Re: Revamping the Rx7
February 12, 2012 09:26PM
I would not own an Audi allroad period. What an overly complex pile of crap that car is.
Have you ever changed a turbo? I have. 26 hours. Screw that.
Only a coupla hours longer than doing a clutch in an Toiletta All-Trac Sillycar.
At least it'll be cooled down by time you get to it.
Gawddam Cossies are so easy that you need nuke-you-lar powerplant gloves and then good rally mechs could change them in about 11 minutes from switch off to start up...
That can't be good using gloves and all...drinking smiley
Edited 1 time(s). Last edit at 02/14/2012 11:08AM by john vanlandingham.
February 14, 2012 04:52AM
acquired a stock 1.8 flywheel for 25 bucks. the 1.6 and 1.8 essentially interchange as long as the matching clutch and pressure plate is used. The 1.8 is slightly larger in diameter however.
March 11, 2012 03:07PM
John! I'm itching for some pictures of the green splendorous boingers!
also aquired the Flying miata clutch kit, and some various seals i felt like replacing for assurance. Also ordered the CNC brake handbrake, (the one with replacement master).
April 20, 2012 01:10PM
Progress! Had to order the clevis for the handbrake, but that came in yesterday. Also had to order the rear main seal and oil pan gasket which came in today as well. So ideally tonight, i should have the engine suspended in the engine bay, ready to make the mounts.
I had to have a friend make a sleeve for the steering quickener adapters. Essentially, the column portion I am splicing into is .7" and the adapter ID is .75" so in the interest of having a good fit, i needed a spacer to center it before welding.
I also do not like how the oil return was run so that will be replaced as well.
April 21, 2012 12:31AM
So tonight i replace the rear main seal, finished cleaning the oil pan, attached the flying miata clutch kit and the 1.8 flywheel and positioned the engine for the engine mounts. With that, bring the non-rotary disdain.
Tinkering with the level and spacing for about an hour before i got it perfect. I will have to pull the oil pan (i didnt make the gasket for a reason) to tap for the oil return. the way it was done by the previous miata engine owner was silly, wrapping around the entire engine.
I also assembled the CNC handbrake and mounted that. Welded a front support bracket due to the angle. Ill let the pictures speak for the rest.
bean
Rabin Rutten-James
None
April 21, 2012 12:24PM
Fantastic photos Alex - thanks for taking the time to document your build. Off topic - but what camera are you shooting with?
Car should be awesome when done.
Rabin
Edited 1 time(s). Last edit at 04/21/2012 05:54PM by bean.
April 21, 2012 01:39PM
thanks!
I am using a Canon 5d (older model) with a 50mm 1.8 lens. The "nifty fifty". About 100 off Amazon. But since the camera is full frame, it comes out very well.
April 23, 2012 10:30PM
Well just posted this on some other RX7 thread, maybe here is better...
On the way:
That top is set up for what is on 90% of Japanese struts: 15mm ID bearing.
Hope your is same!
April 24, 2012 01:03PM
JVL, those look freaking amazing! Can not wait for tomorrow's UPS guy.
April 24, 2012 04:50PM
Want full report. Those'd look nice on mine.
April 26, 2012 01:41PM
so as it turns out, rx7s do not have a 15mm strut bearing. So i am enacting plan B which consists of me using subaru strut mounts and adapting the chassis to suit.
April 26, 2012 02:15PM
OK, good. Is there's some cheesoid flat thing with maybe 25 BBs?
What does it look like?
April 26, 2012 05:49PM
Stock 1st gen is IIRC 17mm.
April 26, 2012 09:39PM
it doesnt look to bad honestly, its just a touch larger. 17mm looks about right. I was gonna about approx 2mm larger than the coilover. should be getting my hands on the mounts tomorrow
April 29, 2012 11:46AM
Subaru tops are on the coilovers. I still need to make a top plate with the subaru pattern for the rx7. I also might have to adjust the ears as a little material hits the hubs.
Also started the engine mounts. Passenger side is coming along nice. Since there are no considerations there. The driver's side however, i am dealing with making the mount and the steering things not occupy the same space.
