I'd look into the Wilson Racing stuff. That's what I had bought before trading up to one of the AEM Stinger 2 setups that was really a steal as it came with a brand new engine harness to go with it.
Re: XRATTY build
December 17, 2010 09:05PM
La big vam is more than enough for an XR. Easily make 250 torques, 200+ HP
Can't imagine needing more in a RWD car.
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
December 20, 2010 12:37AM
Picked up big VAM and LB3 puter... should be a solid improvement.
Visited TSS fab today. Ordered up some goodies and almost watched the shop burn to the ground winking smiley Def skunk works over there... good stuff William, keep cranking it out.. there is a need!
Re: XRATTY build
December 20, 2010 10:47AM
Yeah but how you sposed to kick on the anti-lag and make big bang bang boom sounds while sitting in Parc Expose. smiling smiley
Re: XRATTY build
December 29, 2010 02:00AM
I have a few alt brackets done suppose I should get some photos.
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
December 29, 2010 10:58AM
Alrighty! Well, you got my moolah... I'll pm you my address. Let me know as soon as you're cranking out more stuff. I need everything you make except for the intercooler/radiator stuff and the supra mount which I already have. Def the beam reinforcement, T5 mount, even things like cage 'tacos' if you can crank those out easy I'm in for.
Thanks William!
Re: XRATTY build
January 10, 2011 03:19PM
hey guys not to whore my self out on Jason's build.
but I hope to do a lot of trick work for him.
I have my car in the shop now and its stitched up
and ready for a cage I have enough material to put
some kits together. I can do the 9 yards taco's and
tubing from rear to front strut towers.
I have alt brackets, and ps brackets, tranny mounts,
dual master box's, strut tower bracing, anything,
winter has been really slow and work short so if
there's anything you have been thinking about
getting it would be greatly appreciated.
I have to thank jvl a lot of the parts are his brain
storming and ideas. so you can order from him or
me for fabed stuff and I will make sure it get done
in 5 business days of an order unless its square
beam or other large project.
William@tssfab.us 425 463 5307
jvl 206 431 9696
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
January 10, 2011 07:55PM
Whore away William! I'm in for trick parts esp when they are from a local guy that needs the work and also happen to be a great cost and value.
Alt bracket looks great! If you're able to build up nice tight cage kits off your car then I'm in right away... You'll have the $$ in hand. Just mark the bits with sharpie so I know which goes where etc, I'll get down there and pick it up, and weld it in myself.
I'm interested in the beam now that it appears to be done. If it is done then let's get some cost info out there so guys can budget for it. Good to hear that it requires at least some of the Supra diff kit that I already bought!
PM me your address and the cost of the manifold stuff and T5 mount and I'll get you the money.
J
Re: XRATTY build
January 10, 2011 08:17PM
frumby
J
Re square beam: gotta paint 'em up and take some piccies but been to hectic and cold for paint!
Got some rear discs in.........
frumby
Jason Hynd
XR4TI a slow build!
Re: XRATTY build
January 10, 2011 09:58PM
So what's the timeline on rear brakes. Same guy that set up Grants will do a nice setup for around $900. 11" rotors, Superlites, brackets and hoses. I'd prefer to stick with you if'n you'll have sumpin ready soonish.
JV, what's the bottom line on beams.. Cost, time to build one for me etc. I am trying to decide between a TSS reinforcing kit or a Square Beam!
Motor is ready to put back together. Got lots of boxes: Altenator mount, new ECM and big VAM, rebuild kit, cossie housing and lots more!
