Soooo
Posted by Racinkid13
Max
1983 MKI GTI
Soooo
April 18, 2011 11:17PM
Working on my garage utensils.
http://i4.photobucket.com/albums/y121/racinkid13/Misc/P3280016.jpg
http://i4.photobucket.com/albums/y121/racinkid13/Misc/P3280018.jpg
http://i4.photobucket.com/albums/y121/racinkid13/Misc/P3280020.jpg
next.....bender and chop saw. Really got it for my Taco, doing an SAS on it. But the bender and chop saw will be for roll cages in that and the Jackalope.
Edited 1 time(s). Last edit at 04/18/2011 11:18PM by Racinkid13.
Re: Soooo
April 19, 2011 10:06AM
Hey Max,
Jim and I were talking the other day and wondering what you are up to.
I'm on my way to Alaska for a few weeks. When I get back we should get together with Jim and Christy.
Re: Soooo
April 19, 2011 11:22AM
Nice welder!
Get one of these instead of the chop saw; way better. http://www.google.com/products/catalog?client=safari&rls=en&q=milwaukee+band+saw&oe=UTF-8&um=1&ie=UTF-8&cid=12759432239122107150&sa=X&ei=ObatTfbJNsPciAKrtfnYDA&ved=0CFYQ8gIwBQ#
Reamer
Jeff Reamer
Subaru
Re: Soooo
April 19, 2011 02:12PM
Defiantly go with A carbide tooth low RPM chop saw. I have both and I havent used the POS band saw in 3 years at least. I use the chop saw at least once a week. Theres nothing out of the car that a chop saw cant cut better. And if your cutting a cage out then you would use a saws all. that will work better then that junk ban saw.
It was brought up before about angles of cut. The chop saw and band saw will cut the same angles because of guides on the band saw limit angle. The blade will come off that style band saw if you slightly get off track. The blade binds up and spins itself off.
Most of the time I cut 90 degrees and use the tube notcher to make the final angles. The chop saw blade will also last 100 times longer then a band saw blade. A chop saw will cut 1 3/4" DOM tube in approx 3 to 5 seconds.
I know this is a little rant on my part but I started with the band saw and ended up with the chop saw that was $50.00 cheaper.
Re: Soooo
April 19, 2011 05:05PM
that's a nice mig welder
<----jealous.
Re: Soooo
April 19, 2011 05:18PM
I have a Milwaukee porta-band. Close to 20 years of use on that old saw. I do this every day professionally. I don't have a chop saw. Porta bands do require the occasional blade put back on but the big difference for me is the ease of use. I can clamp a tube in the vice and cut the ends easily. With a chop saw it pretty much requires two people if the tube is over a couple feet long. Porta band goes where ever needed, you go to the chop saw. Always another side to a coin smiling smiley
Reamer
Jeff Reamer
Subaru
Re: Soooo
April 19, 2011 05:40PM
The best use Ive found for a porta band is doing conduit for electrical wire. It is the bomb for that I will agree.
A race car garage should have a spot to store your tube. Right above or below that is a chop saw on a bench with a block on 1 end to support your 20' long tube. Ive never needed help cutting tubing for a cage. Also try to hold that new 20' piece of tube in a vise and clamp it.
Re: Soooo
April 19, 2011 07:48PM
I think 'personal preference' wins the 'chop saw vs band saw' debate. haha
Re: Soooo
April 19, 2011 11:46PM
What happens when you have a 10ft piece cut for the 1/2 lateral and it has a 35* bend and a 45* bend and a 10*kink for the A pillar taper ? How do you gracefully notch the ends with a chop saw? Very easy with a porta band and the vise to hold it. Cutting down 20 footers with either tool is easy stuff.
SgtRauksauff
Jorden
Re: Soooo
April 20, 2011 11:20AM
Just get one of each. You can never have too many tools. And no need to compromise!
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
Re: Soooo
April 20, 2011 11:26AM
vice? clamps? Bah! Girly stuff! I just hold the 20 footer in one hand and the porta-band in the other, and presto choppo!
Reamer
Jeff Reamer
Subaru
Re: Soooo
April 20, 2011 11:33AM
I use a V block and rougher in a lathe to do the notches works very well. The last I new neither a band saw or a chop saw could cut round notches.The angle really doesnt matter at a rough cut stage. You can come up with that 1 spot where it may be handy but I wouldnt buy based on that 1 spot.
I agree with Jon on this. It is personal preference!
Like I said before I have a Milwaukee porta band (from my construction days)and a chop saw wins 99% of the time. So for a fab race garage I would go with the chop saw.
That is a nice welder by the way. Lots of fun projects you can build now.
RallySol
Eric Larsen
awd '93 Honda del Sol
Re: Soooo
April 20, 2011 01:59PM
Been thinkin' about selling my 135 to pick up one of those machines.
I've used that milwaukee porta-band with a chop stand and its real slick until I need to cut any sort of angle. Next saw I pick up will be a proper band saw for metal
KK6EAR
fliz
Chad Eixenberger
1988 VW Golf #687
Re: Soooo
April 20, 2011 02:11PM
How much did that run you, if you don't mind me asking.
I'm looking at picking one up soon.
Re: Soooo
April 20, 2011 11:58PM
Reamer
So what the heck is a v block and rougher in a lathe? (I don't get out much) I learned to notch tubing with a torch back in the old days...
