aj_johnson A.J. Johnson Elite Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
Clevite Rod bearing CB-1426 P
The circumference of the bearing is way large. but other than length seems to fit just fine Did I get the wrong bearing in the right box? When inserting the bearing into the rod, If I line up one end the other sticks out about an 1/8". Both top and bottom. Google shows it's the right part number, but could they really have screwed up 5 different bearings? What am I doing wrong here? |
Check everything, check here cause formatting sucks:
http://www.aclus.com/content/ACL07%281%29.pdf 9 ENGINE VIN CYL Bore x Stroke TORQUE SETTINGS 2226cc (2.2) (MC) Turbo C L5 81mm x 86.4mm 2226cc (2.2) (MC) Turbo D L5 81mm x 86.4mm 2226cc (2.2) (MC) Turbo E L5 81mm x 86.4mm Connecting Rod 22 ft.lbs/30 Nm + 90 deg. Main Bearing 47 ft.lbs/64 Nm Rod 5B1636 Std. .25 .50 .75 1.0 F780 10 1636 IH rod journal OD 45.949/1.8090 45.969/1.8098 ROD ID 49.000/1.9291 49.017/1.9298 1.506/0.0593 .019/.0007 .082/.0032 19.00/0.748 length Main 6M1604 1-6 Std. .25 .50 .75 F780 12 1604 U/L 57.958/2.2818 57.978/2.2826 63.000/2.4803 63.019/2.4811 2.502/0.0985 .022/.0009 .087/.0034 18.50/0.728 Thrust 2T1644 Std. F817 4 1644T U/L 59.500/2.3425 (ID) 73.200/2.8819 (OD) 1.98/0.078 Note : Set includes four pieces. Required with 5M1604 main set Do you have the right rods? Look at this other thing: Rod PN 5B1606A Std. .25 .50 .75 1.0 F810 10 1606A IH JOURNAL OD 47.758/1.8802 47.778/1.8810 Rod ID 50.600/1.9921 50.619/1.9929 1.405/0.0553 .012/.0005 .077/.0030 19.00/0.748 John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
To answer your questions in order: 1. Very possible, happens daily in the auto business. 2. Yes, see 1 ^^ Misboxed, renumbered, cataloged incorrectly, made wrong etc. 3. Working on an Audi ![]() |
Teeee heee! Oh yeah, SAVE THE BOX. look at the bearing, the rod and the journal, not "on-line", except to refer to ACL or even better---cause it has cross references right on the "block of info" is the Israeli "King Bearings" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
So here is yesterdays lowdown on auto parts....
1985 big block Chevy plug wires, ordered for HEI cap and 90* ends on the plugs for headers. Catalog is wrong, wires came for points dist cap. Summit Racing 2003 Pasat, frt wheel bearing and hub, both wrong. Bearing plain wrong, hub mis-boxed. AutoZone 1983 F-150 radiator and hoses. Wrong lower hose. Auto Plus There was one more but I can't remember what it was tonite....2 man shop, 2 cars downed in service bays overnite, one pushed outside. Any idea how much this costs me yearly in lost production?? It's ridiculous. Happens everywhere. Independant stores, chain stores, dealerships no difference all have massive screw ups. |
Shirley there is a better way.
Well, does anyone have a reccomended bearing supplier. I purchased these a month or two ago and can't find the receipt anywhere. Edit, Perhaps a better question, is John do you reccomend the company above or did the just happen to have a handy dandy size guide. BTW the response from the audi forum: "use OEM bearings" Shoulda guessed that one. Edited 1 time(s). Last edit at 08/03/2011 09:02AM by aj_johnson. |
OK only works with an obscure thing called "Intra-sNet Exploder":
http://www.king-bearings.com/cat/panel/pan29.htm Engine Years CC Bore X Stroke Cyl Models 1900 1980- 1920 cc 79.50X 77.40 5 cyl Audi 80 2000 HP,KP,JS,NM - PS,RT,SL - 1980- 1993 cc 81.00X 77.40 5 cyl Audi 80/90/100 2150 JY,KG - 1983-88 2144 cc 81.00X 83.20 5 cyl Audi 100/200 Turbo 2200 A,H,J series - K,M,P,R series - 1978- 2200 cc 81.00X 86.40 5 cyl Audi 80/90/100/200/4000/5000, Audi RS2/S2/S4/S6 2300 AAR/HX/MC/NF/NG-1986-96 1986-96 2300 cc 82.50X 86.40 5 cyl Audi 80/90/100, Audi 80/90/100, Quatro, Avant King Set No Part No Qty Position Crankshaft Diameter Housing Diameter Bearing Length Max Wall Thickness CR 501AM STD/.25/.5/.75/1.0/1.5 ACL:5B1636 CLE:CB-1017AL(5) FMO:5-68095CP GLA:B5011SA GLY:71-3084/5 K.S:87 455 600 VAN:VPR91947 C 411 5 Pairs ROD JOURNAL 1.8086/ 1.8094 45.938/ 45.959 1.9291/ 1.9297 ROD ID 48.999/ 49.014 0.7480 19.00 0.0593 1.506 CR 502CP STD/.25/.5/.75/1.0 1984- Without oil holes CLE:CB-1178P(5) GLA:B5018LB