Fuel test port for Honda
Posted by RallySol
RallySol
Eric Larsen
awd '93 Honda del Sol
June 19, 2011 11:54PM
Any suggestions? Trying to get ready for NNR.
Thanks!
KK6EAR
Re: Fuel test port for Honda
June 20, 2011 12:01AM
Call or e-mail the organizers, it may not be critical for you. I have never been asked at tech to show my fuel test rig. I think it is for the top cars who may have something to gain from running secret fuel blends.
June 20, 2011 01:57AM
We don't check at tech for those anymore on regional cars since we don't have the equip to test fuel samples. It is not a safety item.
June 20, 2011 02:01PM
I'm pretty sure the NNR organizers aren't going to check for a fuel sample or require a fuel port.
June 20, 2011 02:22PM
Oh nice, I was just starting to wonder about this. I guess I won't worry about it, then!
gkd
George Doganis
Civic
gkd
June 20, 2011 02:59PM
Good to know Michel. In previous SW regional RA events Doug N. has been checking the presence of fuel ports and issued warnings.
As far as Honda Fuel Test Ports go: http://www.angelfire.com/oh5/sccafuelports/page3.html
I sent him(Bret) the banjo bolt off the fuel fliter where the filter-to-fuel rail hose goes and he tapped/brazed a fuel test port right on it. You can also cut the the hose and put a "T" with the port installed on it.
June 20, 2011 03:27PM
He is where I got the one for my car. He did pretty much the same thing for the VW - tapped a banjo bolt (to my fuel distributor) and put a schraeder valve there.
As for checking it and so on, technically it is required by the rules so you can get dinged on it. So you'd best be planning on putting one in at some point, unless
the R-A rules change. All I'm saying is that I'm not planning on requiring the port or testing at NNR. I don't have the equipement to do it. However, it's possible you could run into some other better-equipped cranky scrutineer at another event and you don't have one or you're running the wrong additive in your gas he is within his rights to toss you.
June 20, 2011 04:05PM
The RA rules be changing...at least to the point Hurst said not to check for them at Olympus.
June 20, 2011 04:10PM
But But! BUT!!!! It must mean they don't dare check the VT Subies who must have some exotic secret formula----that's the only reason Higgins is winning!
More favortism!!!!!
This is an outrage!!!!(that enough!!! for the dimwits to understand parody?)
June 20, 2011 04:29PM
Probably won't help you much, since I went with a custom AN -6 fuel setup.
But I am running this fuel sample port:
http://www.pegasusautoracing.com/productdetails.asp?RecID=3447
connected to this AN -6 T fitting:
http://www.pegasusautoracing.com/productselection1.asp?Product=1069
And I sealed the fitting with Permatex Aviation Form-A-Gasket No. 3 Sealant:
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_sealants/auto_Permatex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm
June 20, 2011 05:33PM
More favortism!!!!!
But, but, but we do check the national cars for fuel samples. We're not talking about national open class cars. The ports are still required but it is a competition item not a safety item. We don't check for gear ratios or camshaft duration at tech either. We've never checked regional cars for fuel samples and if NNR isn't doing so then no need to stress anyone out over fuel ports.
We did find silver metal flake in a guys fuel one year...decided the fuel pumps were getting ready to take a crap.
June 20, 2011 06:48PM
In all events that were a regional running with a national, they checked for my fuel port. I was able to play dumb at LSPR (my first rally) but when I did my next event, Sno*Drift in 2009, they put in my logbook I needed a fuel port.
I would just put it, as it's $30 or so in parts.
June 20, 2011 08:01PM
I've often wondered, especially with a fuel cell, if having a really long straw would count as a fuel test port.
fliz
Chad Eixenberger
1988 VW Golf #687
June 20, 2011 10:44PM
If you've got a fuel cell, you've probably got an AN fitting near the cell. Should be very simple to put a test port on there.
My test port was at the fitting where the fuel lines came into the car. I put it on the return line so it wasn't under pressure.
But I agree that it's not something that should be required for regional cars. If you're never going to make them use it, then why make them have it?
June 20, 2011 11:11PM
Turkey baster grinning smiley
