Custum brackets list anyhting you can think of!
December 13, 2010 06:52PM
HI well I have said I was going to start this list for some people.
For people that don't know what I can do, I can take drawings and dxf files and can cut and shape you
desire with out the set up cost and quantity that other shops cant afford to do.
I use to ask for a 100 minimum order but for this I will go down to 50 plus shipping minimum.
I will start posting parts asap I have reinforcement kits shock tabs cage base brackets taco gussits and
anything you can think of.
I have about 1000 parts I saved from the last few years so I will pull the ones up I think people will want
and show all there measurements and post them.
I will take scans of drawings and cardboard cut outs for this post and not charge any drawing fees to get
more on to my data base, and try and give them all part numbers.
my email is William@tssfab.us and my cell is 425 463 5307
frumby
Jason Hynd
XR4TI a slow build!
Re: Custum brackets list anyhting you can think of!
December 13, 2010 08:21PM
William.. I talked to you a while ago, but I need the altenator mount for my xratty. Also heard you can do rear beam strengthening bits and rear strut mounts for xratty. Really can't move forward without the altenator thing because I need that to plumb my intercooler.. Would much prefer to get parts from local guys like you!
December 18, 2010 01:21AM
Ok hear is a start its a Volvo front a arm reinforcement.
one hole allows you to still get a big socket in to take the back ball joint bolt out.
30 bucks for the pair sounds fair.
like I was saying, if you want anything like this, don't hesitate to ask.
December 18, 2010 01:34AM
Another right quick is a Xr4ti strut brace Ill try and get a photo of it bent up and dimpled.
they fit tight and rap around quite aways. the rest against the crease in the inner fender and leave
enough room to weld on fully with out interfering with the lip from the fenders.
December 18, 2010 02:09AM
hear is the reinforcement kit that Sean M made up they
fit rather well I did place the holes on the shock tabs and ears.
60 for the whole kit thats 24 peaces at 2.50 a part.
December 18, 2010 02:13AM
wheel spacer I can make them for about anything if your in a pinch and cant find one
this one I used to mount my 17 ero focus rims on my xr
price I don't know depends on thickness really just ask me.
December 18, 2010 02:19AM
xr to Saab radiator mount, steel.
I don't remember how much I think it was 55 or so
December 18, 2010 02:41AM
This was made for a toyota axle. I made mine with 1/8 inch and 12 mm bolts.
I can change this set up for any axle you want. for the same price
or more depending on thickness or amount of parts.
The backer is 60 mm wide and thats the same as the ss bushings I use already in a lot of parts.
a lot of bushing ends in stock cars are 40 50 60 and I have all the bushing for those sizes, using 3/4
hime joint which I can supply as well.
the set in the drawing for both sides would be $48
December 18, 2010 11:10AM
I will take a set of those strut tower braces.
December 18, 2010 01:47PM
Good job William!
December 18, 2010 02:26PM
Needs more radius contour on the shock tabs for full droop.
Continue the radius from over the top down to about 9 o'clock.
Gotta watch the distance center of bolt hole to shock body, in all positions including FULL droop.
December 19, 2010 12:06PM
How about a bracket similar to your Saab bracket, but designed to not have as much drop, width be for Setrab oil coolers or similar, and mounting point be the bolt holes on the freme rail forward of the radiator ones where the ac condenser mounted. Does that make sense? Basically same thing as the radiator but further from the ground and designed to support two Setrab oil coolers, one for oil, one for p/s fluid.
To hold them like in this picture. I was using just a piece of al flat stock that's super flexy.
http://nocoastmotorsports.net/Build/Merkur/08Mar8front.jpg
December 19, 2010 01:47PM
ha yea i get it but there is not one number in there. I would need to know how high up you want it and
what is the mounting of the oil coolers are and where would your intercooler go? theres not much space when its lowered.
December 19, 2010 10:03PM
VW top mounts have sold a lot of these.
December 23, 2010 01:01AM
vw front arm reinforcement plate
