Holy Crap. I mounted a Yoko A035 on a H.F. manual changer. Now with video*
Posted by biggreen96
biggreen96
Chris Caylor
Old Legacy- not very stock.
April 22, 2011 12:04AM
Went to get them mounted at the Schwab, too busy, and wouldn't let me leave them to do in the morning. Next place down the street was busy too so I came back home. I tried to mount a Pirelli once before on the manual changer and had no luck. This time I had good weather and anger at Les Schwab driving me.
It wasn't easy. But it wasn't like I needed the strength of a linebacker. I'm a skinny punk. AND I was just in the hospital getting 3 pints of blood on Tuesday.
I only got three before I got hungry and went inside so I'll try and make a video for the 4th so all you other cheap-asses can benefit. I mounted snows on steelies right after I got the thing so once I've got these mounted I will have broken even.
[url=
][/url]
Brap Brap.
Edited 1 time(s). Last edit at 04/22/2011 06:22PM by biggreen96.
Re: Holy Crap. I mounted a Yoko A035 on a H.F. manual changer.
April 22, 2011 12:23AM
this I want to see.
did some snows on mine too - that was (relatively) easy.
then I decided to flip some of my 205/50 r-comps that are on 6" wide rims (they were cheap!). While I did manage it, it wasn't pretty. 60-90 minutes each...
assume you've actually got yours bolted into concrete? (attaching it to a pallet works for me, but just barely)
biggreen96
Chris Caylor
April 22, 2011 12:48AM
There is no effing way you could do a rally tire without the thing bolted down. I'll work on getting that vid..
Brap Brap.
April 22, 2011 04:10AM
OK, now manually mount a Michelin rally tire and I'll realllllly be impressed.cool smiley
biggreen96
Chris Caylor
April 22, 2011 07:04AM
Challenge accepted. It's my spare.
Brap Brap.
Ascona73
Bob Legere
1971 Opel Ascona
April 22, 2011 09:19AM
Been there, done that!
Mounted a set of four Michelin tarmacs and 6 Michelin gravel tires about 10 years ago on my manual 'Roger Kraus Racing' tire mounter. Not fun however....
Lube, lots of lube....
April 22, 2011 09:57AM
Ascona73
the solution to most problems in life.
biggreen96
Chris Caylor
April 22, 2011 11:16AM
Ascona73
Babe I'm kinda low on funds, I hope you don't mind soapy water.
Brap Brap.
SgtRauksauff
Jorden
April 22, 2011 01:39PM
I like Murphy's Oil Soap.
regular passenger-car snows aren't too hard, sometimes you can get the bottom bead on without even having to use a tool. just push/twist, done.
Never had the chance to mount an actual rally tire yet, but when I do my autoX/HPDE tires (205/50-15 Hoosiers, 225/50-14 hoosiers and hankooks, 255/40-13 Hoosiers, and some 22.0x7.0x13 goodyear SRF slicks,) I am SUPER SUPER SUPER glad that I hunted for a couple years and finally bought a tire machine. Those darned low-profile fookers are hard to do even with a Hunter TC3500.
The twisting/bending/muscling required to use the manual changer (bolted to the garage floor using 3 out of the four bolt holes) on eight tires (swapping winterforce snows for all-seasons, so I could go to a rallyX with the snows) is responsible for putting my back over the edge and doing the final damage to my L3-L4 and L4-L5 discs, which were severely crimped in that process.
Thinking about it, I paid more for my mounter and balancer than I did for most of my cars. lol!
--sarge
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
April 22, 2011 02:30PM
I just started using a HB mounter. Been doing rally and snows but in 13 and 14" sizes. The HB tire iron is a POS, picked up a Ken Tool Serpent Mounting Iron and a couple of bead keepers. Now its pain free and less of a chance of screwing up the beads.
biggreen96
Chris Caylor
Re: Holy Crap. I mounted a Yoko A035 on a H.F. manual changer. Now with video*
April 22, 2011 06:23PM
Added the vid to the first post.
Brap Brap.
April 23, 2011 10:55AM
I was waiting for the bar to hit the vice grips into the nuts America's Funniest Videos moment....
I don't think you actually need the vice grips. Start the tire on just after the valve stem location. You had the valve stem more in the middle of the process. The bead can hit it and tear the rubber stem plus it is one more thing stopping the bead from dropping into the center. Do you have the shoe for de-deading tires? That would help push the bead into the center while mounting also.
Not too bad. The yokos are pretty easy to mount tho! But on a nice sunny day with warm tires, it's possible.
It is too bad tho that your gonna have to unmount that tire you did in the video...You have the "inside" on the "outside" of the rim...
biggreen96
Chris Caylor
April 25, 2011 09:59AM
Did that on purpose. I was told Olympus was mostly right turns so I have insides out on the passenger side...
Fu k.
Brap Brap.
krisdahl
Kris Dahl
Integra, Civic
April 25, 2011 01:01PM
I'm not sure how true that is that Olympus is mostly right hand turns.
But I'm pretty sure the orientation of the tires isn't as critical as it seems. Pat Richard told me once that they've run tires wrong side, backwards, etc. and it never seemed to matter.
