Re: 1994 Subaru Legacy Turbo, gots to go to NA sad smiley
September 09, 2011 11:45AM
A1337STI
I sorta get their rule, and i don't. Is their rule for the laywers , insurance company. i could see insurance guys reducing their rates slightly that only experienced drivers are allowed in the fastest 3 classes . (open, super production, G5)
Not a lawyer rule, a nanny rule. The insurance companies don't give a flying fuck if you kill yourself rallying - you've signed away your liability, and the waiver will hold against you, as does common law assumption of the risk. Smoke and mirrors excuse to limit novices from a perceived, but never proven, greater accident rate in AWD turbo cars.
September 09, 2011 12:05PM
A1337STI
And meanwhile any fool can start in a 200 bhp P car, or a 230 bhp Gp2 car...
with short gearing..
Gotta remember both Havir and Niday did basically start with some junk and nearly immediately switch to expensive Subarus which they promptly began flipping, Havir particularly---like 4 violent rolls in 22 events..
In other words, they done did stoopid, therefore logically everybody will be stoopid; better ban stupidity.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
September 09, 2011 12:54PM
ah Of Course... I think anyone who has seen G.doganis , Hoche, Crane, Duplisess , gaylord van brocklin . knows that the speeds are much to low for a G2 car to crash....... . .. .
confused smiley oh wait all of those guys are super fast. lol
well there goes my theory the rule is based from playing a lot of racing video games, and they really like how you often can only use the cheesy cars until you get enough points , and then you unlock the faster cars.
September 09, 2011 01:02PM
A1337STI
that makes more sense than the current rule.
I know we can't talk logic and reason to everybody, and convince them they'd spend way less and have way more reliable car and have way more fun in my favorite 2wd cars---which are only my favorites cause i know how well they work---and how cheap we can get into them for---but this rule forcing people to do shenanigans like in this thread is just flat stupid...
and they can't come back with their ludicrous argument "best practices!!! BEST PRACTICES AH YIEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!!!!!"
Most places most people aren't so deluded that they imagine they must START with a turbo 4wd car---and they grant PROVISIONAL liceneces....
Typical 'Merikuh: shotgun approach, no finess and above all NO THINKING.
alosix
Jason Powers
September 09, 2011 02:12PM
What's kinda sad here, at least for my WRX with stock 8.0:1 pistons in it, running on just the wastegate spring (7psi), I'm roughly equal to a 11.8:1 NA engine (albeit a little cooler intake charge overall). That coupled with a 32MM restrictor is going to be a 'open light' powered car.. Heck you can easily see that in the last few rallies burke and alex have run (driving differences aside) as burke's car is pretty much running a 7psi TD04.
Using http://www.dragsource.com/index.php?navselect=calculators&calctoview=3 to calculate.. Not sure 100% on accuracy, but my gut says it isn't far off.
Its easy enough to check that you are running on just the wastegate spring.. The only caveat there would be messing with its setting..
A1337STI
Alex Rademacher
September 09, 2011 03:54PM
Sounds like we should do a drag race and test out your theory.
http://www.sacramentoraceway.com/ Can you get there by 5 on a wednesday? thumbs up smiley
alosix
Jason Powers
September 09, 2011 04:00PM
A1337STI
I could prob make that work.. smiling smiley would be an entertaining test.
A1337STI
Alex Rademacher
September 09, 2011 05:46PM
Yep, maybe we can get Burke to show up and join the party as well. smiling smiley though hopefully he may be back to a 34mm restrictor and proper turbo by then.
actually that would be sweet, get a great comparison between an RS, a WRX on a 32mm and 7spi, and a wrx on a 34mm and 14 psi ...
anywho /thread jack.
I'm so convinced a "simple" air bypass pipe is the best solution for your car. you could slap a generic cone filter on your turbo air inlet to keep it safe, probably picked up a used one on ebay for cheap, and even resell it for about the same after...
so you should only be out the cost of a by-pass pipe ... which could probably be made at lowes for cheap (might generate a few laugh at rice comments though) hehehe
