Custum brackets list anyhting you can think of!
fliz
Chad Eixenberger
1988 VW Golf #687
Re: Custum brackets list anyhting you can think of!
December 23, 2010 09:01AM
Is that VW 6 bolt top plate for a Burmeister strut top?
Also how about just a tube for the hole on the VW a-arm?
Edited 1 time(s). Last edit at 12/23/2010 09:03AM by fliz.
December 23, 2010 11:34AM
fliz
Rightie-o Chad---that's the idea!
I like to do 2 layers, upper and lower and joined by tube welded in and kissed sown.
It only occured to me later that I was making stiff that looked like motorcycle swing arms but we gotta do something to join the thing into one stiff thang..
December 23, 2010 11:40PM
fliz
Its been a wile on the strut top I'm not sure.
I like the tube idea. cool ill do that next time some one wants one.
Robert Culbertson
Out of this dumpster fire
December 25, 2010 01:35AM
I'm in need of some top mounts and some control arm reinforcement plates for a vw gti (mk2). I sent you a pm about..mhmmm... a minute ago.
Have a Happy/Merry/Hoon-filled Christmas!
EricW
Eric Wages
2002 WRX
December 25, 2010 10:20AM
Subie control arm reinforcements?
December 25, 2010 11:54AM
EricW
Probably unnecessary. They're cheap and they are relatively strong. Weld pushing points on them and get a small hydraulic thingy to be able to straighten them a bit on transit if needed.
December 26, 2010 11:03PM
if you are interested in a set I have steel arms off a wrx
I can make them for you.
they do bend up a lot people switch to aluminum arms
and I have seen plenty of those bending.
if you fix up a pair for half the cost of sti ones
and they last long enough I think its worth it.
January 20, 2011 12:22PM
William - wondering if you have any unfinished Merkur/Supra diff mounts?
I'm going to be mounting a supra diff in my BMW and I'm after that flat piece contains the rubber bushings. If you are able to profile the bottom edge as normal, but leave the top edge of the steel uncut so its maybe 6-10" tall overall, instead of just 3" or so. That way, once I get the diff in the car I can trim the top down as needed so that it will reach the floor, and then I'll have Grant help me box in all the corners.
Thanks,
