Re: 2003 and newer NEON'z
August 03, 2011 11:54AM
SeanP
Quaifes just dont stand up in the Neon's as I have read, requiring frequent repacks of the clutch packs. I will stick with the lincoln locker.
Quaifes don't have clutch packs, which is most of why they suck.
They're better than a bevel open diff, at least, but they're still open diffs.
Edited 1 time(s). Last edit at 08/03/2011 11:55AM by Pete.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
August 03, 2011 12:31PM
Torsen diffs do provide much better forward bite than an open diff, but it kills your predictability.
August 03, 2011 01:15PM
A1337STI
Tell that to Kevin Hawkinson
here in my flat driveway, 4 inches snow on hard base, 4 studded tires= did't go no stinking forward bit at all. Stuck.
All you need to do to lose all power down the ground on one side is unweight it vigourously, or plant the wheel in inside line slime..
spin
loss of forward drive
understeer,
death in a fiery wreck
A senseless waste of human life.
A1337STI
Alex Rademacher
August 03, 2011 02:04PM
Well at times you need to ride your brakes lightly, if you have 1 tire in the air, or on wet ice.
I know I tested mine with 1 tire in the air, engage first and the tire just spun, i even was able to hop out and look at it. got back in, gently touched the brakes and i drove forward (with a front tire in the air!!!)
but you can definitely get stuck in a situation that a spool or clutch type LSD would pull you out of. i found one uphill i could almost climb but i would start to spin 1 tire, riding the brakes a bit caused both to spin, but then i was dragging the rear tires. i could Almost go up the hill but not quite. I'm fairly sure a spool would have had no problem in that same situation.
I've only driven 1 fwd with a torsen , but lots with an open front.
August 03, 2011 05:09PM
I haven't driven a clutch pack FWD, but I'd rate Torsen at maybe a 3 on a scale of 1 to 10 where 1 is an open diff and 10 is welded.
So, better, but it could be a LOT better.
August 03, 2011 08:52PM
A decent Salisbury or ZF or Gripper or Kazz or any of those type in a fwd car set with maybe 90-125 ft/lbs breakaway (depending on PS or manual steering) on your scale would be a 13-15......assuming decent alignment, matched inflation side to side.
It is simply cooler than sheeeeeut.
On tighter corners after high speed the ONE advantage that a clutch plate diff equipped FWD car has over a RWD is the ability to pitch the car stooooooopid sideways into a corner---before the corner and get WAY squared with drastically less chance of a loop out. The reason is way sideways those rear tires present a LONG side to direction of travel and they ARE SLOWING down the rear----meanwhile in Sweden*
<object width="425" height="349"><param name="movie" value="
?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always">
Excuse me, wrong vid...meanwhile the fronts can be pointed where you want to go and you can romp on the gas
Not too often we have that kind of corner but man it works good even if you're clumsy where in rwd car once the ass end is maybe 45* or more out
sloppy stomping on gas will make the rear accelerate faster than the front..
If you're lucky you loop out in the middle of the road.
If you're not lucky.....
*Finnish documentary---100% true.
SeanP
Sean Lane
2000 Dodge Neon G2, bruised
August 03, 2011 11:33PM
I have to throw out the WTF Flag with a 10 yard penalty on that video.
A1337STI
Alex Rademacher
August 04, 2011 01:31PM
Only 10 yards? hehehe
August 04, 2011 01:39PM
SeanP
Ask any Finn. That is 100% true to life...
August 04, 2011 02:42PM
explains why swedish girls might strive to become models instead of housewives.
