Another RWD car joins the fray
Posted by Doivi Clarkinen
It's alive!!
April 28, 2011 04:39PM
Dave tested the car at Dirtfish yesterday. Everything went well. Forrest Duplessis, Dave's instructor, said the car handled better and was easier to drive than the E30s at Team O'Neil. Still a host of details to finish (like skidplate, lol) but car is looking good. Been working so many hours that I haven't had time to upload any pictures but hopefully I can get some up before the rally.
Everything went better than expected
May 09, 2011 01:56AM
After several late nights and a couple all nighters Doug and I finally got the car ready to go for the rally. I finished up the last door panel at 9 am Friday and actually got a few winks in before towing down to Ocean Shores. Everything went smooth, just changed some tires around at service. Dave got started out slow but got more comfortable with the car as the weekend went on. By the final stage on Sunday he was quite competitive and set fastest 2wd time on the last stage. The clutch got a little slippy on Saturday, which was no real surprise. We changed it and installed the aluminum flywheel overnight. Only took 5 hours... Ugh, would rather do a Subaru clutch any day. We had to do the rally with the stock diff but the 3.90 will be ready for Oregon trail. All in all a successful and drama free debut.
Fresh out of tech
At service in Tahola
Action shot by Jamie Thomas
Edited 1 time(s). Last edit at 05/09/2011 02:47AM by Doivi Clarkinen.
Now that the car is finished, some more build pics
May 09, 2011 02:05AM
Rear subframe reinforcing and bushings
Had to notch the fenderwells to clear the coilovers
Finished notch
Brake and suspension pics
May 09, 2011 02:14AM
Made shields to protect the crossover tubes on the Alcon calipers
Rear suspension and brakes
Front suspension and brakes
Front calipers are tight in the stock wheels. Had to use wheel spacers
Underbody and exhaust, etc
May 09, 2011 02:34AM
Here's a couple pics of the skidplate after the rally. Hardly got a scratch!
Doug Chase did a great job on the underbody protection and exhaust armour
Turner Motorsports headers and midsection on left, heavier stock pieces on right
Fluidyne aluminum radiator
Pedals and interior
May 09, 2011 02:43AM
Here's the pedal box finally installed and plumbed. Came up with a creative solution for the throttle cable using the cruise control cable, which was longer.
I'm going to have to make a plate to reinforce the top of the transmission tunnel as it's very thin and the handbrake moves too much when you use it.
False floor
aluminum door panels I whipped up
The office
Re: Everything went better than expected
May 09, 2011 10:42AM
Beautiful! What'd you use to attach the cross over tube shield? Looks like just some glue or something.
Re: Another RWD car joins the fray
May 09, 2011 11:00AM
great stuff. Wht is that underbody protection material?
May 09, 2011 11:42AM
You should see this car in person. I'd park it at the end of the mall and walk to avoid door dings. Saawweeet build. It is the Kim K of cars. Terribly pretty and wicked nasty...
DirkaDirkaJack
Jack Russell
phil's GTI
May 09, 2011 12:18PM
looks like high temp RTV
awesome car too.
May 09, 2011 03:48PM
Steel pop rivets. The RTV is just to keep the dirt and water out.
May 09, 2011 03:52PM
UHMW polyethylene. In fashionable black, of course.
May 09, 2011 04:23PM
I thought those looked like rivets. Just drilled through the caliper? Any compromise on strength by doing so?
May 09, 2011 05:05PM
Not drilled all the way through. It's just solid aluminum all around where I drilled, plenty of meat. Just 1/8th inch holes.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 07, 2011 11:00PM
really makes me want to ditch the impreza and scoop up the compact i have had my eye on. stupid lack of money.
