OK, So I have looked at all kinds of threads on this topic and looked at all kinds of online stores for the parts I might need but always seem to come up short and don't want to be putting adapters on adapters on adapters to rig stuff together all over the place.
So, here is the setup I want to do: Stock 22mm VW Master cylinder with M10x1.0 ports (all VW stuff is bubble flare I think) FRONTS--easy get hard-line and 4 tube-nuts-----> Softline to stock front calipers--easy, use stock lines or SS line kit I already have. ....done! REARS--this is the hard part as the system needs to look something like this: 2 lines from master cylinder----> 2 bulkhead fittings through firewall----> stock prop valve (2-in 2-out)---> "T" fitting to single line---> handbrake in----> handbrake out---> brake light pressure switch---> "T" to double lines---> Each line to bulkhead fitting at rear wheel well---> Softlines to calipers (banjo at caliper). The big problem seems to be that the only bulkhead fittings I have seen are AN which requires adapting back and forth. M10x1.0 metric bulkhead fittings would make life lots easier.... |
Josh,
I have not seen metric bulk head fittings in any catalogs. However, it is possible that JVL knows of some obscure cars that had these. Metric T fittings can be had from the old Bugs. You may end up having to make brake lines with a bubble flare on one end and AN flares on the other. Robert. "You are way too normal to be on Rally Anarchy." Eddie Fiorelli. |
Josh, I use metric only where I absolutely have to. ie at the calipers and the master. I prefer to use a male/male M10 to -3 adapter and consider it a permanent thang. All other junctions and fittings I do inch just to make things easier. -3 bulkhead in steel is findable for less than the common $8-14
Then everything is easy. And of course a simple electrical switch instead of a pain in the ass pressure switch simplifies things even more. Then for the flex hoses if you don't want to assemble your own, now you can buy -3 swivel hoses for cheep from any circle track joint pre-made. OR M10 x 1 bubble flare nut to terminate hard lines at master: http://www.thetoolwarehouse.net/p-6420-sur-r-br230.aspx S.U.R. & R. BR230 M10 x 1.0 Bubble Flare Nut (Euro, Domestic) Order No. SRRBR230 0.0 Write a Review List Price: $6.11 Sale Price: $3.40 You save: $2.71 (44.35%) Availablility: In Stock Or: S.U.R. & R. BR250 - M10 x 1.0 Bubble Flare Nut (VW, Audi)S.U.R. & R. BR250 M10 x 1.0 Bubble Flare Nut (VW, Audi) Order No. SRRBR250 Sale Price: $4.75 S.U.R. & R. BR255 - M10 x 1.0 Bubble Flare Nut (Ford)S.U.R. & R. BR255 M10 x 1.0 Bubble Flare Nut (Ford) Order No. SRRBR255 Sale Price: $3.85 |
Yes, but I am using the 2-in 2-out stock prop valve |
Cosworth Paulinho Ferreira Mod Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
token-negro Kendrick Gray Ultra Moderator Location: Renton, WA Join Date: 04/20/2009 Age: Midlife Crisis Posts: 176 |
Yes the cheap ones true, but the Tilton and AP units are top notch and I normally recommend them for applications that dont allow a balance bar. Trust me, these two are good and give you an adjustment from 30% to 80% of pressure reduction. |
mack73 Jason Wine Mega Moderator Location: Seattle, WA Join Date: 02/20/2006 Age: Midlife Crisis Posts: 448 Rally Car: Started a Golf... Never Finished It |
