I don't see how putting a complex bend in there makes the 1/2 lateral joint more square. Looks like it makes it less square? |
Not the direct connection. The one that's near your helmet that connects 12-15 inches or so outward of the junction.
And back to the rear stays. Here's a good question for you tech inspection types. Does the main hoop X have to be welded to the main hoop X? Or if you had a straight bar that ran longitudinally between the bottom of the main hoop, can the bottom of the X connect within 100 mm on that? Just trying to maximize the space in the upper X to potentially be able to fit a helmet through there. Also, rules state 1.75 for main rollbar, lateral half rollbars, their connections, and at least one continuous door bar per side. Their connections? Would that just be the windshield longitudinal member then? |
Blue is what I interpret can by 1.5" diameter. Rest is 1.75.
The lean back was just experimental. It does however move the main hoop H's intersection back almost three inches, which will be noticeable and give more room for the seat. I just did some quick measurements on the Merkur to get used to the cage software. None of this is precise or being used to actually build anything. Impreza cage design starts soon though. |
modernbeat Jason McDaniel Mega Moderator Location: Dallas, TX Join Date: 12/14/2007 Age: Possibly Wise Posts: 401 Rally Car: 1963 SAAB Historic, 1995 Impreza Open Light totaled at WRC Mexico, 2005 STi Pikes Peak winner |
Well, yes, you are correct. And I was speaking tongue in cheek. But safety cost HAVE gone up. Insurance (which replaces real safety in some places) has increased the cost of preparing a car, outfitting a driver/codriver, sanctioning fees, and is a possible reason for the increase of road closure fees. |
Dazed_Driver Banned Infallible Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
No sill bars? oh I see, just playing ,not final. Edited 1 time(s). Last edit at 03/17/2011 04:21PM by alkun. |
Actually, in the two cars I've rode in, the X is the problem. Sill bars aren't required. I did sill bars plus an X in my car though. I figure the more side protection the better. I actually like the sill and one diagonal style better. And yeah, roughly based on quick Merkur measurements. Wanted to figure out software and what measurements I need to be exact on. |
BillyElliot Billy Elliot Mann Senior Moderator Location: Royal Oak, MI Join Date: 08/11/2008 Age: Midlife Crisis Posts: 557 Rally Car: 1996 Honda Civic with VTEC YO! |
I agree with the sill bar. But a lot of WRC cages don't have them. I would think stump intrusion block is a good thing. Maybe for the fact that you take a tree stump and damage the sill bar, you're out? Didn't that happen to Gronholm at one rally?
The problem with my car is not the X, but the V in the rear stays. It pinches too much at the top and doesn't allow me to fit my helmet behind us. Kind of a bummer if you ask me. I would like to have have two helmets sitting in the co-driver's lap on transits. I was thinking of helmet hooks, but i've heard of them bouncing up and cracking windshields at times too.
sidewaez Blake Lind Junior Moderator Location: Hillsboro Oregon Join Date: 06/09/2009 Age: Midlife Crisis Posts: 233 Rally Car: orange AE86 |
In the cars I've ridden in with an X, the problem isn't with getting the helmets through after you've taken them off, it's recovering them afterwards.
![]() The X is really quite a PITA if you have a two-door. Can you figure out a way to put the helmets in the trunk? Or is that space going to be taken up with a fuelcell and the spare? |
hmm, I drew some lines, it looks like when you rake the main hoop back, and run the X to about 4 inches from the half laterals, and then run the little corner tube back from the roof bar to the half lateral, you actually DO get the most clearance. Now, obviously, it DOES depend on where you sit, but in general, that configuration DOES give the most room. That is the lime green line. It's a bit buried..
