Revamping the Rx7
Posted by Gravity Fed
Re: Revamping the Rx7
April 29, 2012 12:36PM
Why not put the quickener under the dash?
April 29, 2012 12:42PM
You mean use those mounts in the quickener for mounting?
April 29, 2012 12:44PM
well the quickener isnt mounted yet and will be just trying to figure out clearances.
also, mounting under the dash would require either buying more things i dont have like aftermarket steering things, or trying to cut up the column.
April 29, 2012 01:03PM
What kinda quickener is that? Looks like it fits there nice.
I drove a newer BMW the other week and fell in love with the steering. 1.8 turns lock to lock from the factory. Too bad it's wrapped around a big fat pig of a car (650i).
April 29, 2012 10:21PM
pass side engine mount! and a pic of what im dealing with regarding the strut tops
April 29, 2012 10:57PM
with the caveat that I don't know much up front...
if you were re-using some of the existing holes for the subaru mounts, wouldn't it be better to use the rear two and gain a little bit of caster?
April 29, 2012 11:09PM
would that be the best location?
April 30, 2012 08:59AM
I was going to say the same thing.
April 30, 2012 11:14AM
Is there adjustability for camber or caster down at the bottom?
If not, remove springs from struts and make top mount be in a nice location for desired camber and caster. Nothing worse than making something and having it make for shit handling.
April 30, 2012 02:05PM
i dont think i follow on the removing springs to optimize the alignment.
also, the engine mount cup is 1/8 steel plate. I plate to reenforce from the bottom once the engine is pulled. Does that seem sturdy enough? Its seems like it but i am only a mere mortal.
April 30, 2012 02:41PM
John,
After some searching i cant find your images of the transmission mount ideas.
April 30, 2012 03:01PM
i am considering using an aluminum weld in bung in -8an for the oil return.
April 30, 2012 03:22PM
If you remove the spring you can compress the strut through its range of motion. Give you a visual representation of what the wheel does through the range of suspension travel.
I think your factory strut mount actually allows a bit of adjustability by rotating the uppper mount through the 4 bolt holes.
April 30, 2012 04:25PM
you are correct on the stock adjustment, although without the rx7 mount that wont happen in the first place.
how wrong would it be to have a 2mm spacer made?
April 30, 2012 11:03PM
driver's side mount is mocked up! Perfect clearance with the steering quickener. Tomorrow ill get the metal to mount the quickener and finish the steering! Then i just need to do the trans mount, then i can pull the engine and finish weld.
