sidewaez Blake Lind Professional Moderator Location: Hillsboro Oregon Join Date: 06/09/2009 Age: Midlife Crisis Posts: 233 Rally Car: orange AE86 |
Joel and I have the roof off the Corolla right now and are considering adding some roof bars. It's my understanding that the current cage is grandfathered in and doesn't technically need any updating and it would be purely to increase our safety. I'm not sure what the accepeted method for updates is, the cage is out of 1.5" and has an SCCA Logbook it was built by the original owner "Villy" around 2003.
Here are some pictures: ![]() ![]() |
"Grandfathering" isn't a kingspass forever. It can be dropped at anytime a sanctioning body feels the need to upgrade safety. So...the more important bars are actually another door bar and the A pillar support, roof bars would be 3rd on my list. I would do all 3 if it were me, and maybe consider doing an actual X in the main hoop just for grins and giggles.
I remember when that car rolled a few years back. |
Billyee Billy Irvin Ultra Moderator Location: Puyallup Washington Join Date: 06/06/2010 Age: Midlife Crisis Posts: 156 |
Is there something wrong with---from rules perspective only----the dual diagonals??? And Blake, do a V from center of main hoop V-ing forward---seems the best head/helmet clearance. And yeah a low X in the doors---its sorta why snot since its easy---but thing what a broken rib does when it pokes thru your lungs. I've cracked ribs and they hurt, broken is even nastier. |
For the roof brace, think along what John has said: Hed and helmet clearance. I always tell folks to mount in the seat in the actual positions, and see where your head and helmets set, and make the decision. A V is usually best but I have run across one car (a Focus) where the X in the roof was better for head/helmet clearance than the V. I prefer a sill bar and single sloped side bar. I don't understand the dual diagonal question, John. Regards, Mark B. |
Rallymech Robert Gobright Super Moderator Location: White Center Seattle Join Date: 04/27/2008 Age: Possibly Wise Posts: 1,292 Rally Car: 91 VW GTI 8V |
John, are you asking about the V bar in the center hoop (dual diagonals??) ?
And I'm with Mark on the door bar configuration. I like a straight lower and an angled upper rather than the X style, or a straight lower and a shallow V'd upper. Edited 1 time(s). Last edit at 03/14/2011 06:27PM by heymagic. |
I's a askin if you know any rumblings to ignore the FIA spec which CLEARLY give the options of an X in plane of main hoop----like everybody faddishly has been doing, or dual diagonals aka an X from MAIN HOOP both sides to rear.? |
Why in section 253, of course. Where else? |
For all cars homologated after xx Jan 200x. As I read it it seems pretty clear that you EITHER do main hoop X or 2 diagonals. But wot da fock do I's knows? let's see: Cars homologated before 01/01/2002 : The cage must have one of the diagonal members defined by Drawings 253-4, 253-5, 253-6. The orientation of the diagonal may be reversed. In the case of Drawing 253-6, the distance between the two mountings on the bodyshell/chassis must not be greater than 300mm. Members must be straight and may be removable. The upper end of the diagonal must join the main rollbar no further than 100 mm from its junction with the backstay, or the backstay no more than 100 mm from its junction with the main rollbar (see Drawing 253-52 for the measurement). The lower end of the diagonal must join the main rollbar or the backstay no further than 100 mm from the mounting foot (except for the case of Drawing 253-6). Cars homologated as from 01/01/2002 : The cage must have two diagonal members on the main rollbar according to Drawing 253-7. Members must be straight and may be removable. The lower end of the diagonal must join the main rollbar no further than 100 mm from the mounting foot (see Drawing 253-52 for the measurement). The upper end of the diagonal must join the main rollbar no further than 100 mm from its junction with the backstay. Hmmmm where did I see it? Oh re roof: 8.3.2.1.3 Roof reinforcement : Cars homologated as from 01/01/2005 only : The upper part of the safety cage must comply with one of Drawings 253-12, 253-13 and 253-14. The reinforcements may follow the curve of the roof. Gets more interesting: Windscreen pillar reinforcement : Cars homologated as from 01/01/2006 only : It must be fitted on each side of the front rollbar if dimension "A" is greater than 200 mm (Drawing 253-15). It may be bent on condition that it is straight in side view and that the angle of the bend does not exceed 20°. Its upper end must be less than 100 mm from the junction between the front (lateral) rollbar and the longitudinal (transversal) member (see Drawing 253-52 for the measurement). Its lower end must be less than 100 mm from the (front) mounting foot of front (lateral) rollbar Interesting regarding the cage dimensions: dimensions (mm) Use Main rollbar or Lateral rollbars according to construction......................45 x 2.5 (1.75"x0.095") or 50 x 2.0 (2.0"x0.083" ![]() Lateral halfrollbars and other parts of the safety cage (unless otherwise indicated in the articles above)..............................38 x 2.5 (1.5"x0.095") ...............................................or..40 x 2.0 (1.6"x0.083" ) What's this? Second one down is drawing 253-21, third one is 253-22 ![]() It says clearly: 8.3.2.2.3 Diagonales de jambes de force arrière (Dessin 253- 21) : La configuration du Dessin 253-21 peut-être remplacée par celle du Dessin 253-22 si un renfort de toit conforme au Dessin 253-14 or for youse guys: 8.3.2.2.3 Backstay diagonals (Drawing 253-21) : The configuration of Drawing 253-21 may be replaced with that of Drawing 253-22 if a roof reinforcement complying with Drawing 253-14 is used It says you can use "drawing 253-21" instead of "253-22" IF you use roof reinforcment as i suggested--probably where i saw it---like in FIA drawing 253-14, All this is of course reading both the English and the French which of course isn't Mid-westese which I don't speak or even understand. Edited 1 time(s). Last edit at 03/14/2011 09:43PM by john vanlandingham. |
Hey Blake, you gonna do some prophylactic stitching in the front end?
And maybe take a page from Ford and add a gusset where the inner chassi leg meets the firewall? Well ya oughtter. See in the piccie? I say you're gonna do it sooner or later.. Now means "stitch" Later means "repair, pull car on frame rack then stitch." |
slidewayswrx Patrick Darrow Infallible Moderator Location: Portland OR Join Date: 12/30/2006 Age: Midlife Crisis Posts: 379 Rally Car: Swedish John Deere |
