Re: Toe settings for FWD rally?
August 30, 2011 06:25PM
Only slow drivers (or fast drivers driving slow) need toe out to get FWD cars to turn in.
The faster you drive FWD the better it handles. Nat T Stow and I discussed this at length once after a day where he and I had an epic battle for fastest 2wd driver.
As we kept upping the speed we found the cars got easier to drive when we tried harder, we pushed very hard as we were so close.
Edited 1 time(s). Last edit at 08/30/2011 11:04PM by derek.
September 06, 2011 04:03PM
This info is from the Citroen Racing C2R2Max setup book.
Good Gravel: Toe 0mm front / 5mm IN total rear Camber 1°40' front / 1°30' rear
Bad Gravel: Toe 0mm front / 5mm IN total rear Camber 1°40' front / 1°30' rear
Tarmac Smooth: Toe 0mm front / 5mm IN total rear - Camber 2°50' front / 1°50' rear
September 06, 2011 04:23PM
I'll bet they know even less than those cavemen at Ford...
September 06, 2011 07:49PM
Savages all!
September 07, 2011 07:33AM
This is just to confirm that monkey see monkey do, doesnt really always work. So copying what the old Ford papers say might work for some cars but it might be totally wrong for others. Chassis change and tires even more. On these same setup sheets, in one of the setups had different settings for the Michelin and Pirelli tires.
I was actually surprised at how much toe in the C2's require. But I'm sure they found out that to be the fastest and most stable setup.
wildert
Brian Klausen
VW Golf GTi 16V
September 07, 2011 07:58AM
A C2 is about 2 inches long - so adding stability must be top priority smiling smiley.
I run a tad toe in on my Golf Mk 2 as well - it has ended up with toe out on occasion after smacking into odd things - and while it rotates very well, it is also well scary at higher speeds (70ish mph and above). And as Derek says, it rotates just fine with toe in as long as it's DRIVEN.
It didn't previously - but removing the lame front ARB, after fitting the Quaife ATB diff, has proved it to be more than willing to rotate.
Conclusion: you need to go fast to make the car rotate (and to win) - to want to go fast you want stability - to get stability you want toe in. So in the in end: to make the car rotate (and win) you need toe in...
(maybe slightly simplistic, but never the less... I know I'm much faster with toe in than out...)
Brgrds
Brian
Edited 1 time(s). Last edit at 09/07/2011 08:02AM by wildert.
September 07, 2011 09:41AM
wildert
Tack, drengen...
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
September 07, 2011 12:56PM
I noticed when i first started rallying, i needed help getting the car to rotate. Now i just want it more stable.
I think if you want to develop yourself as a driver, its great to get experience with different setups. drive one rally with your car setup to over steer (hopefully one with out very very high speeds) , and one setup to under steer . both experiences can improve you as a driver. focus on driving what you have, to the best of your ability, rather than tuning the car to fit your style of driving.
I tried seed 9 with a rear sway bar last year. car was very loose, and it was slowing me down. driving through the corners if i hit a bump the car would start to drift, but i couldn't really predict it so i ended up driving tidy and under the limit for sure. i disconnected the rear sway bar at the mid server and the car tightened up a lot, enough to have steady state under steer, the result? i ended up driving a lot more sideways through the corners, because the car became predictable and easier to handle (for me) smiling smiley
September 07, 2011 01:14PM
A1337STI
Through all four corners?
A1337STI
Alex Rademacher
September 07, 2011 01:24PM
I think the roads have changed since you drove it last. the stages now have 6, and 8 corners respectively ... :p
September 07, 2011 04:33PM
I never even drove it. I looked at stage maps and withdrew. smiling smiley
BobOfTheFuture
Rob
None, anymore.
September 08, 2011 02:25AM
SeanP
I am gettiing some alignment done before the next event. Car is FWD Neon with a welded diff. I am planning on running zero toe in the rear and a bit of toe-out (.25"-.30"winking smiley in the front. My theory is that a little toe-out will reduce understeer.
Anybody see anything wrong with this?
Just as a quick note-
Toe out= quicker turn in, then earlier tendancy to 'break away' and understeer
Toe in= More sluggish turn in, but less tendancy to understeer and more warning before 'break away' understeer.
a nice turn in feeling is not equal to grip up front
This is from my old Autocross notes, for a FWD car (focus SVT) on the pavement at Nassau coliseum that is nasty, sandy, torn up w/ large cracks. As close to offroad as Autocross gets probably. So take it with a grain of salt...
Edited 1 time(s). Last edit at 09/08/2011 02:27AM by BobOfTheFuture.
wildert
Brian Klausen
VW Golf GTi 16V
September 08, 2011 02:35AM
BobOfTheFuture
Oh how true and what an excellent point!
And then add the "oh-crap-it's-all-over-the-place"-feeling you get with toe out at higher speeds, and you got a recipe for something that wont be all that quick.
Brgrds
Brian
BobOfTheFuture
Rob
None, anymore.
September 08, 2011 05:55AM
wildert
Yeah, on the highway, hitting some crowned pavement... eye popping smiley
wildert
Brian Klausen
VW Golf GTi 16V
September 08, 2011 06:38AM
BobOfTheFuture
wildert
You don't even - in my experience - need that. Add a bit of power to the car (I have around 170 hp), semi-slicks (Yokohama A048's) and poly or nylon bushes all around - and you feel just about ANYTHING the car does. In my case it was plain scary going through a high speed corner at may around 60-70 mph, and accelerating - and then just letting go of the throttle. Car just felt like it wanted to point in a COMPLETELY opposite direction.... NOT funny in my experience...
Brgrds
Brian
