1fastben Ben Hetland Godlike Moderator Location: Utah Join Date: 09/12/2007 Age: Midlife Crisis Posts: 297 Rally Car: None, right now |
I saw someone mention maybe dumping the exhaust out the side (as in, in front of the rear wheels)... is that allowed in both NASA/RA? I ask because I'd like to do that, because my exhaust and the way it's been installed, actually limits the downward travel of the suspension by a bit.
I briefly scanned through the RA rule book and didn't see anything, but I seem to remember that it's required to exit the rear of the vehicle. |
mothra Matt Smith Super Moderator Location: Wilmington NC Join Date: 03/31/2006 Age: Possibly Wise Posts: 546 Rally Car: xr4ti |
My recollection is that the exhaust is required to exit behind the driver and codriver. |
Doivi Clarkinen Banned Godlike Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Ancient Posts: 1,432 Rally Car: 1980 Opel Ascona B |
SteelSolutions William Timmins Mod Moderator Location: Redmond WA Join Date: 02/26/2008 Age: Midlife Crisis Posts: 648 Rally Car: 3 xr4ti/74 capri/02 bug eye |
I wasn't so clear the first time. I hate side pipes for that reason but the gas tank butts the passengers side and high up in the car high enough you can make a skid and do a 180 side by side muffler and cat and dump the tip on the side of the car above the sill like literally out the side of the car. |
wvonkessler Wilson von Kessler Mod Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Ancient Posts: 1,128 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
Let's say I could get a body in white of the coupe with all ancellaries except engine and tranny for free in the eastern US. Is there somebody who would commit to building it to RWD specs? You would have to vin it. I'm not going to the effort unless somebody commits. W |
Don't understand if you mean "Is there somebody in the Eastern US who will commit to build it?" Or what? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Dazed_Driver Banned Infallible Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
I hate to be the one who says this, but why have a one off, custom rally car? More over, I wouldn't understand why someone would want want the first generation one off custom rally car from a (no offense to you Will) reasonably new to rally builder.
Just from a risk assessment point of view... it doesn't really make sense. I would build it for yourself first, and run it yourself and try to get attention that way. |
mellow65 Matt Senior Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
I am doing that! others have more money to spare and some one could be just interested enough, like the ford 9" irs Subaru with alloy hubs I'm doing for a customer its way wilder than that the focus. sooo one off hang a diff and move some stuff around? you cut most of the back of your car up just to put some links in. there will be less cutting in the back of a focus than your car. its a risk but what if it work as good as the plan? its not soooo far out, a lot of the us rally crowd are stuck in a box and the fist thing people say is your new so you don't know what your doing I have the tools and skills to do this and bring it to a point where its affordable to the mass of road race, rally just for fun. what doesn't make sense there is only adding some tubing why is everyone so afraid I have made frames that are taking crashes moving all sort of geometry and this is sooooo wild? all the components are proven motor box diff suspension just the way the mount to the car. I'm getting frustrated some times. |
there are 6 mount in the car for the back and I will cut a 1/4 of the spare tire well hang the diff like the Subaru one I do. I will make the links about the same but the front one will be a lot longer but still be shorter than the back too keep the toe in on bump working. The only hard part will be the knuckle that will accept all these parts and hold the 33 spline hub that is in the post above. The suspension will look stock in style 3 lateral and 1 trailing and a coil over shock with a flanged hub |
What's wrong with a 5 linked solid axle? Cheap and easy, well proven and works great in rally. 8" Toyota units are cheap and so are gears and diffs. Why make things harder on yourself getting all fancy with a multi-link IRS that doesn't really offer the best geometry and travel for rallying? Plus more failure points. Just sayin', K.I.S.S.
