AE86 Cage Update?
Posted by sidewaez
sidewaez
Blake Lind
orange AE86
Re: AE86 Cage Update?
April 11, 2011 01:01AM
how's this look for a-pillar support bars and more door bars?
April 11, 2011 09:08AM
That'll work. And holy cow, completely necessary. Look at the tight radius on the bend at the A-pillar. I don't think that's even a legal radius bend.
April 11, 2011 10:39AM
Wow! I just saw that bend..how do you do that? I wonder if it is notchesd and welded back together?
I would fit in another brace, maybe a foot long or so across that bend. Or a taco gusset.
sidewaez
Blake Lind
orange AE86
April 11, 2011 11:14AM
Yeah that bend prompted us to put in the supports, Villy was trying to kill us! It is one continuous tube no notching. we can put in a taco gusset, do I need to put any gussets on the a-pillar support bar?
April 11, 2011 03:03PM
I would ask for one on the A pillar to upper door bar, either front or back, but not required as this is just a voluntary upgrade.
Greg Donovan
Greg Donovan
95 Impreza Sedan
July 23, 2011 09:39AM
Curious how this has turned out. What did you guys do about that crazy tight bend?
July 23, 2011 10:41AM
I had not followed this thread but I saw the bend this AM and read all the comments, Gene et al are right. This tight bend will result in buckling of the A-pillar tube on a hard load (flip over onto roof). This will put all of the load on the A-pillar support; that is not the intent of the design behind this; the load needs to be shared between A-pillar and A-pillar support.
The only way to fix this is to put a brace across this bend, as in Gene's first suggestion. A gusset will not do, as gussets are neither intended for, nor capable of, preventing structural bending.
The gusset idea on the A-pillar support is good; that support is in a place that is subject to side impacts, and that lower joint could break like any side bar joint.
Mark B.
sidewaez
Blake Lind
orange AE86
July 23, 2011 01:59PM
Greg Donovan
We put in a taco gusset, Gene and Mike Hurst both looked at it closely at Olympus and sort shook there heads and laughed, but they passed us right through.
the car has been rolled two times already without the a-pillar support bar, the first time was a pretty good hit right at the top of the windshield and it survived.
July 23, 2011 09:00PM
Good report there. Was the 'pretty good hit' stright down onto the roof or more form the side? That makes quite a difference on what is bracing what and where the loads go. I did not notice before, but with it welded to the shell right at the bend, plus with the strut supports (visible on the far side), the shell kept it from bending...! A different kind of A-pillar support, and good interconnection of strengths......but not what is intended in the designs on which the rules are based, and not a good general thing.
BTW a tube across the gap between the A-pillar support and the A-pillar would brace it too.
Mark B.
Greg Donovan
Greg Donovan
95 Impreza Sedan
July 23, 2011 09:29PM
Have any new pictures to share?
July 24, 2011 12:07AM
Greg Donovan
Any?
Youse leaving the door mighty wide open there considering where youse be writing!
Greg Donovan
Greg Donovan
95 Impreza Sedan
July 24, 2011 02:19AM
Greg Donovan
Any?
you make that sound like a bad thing. Could be cars or it could be more stuff like zimmer's avatar. Of course it could be something unpleasant too but I am willing to take that chance.
sidewaez
Blake Lind
orange AE86
July 25, 2011 05:58PM
this is the only one I had all loaded up
