Re: threaded rod and spherical rod ends
March 22, 2011 11:18AM
Reamer
Im looking for a mono ball or something rally tough for the front lower control arms of 08 up Subaru?
They changed the way the lower hooks to the car and it doesnt look to have rally strength or travel built into it.
Parrin makes an insert but I think its more track stuff then rally.
Send us sample!
Robert Culbertson
Out of this dumpster fire
March 22, 2011 11:33AM
If you wanted to spend the money, Aurora makes staked and standard teflon lined spherical bearings. They aren't cheap, they are actually scary expensive when you get to bigger sizes. They are air craft grade and will take a ton of abuse too. Don't worry about getting the "high-misalignment" sphericals, they cost 2x. You can do the same thing with some machined cones or a spacer.
For the Subaru control arm, you can probably machine an aluminum or steel carrier that holds a spherical bearing (staked or std) and then use a BIG snap ring or a bolt down plate to hold it in. If you know anyone with simple machine tools (lathe and a milling machine) this can be done in an evening. Remember, when things don't fit... JB-Weld/Loctite!
Ascona73
Bob Legere
1971 Opel Ascona
March 22, 2011 11:48AM
I just got these yesterday for a hillclimb car project I'm working on. 3/4" high-misalignment monoball with Chrysler-style tapered pin. Pins cost me $18 each (Coleman), monoballs $59, housings $17 (both from UB Machine).
March 22, 2011 12:04PM
whats the dimensions on the taper? OD at top and bottom and distance? those may work for the XR arms.
March 22, 2011 12:19PM
Ascona73
What I've done is go to a larger size---7/8" (close enough to the 22mm ID Ford used on their arms as ball joint, maybe 006-007"winking smiley and then sleeve down to the size needed, and incorporate the shoulder that the High Misalignment bearing has integrated but then a good bearing is 20-25 bucks rather than $59. Alternately a stepped down spacer with a nice large register---that's what all the shiny stainless things are.
Important thing is I can be assured that by straight copying the size of the GpA Ford stuff that the load capacity of the bearing is good enough for what we're doing---since it was good enough for their speed and power.
Ascona73
Bob Legere
1971 Opel Ascona
March 23, 2011 12:04PM
I'd take John's advice for the XR since he works with them all the time and I know nothing about them.
However, in the 'just FYI' department, here are the taper dimensions.
Taper overall height: 1.150"
Taper diameter at top: .750"
Taper diameter at base: .890"
March 23, 2011 12:59PM
You have? ETA on an actual product?
Sofa King
Monika Hawkinson
2006 Tacoma
March 30, 2011 12:01AM
Grant, what "actual product" are you talking about? Pronouns can be sooooo ambiguous!
March 30, 2011 11:56AM
Adjustable TCA/comp struts.
Sofa King
Monika Hawkinson
2006 Tacoma
March 31, 2011 01:59PM
Yeah, no.
Haven't seen anything yet. Just talk. And one purple aluminum thing that he bought to copy.
March 31, 2011 04:52PM
Sofa King
Yeah, no.
I thought you were going to call when there was time to make a CAD drawing?
Sofa King
Monika Hawkinson
2006 Tacoma
April 05, 2011 04:32PM
Do I have to remember everything?confused smiley
biknman
David Potter
03 WRX Wagon
April 23, 2012 04:57AM
Good info getting ready to make my own adjustable front LCA so the sources will be very useful.
Dave Potter
Potter Racing
PHA #139 S3
“There are only three sports: bullfighting, motor racing,
and mountaineering; all the rest are merely games.”
• Ernest Hemingway
http://biknman.shutterfly.com/action Link for my photo album smiling smiley Enjoy
