Who can build me a rally car?
Posted by WRCWRXSTI
WRCWRXSTI
John Turner MacCallum
1988 Mazda 323 GTX
June 26, 2011 09:35PM
who here could build me a rally car and how much would it cost? william told me he does cages, im thinking a merkur, an impreza, or a volvo.
Re: Who can build me a rally car?
June 26, 2011 10:17PM
If I had the time, I would build you a car. Merkur or Volvo. Figure roughly $20,000 start to finish. That would be the same spec as my car. 250 hp, the good brakes, JVAB suspension. Good diff and ratio, skid plates and all the other necessary stuff. The price could go up for sure depending on the spec of stuff, you can spend $1000 on seats and belts, or $6000 on seats and belts for example.
Buy the sub $3000 Justy in Vancouver and go have fun on stage and make sure you can sustain the habit. We spend $1500- $2000 per rally, and we try to do it on a budget. It really adds up.....
WRCWRXSTI
1988 Mazda 323 GTX
June 27, 2011 12:43AM
what about for a fwd or rwd car with a little less horsepower? im actually very willing to buy a car but i havent been able to find any online within like 2000 miles...
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 27, 2011 01:48AM
WRCWRXSTI
you will find that the type of car has very little impact on the minumum cost of building it into a rally car.
there are certainthings that cost a minimum amount regardless of make, power and driveline configuration. things like cage, seats, harness and basic safety requirements being among them.
in all seriousness you could get a basic starter car for around 9 grand on top of the purchase price of the shell. of course it can be done for less, or more... it all depends on what you need/want and what you can do yourself. your choices are good, fast and cheap. pick two.
also, it should be noted that the 9 grand price doesn't do anything with engine, trans or brakes.
Edited 5 time(s). Last edit at 06/27/2011 02:14AM by Greg Donovan.
June 27, 2011 02:04AM
With Rwd you tend to be able to get upraded parts cheaper,
Ring and pinoin, close ratio gear kits, limited slips.
This would be a personal list of cars I would get
Honda civic coups or hatch 92
Merkur Xr
Volvo 240
Nissan 240
Focus for my Rwd plans
Any log booked subaru and do the quick and dirty Rwd to it
Ae86
Bmw 318ti or any e36 shell
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 27, 2011 02:20AM
Merkur Xr
Volvo 240
Nissan 240
Ae86
good advice.
with all the time i have spent planning i have learned that it is best to start out by building a rally car around the drivetrain.
there are cars that are expensive to upgrade and operate. a cheap little suziki swift might be tempting but wait untill you try to find a close ratio gearset and a LSD for it. ouch.
there are also cars that are cheap to upgrade. the volvo 240, xr4ti and subaru (for AWD open light non turbo) come to mind for this path.
which one do you want?
remember that cheap and expensive are VERY relative terms in this context.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 27, 2011 02:22AM
oh, and lots of people can build you a rally car. but do your homework. cheap aint always better.
there are many in your area.
June 27, 2011 02:24AM
[/quote]
also, it should be noted that the 9 grand price doesn't do anything with engine, trans or brakes.[/quote]
That Xr I got would be one of the cheapest routs you can go.
I told you the list of part that are on it
large van and computer
Welded rear diff
T5 swap
Cut and welded driveline
Hydrolic clutch
Fresh motor, hone, rings, bearings, valve springs, valve seals, light porting just clerk the crud. Castings past the valves, ported exhaust,
Cosi housing intercooler
Saab radiator twin fan
Rx7. Oil cooler with quick fit lines and remote filter
Rotated intake
Matched and cleaned injectors
Add all that up I want 1000 so I can move forward on my focus
You don't have to take the second shell I can get rid of it
Soo 1000 there
I think you can do a cage
safty stuff for under 6500 with the car
By the time you spend 9000 you will be on your way to a bitchin xr
WRCWRXSTI
1988 Mazda 323 GTX
June 27, 2011 03:46AM
Welded rear diff
T5 swap
Hydrolic clutch
Rotated intake
Soo 1000 there
By the time you spend 9000 you will be on your way to a bitchin xr[/quote]
so it drives? i could drive it home tomorrow and then get the seal fixed? or does it leak oil like crazy?
June 27, 2011 08:05AM
No it needs some loven too bad you have to drive it home that elliminates a ton of potential good deals.
June 27, 2011 09:44AM
William,
Give him a dollar amount for a running driving XR caged rallycar. Something he can fly across the country and drive home. You have a car you need to get rid of, he needs a car.
Sell him a Caged, Running, Driving rally car, with something slightly better than a milk crate to sit on and let him do the rest of the safety, motor, suspension and brakes. Put a little elbow grease into it and you guys should work out a deal.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 27, 2011 10:02AM
William,
worst part is he doesnt need to fly across the country to get it. they are both pretty damn close together. john is on in island up by victoria BC and william is in redmond. if i were that close both the XRs would be at my house by now instead of the impreza.
maybe john (not JVL john) can kick in some extra cash and a little sweat equity some afternoon to get the car fixed and drive it home. that way he can start to get intimate with the car, get to know some of the rally people in the area and learn a thing or two.
Edited 3 time(s). Last edit at 06/27/2011 10:05AM by Greg Donovan.
June 27, 2011 10:06AM
WRCWRXSTI
It drives.
You press a seal into a seal holder and bang it in before you drive home.
I put a link already. $6.50 to $8.50
June 27, 2011 10:17AM
Greg Donovan
quote]
Doh! I was thinking fox mustang guy. No shit if you are that friggen close, what is taking so long? Rent a car hauler for a day and move some cars.
I still think the running, caged idea was a good one tho, That's 70% of a rallycar project right there.
June 27, 2011 11:29AM
Well he doesn't need to rent a truck and hauler cause he can barrow a nice diesel van and dolly from me.
Same as William did years ago.
Problem is the ferry charges about one million dollars for a van, dolly and car.
And he needs sumpin that runs so he can avoid the million dollar ferry charges and has NO storage.
That island is small, and is really a resort island so the square footage is at a premium---the space a car takes up could be rented to yuppies from Seattle for a thousand bucks a week...
I really don't know hows he's thinking he can do a project of any sort on the island, even if the major build is done elsewhere there's constant revisions, improvements, fixin and fiddlin to do and that means a space to work---along with REPAIRS. Oi.