GLY:71-3566/5 K.S:87 413 600 VAN:VPR92291 C 437 5 Pairs 1.8802/ 1.8810 47.757/ 47.777 1.9921/ 1.9929 rod ID 50.599/ 50.620 0.7480 19.00 0.0554 1.407 CR 505AM STD/.25/.5/.75/1.0 1986- With 1.5mm oil hole. CLE:CB-1162/1426P(5) FMO:5-4465P GLA:B5010LB/B5015LB GLY:71-3694/5 K.S:77 206 600 VAN:VPR92525 C4104 5 Pairs 1.8802/ 1.8810 47.757/ 47.777 1.9921/ 1.9929 50.599/ 50.620 0.7480 19.00 0.0553 1.405 CR 513CP For cracking con. rod GLY:71-3929/5 C4250U C4250L 5 Pairs 1.8802/ 1.8810 47.757/ 47.777 1.9921/ 1.9926 50.599/ 50.612 0.7480 19.00 0.0554 1.407 CR 516CP Under Development For S2/S4/S6/RS2 162/169/232 kW (220/230/315 PS) Upper half -sputter replacement. GLY:71-3732/5 C 516* 5 Pairs 1.8802/ 1.8810 47.757/ 47.777 1.9921/ 1.9926 50.599/ 50.612 0.7480 19.00 0.0549 1.394 MB 601AM STD/.25/.5/.75/1.0 With flange bearing. Flange length: STD - 24.94mm 0.25,0.5,0.75,1.0 - 25.04mm (Fl oversize 0.1mm) ACL:6M1605 CLE:MS-1434AL FMO:6656M GLA:M6046SA GLY:H 941/6 K.S:87 461 600 OEM:035.198.451 VAN:VPM91929 M 601U M 601L F 601U F 601L 5 Pairs 1 Pair 1-2-4-5-6 3 2.2818/ 2.2826 57.958/ 57.978 2.2818/ 2.2826 57.958/ 57.978 2.4803/ 2.4810 63.000/ 63.017 2.4803/ 2.4810 63.000/ 63.017 0.7283 18.50 0.9815 24.93 0.0985 2.502 0.0985 2.502 MB 605AM STD/.25/.5/.75/1.0 Without flange bearing. CLE:MS-1489P GLA:M6056LB GLY:H 981/6 K.S:87 454 600 VAN:VPM92292 M 601U M 601L 6 Pairs 1-6 2.2818/ 2.2826 57.958/ 57.978 2.4803/ 2.4810 63.000/ 63.017 0.7283 18.50 0.0985 2.502 TW2009AM STD/.25/.5/.75/1.0 FMO:68156BF GLY:A 124/4 K.S:78 639 600 VAN:VPW95170 W2009D W2009E 2 Pairs 0.0000/ 2.5000 0.000/ 63.500 0.0000/ 3.0394 0.000/ 77.201 0.0000 0.00 0.0780 1.981 There's the Clevite numbers, and all the info..... hope this helps. I'd figure what rod journal size, double check the rods are what thety're spossed to be, find the Clevite number then Google "Shopping" search it. You also have the Glacier and Glyco numbers and can look on the old rod bearing which of course you didn't dare throw away. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 08/04/2011 03:55PM by john vanlandingham. |
HMMM after further inspection, I have an engine with the code 054 103 021
Not the traditional 034 engine code. Serves me right for not looking. After googleing for a bit, I could only find one other instance of this code and the response the poster got was it's incorrect. HMMMMM what to do. I've found appropriate bearings - order them and run em? |
WHAT DOES IT ALL MEAN!!!!??? help us help you and answer the questions: you have the old bearings? Journal diam? Rod ID? (i know i already asked)(go along) bore? stroke? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
81 bore 86.4 stroke
Crank diam ~45.39 rod diam ~48.98 old bearing 1.49 thick roughly 49 in diam These are shit calipers btw I wouldn't count on the measurements for anything other than rough guesses Diesel fitter- CR 501AM STD/.25/.5/.75/1.0/1.5 ACL:5B1636 CLE:CB-1017AL(5) FMO:5-68095CP GLA:B5011SA GLY:71-3084/5 K.S:87 455 600 VAN:VPR91947 C 411 5 Pairs ROD JOURNAL 1.8086/ 1.8094 45.938/ 45.959 1.9291/ 1.9297 ROD ID 48.999/ 49.014 0.7480 19.00 0.0593 1.506 Edited 2 time(s). Last edit at 08/04/2011 11:50PM by aj_johnson. |
Sounds like:
1981 AUDI 5000 TURBO 2.2L 2144cc L5 FI Turbo (C) [WK] SOHC : Engine : Connecting Rod Bearing Wiki Price CLEVITE / PERFECT CIRCLE Part # CB1017P More Information About this Part TriMetalâ„¢; Steel Backed Bearings With An Intermediate Layer of Copper-Lead Alloy and An Electro-Plated Lead-Base Overlay Material: TM-77 Part Image Choose Size: $7.78 each Add to RockAuto John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
vbares Vittorio Bares Senior Moderator Location: Londonderry, NH Join Date: 04/10/2007 Age: Ancient Posts: 413 Rally Car: Audi 4k (3b conversion) |
I checked ETKA - and your part number doesn't show up. The MC engines should be in the 034 100 family of part numbers.
On the AAN motor the bearings were flush with connecting rod mating surfaces. You can also try EFI Express (are you east or west coast?) - but Rock Auto ought to do the trick just fine... I've got the following part numbers for connecting rods on the MC1: 056 105 701 056 105 707 (0.25 u.s.) 056 105 713 (0.5 u.s.) 056 105 719 (0.75 u.s.) |
