actually its Flying Miata, a aftermarket company!
But yea that diagram is about what were talking about. I would suggest a separate Rx7 thread just so we can work out all the details! First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
MeCalledEvan Evan Horner Mega Moderator Location: Columbus OH Join Date: 01/03/2012 Age: Settling Down Posts: 109 Rally Car: 1983 Mazda RX7 GSL |
O rly? I'll have to look them up!
![]() Thread started: http://www.rallyanarchy.com/phorum/read.php?5,60038 "The more I learn, the more I realize I don't know and have so much more to learn." - Claude Rouelle, Optimum G lecture June, 2011 |
If you want to put the shocks/springs right on top of the axle, you're going to have to cut through the lateral member in the "trunk" floor - it's what the stock springs attach to. If you're willing to stick the shocks behind the axle, you can just open up the existing shock towers large enough to fit springs inside. I did one car where we put boxes in there for coilovers, and it could have worked very well, but due to various reasons it ended up sucking bad. Really, though, working as-is you can use 5" circle track springs in the back and the rear shocks are pretty simple. IMO. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 01/12/2012 02:40PM by Pete. |
i think i know what i want to do for a rear axle. The toyota 8" for 80-95 2wd pickups is 56" wide (compared to mazdas 54"
![]() I dont think i will bother with narrowing it by 2" I just need to figure out what rotor and caliper i plan on using and have a bracket made up. First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
Aaron Luptak Aaron Luptak Mega Moderator Location: SLC Join Date: 02/15/2008 Age: Midlife Crisis Posts: 776 Rally Car: Civic... |
a) is that the same toyota axle that JVL pitches for the volvos etc? b) are you planning to try and do this before idaho? ![]() ![]() http://www.utahrallygroup.com |
step 1. Make this stuff combine into one. I also have to buy a flywheel and clutch....
![]() ![]() ![]() First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
Yeah, same one.... seems that is becoming the default choice. Makes sense. Now to get the 240 Volvo to be the default choice of car. Its the Next Big Thing that will save US Rally---by having a field full of strong and simple cars with limitless potential--affordably. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
i have never driven a volvo honestly. Back in ohio they dont exist anymore, not even at the junkyards. If you do see one, its pure rot.
Oh come on Alex, I see Volvos all the time!
Why, amongst my regular customers are a S60T, an S80 (transverse inline six!), not one but two S40s, and a VC70! And my Mom has a V70. That VC70 is nice. But it looks like I can get an Allroad 2.7t for less, and the Allroad can be had with a manual transmission... Audis are evil but they're the devil I know, you know? Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 02/07/2012 07:49AM by Pete. |
i believe i have decided on the Megasquirt III. There are a few features over the MSII that would just be nice, like onboard data logging (already have a 32GB SD card) and a USB port (FINALLY). That and has anti-lag settings.
.... well, I finally mapped it out, and it's not as shit-ton as I previously thought. Depending on ride height, and after making some assumptions about the car's CG height, it's looking at right around 50-60%. (The IC/tire slope meets the front axle centerline about 13" above ground) Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
How can it take that long to change the turbo? All you have to do is drop the drivetrain out the bottom and then it's right there. Probably 12 hours max.
