dirty_d
Brandon B
wabbit season
VW MK2 Shell for $1000?
June 27, 2011 03:31PM
86 mk2 shell. running but doesn't run good due to 'lectrics. Has a carb'd 8v of some sort and a "rollcage" Not real exciting to me other than as a solid shell with some spare pieces.
The rollcage looks not too hacky in celphone pics, but assumed useless until proven otherwise. Interior appears stripped and painted white.
thoughts?
pics forthcoming hopefully tonight.
Edited 1 time(s). Last edit at 06/27/2011 03:52PM by dirty_d.
Re: VW MK2 Shell for $1000?
June 27, 2011 05:40PM
No old SCCA/RA/CARS/NASA rally logbook then it most likely won't be rally legal. Assume the cage is scrap.
June 27, 2011 10:45PM
Is it white?
I wonder if it's a certain ex-Lemons car I know about.
Either way, $1000 for any Mk2 that has enough metal left to support a rollcage is a steal, even if you have to cut out the cage and start over.
June 28, 2011 03:20AM
Geez, I'm glad I don't live in the rust belt.
June 28, 2011 08:33AM
Fixed that for you.
Is it white?
Either way, $300 for any Mk2 that has enough metal left to support a rollcage is a steal, even if you have to cut out the cage and start over.
dirty_d
Brandon B
wabbit season
June 28, 2011 11:56AM
finally got pics. not too bad really. if it was a lemons car it should be $500 right?
Edited 4 time(s). Last edit at 06/28/2011 12:04PM by dirty_d.
June 28, 2011 12:02PM
They're hovering in the $2500-3500 range now, at least when I get The Itch. A lot of 'em are rusty, too...
Mk3s can be had sub-$1k easily, no idea of condition. But even the base models have a lot of the upgrade parts that you put in a Mk2 anyway.
Edited 1 time(s). Last edit at 06/28/2011 12:03PM by Pete.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 28, 2011 12:41PM
Fixed that for you.
Is it white?
have you ever seen a 15 plus year old car in the midwest?
dirty_d
Brandon B
wabbit season
June 28, 2011 12:42PM
The guy's in Zanesville. Are you interested Pete? I can send you his # he's desperate to move it this week and i don't know if i can get a trailer down there by Friday.
Greg Donovan
Greg Donovan
95 Impreza Sedan
June 28, 2011 01:01PM
that cage cant be even a little legal for anything. why would anyone build a cage with no rear stays from hoop to shock tower?
June 28, 2011 04:42PM
I have no cash and if I did, it would be shoved towards fuel/entrance for a shindig in Tulsa in October.
You may wish to check this out though: http://www.ohiovw.com/forum/default.aspx?g=posts&t=35194
fliz
Chad Eixenberger
1988 VW Golf #687
June 28, 2011 05:00PM
Greg Donovan
Makes you wonder what else on the car he's "fabricated". Because it's probably just as well thought out as that roll bar.
Brandon - Give the guy on OhioVW $250 for the A3 shell, then take it up to Ann Arbor and have a cage installed for $2500.
June 28, 2011 05:24PM
I'd be leery of fresh paint on any car with obviously rusted spots.
That cage sucks. It could possibly be salvaged, but it's got some weird things. As pointed out it's got no rear stays, just the X. It looks like the main hoop V-bars go to the crossbar, not the hoop itself. The doorbars are really far inboard, relatively speaking. No sillbar. Blah blah blah.
And it's got a horrid green valve-cover.
I know you live in the rust belt, but you'd be better off scheduling a vacation to AZ or CA or something, picking up a CL special there, and then having a nice pleasant drive home.
dirty_d
Brandon B
wabbit season
June 28, 2011 05:42PM
I saw that guy on ohiovw and i'm planning a trek down south to see what he has. probably less than an hour drive for me
his pm box is full.
June 28, 2011 08:13PM
I thought that was an indicator of a tidily executed, well thought thru engine build, and the nicest thing on the car.
Go figure.
