puckhead
Ken Lewis
96 coupe 2.5 swaped and stripped waiting for a cage
cp pistons for a subaru
August 24, 2011 12:43PM
so since I have my car torn 10 ways from sunday I was kicking around the idea of putting some forged pistons in it I could afford cossie stuff but I would have to save up so I was looking at je pistons and it came up cp makes em too anyone have problems with the cp ones? what should I do?
Re: cp pistons for a subaru
August 24, 2011 12:57PM
puckhead
I'm a CP Dealer and have built all kinds of turbo motors including Regionally winning Subie motor for Dave Hintz....
I would suggest a serious re-think about the design of the dish in the pistons.
I have seen piccies of WRC Subie stuff and it looked as i would expect; a nice quench band around the outer rim with a nice radiused dish.
Not so the production junk---and 99% of the "shelf-stock" aftermarket stuff...
I'd think hard. Mitigating detonation is the big priority so we can either a) be smrat or b) run moar bewst.
August 24, 2011 12:58PM
I presume you are thinking of replacing those rather flexible rods in there with something better?
August 24, 2011 01:09PM
I'd definately be tossing some Forged pistons into it...cheap insurance.
but give us more details...
useage? Goals?
what block? what heads? etc.
August 24, 2011 01:26PM
John a lot of the new forged pistons are made that way,
with the quench band, my stock sti pistons are aswell.
puckhead
Ken Lewis
August 24, 2011 06:10PM
thats where it gets interesting I have a block that came from a 06 wrx limited with a set of bugeye heads I kinda need to try to run a NA setup as I have no coefficents so I was thinking about just ditching the turbo and building a exhaust pipe to bypass it untill I am able to run it I just want to get out and tear up some 2 lane dirt roads
puckhead
Ken Lewis
August 24, 2011 06:22PM
I didnt know there wasd much issue with them I found a set of manleys for 322 plus ship. If I remember right the shop rally car was a stock bottom end and it finished consistantly I may just start building one of the donor blocks I have up and just run this as is for now
August 25, 2011 09:11AM
Tough call.
Ideally to run N/A, you'd want to up the compression to like 11:1 (which are available). Problem comes when you go to turbo, you will be married to race gas or E-85 with that much compression. You'll also need some really good engine management to keep it in check, not to mention a good tuner.
You may well be better off to find an N/A bottom end, and monster it together with some heads, and run that while you need to be N/A. You don't need forged stuff for N/A.
I would definately suggest putting some Forged pistons in your turbo motor when you do that. You can find pistons cheap enough...really doesn't matter if they are Wiseco, CP, JE, Cosworth, Mahle, or Maney they are all better than stock and give you some insurance you won't break ring lands.
Rods....for the price of them, while you are in there I would. The OEM rods are proven ok at your likely power levels, but the aftermarket stuff in an improvement. For $300 it's dumb not too.
August 25, 2011 10:27AM
puckhead
In 2000 I was around various Cosworth shops in UK and some did Subie and Misterbitchy too. Collins, Burtons, Goode, Taylor, Mikeanics etc.
Collins particularly since that where I was staying..
ALL pointed out that it was possible to bend the rods with stock turbo..
So I zero in on the "possible' and say "OK possible---but how common in the real world? and we walk over to the bench and look at 3 opened up motors all with bent rods..
The Manleys are fine, they made in the same factory in Western China as my Soooper Bitchin Volvo rods...same as Scat, and several other name brand.
Sure is a bitch having to screw with this different motor rule....so arbitrary and so proven not to work.
puckhead
Ken Lewis
August 25, 2011 01:05PM
could I just put some 11:1 pistons in the turbo block and then when I step up just change em again to some cp's and manley rods? what are the diffrences in the blocks heads cams ect it will be tuned by harvey
August 25, 2011 01:23PM
puckhead
sure...if you have $$$$ to burn.
August 25, 2011 03:21PM
What are you planning to do with the car?
You can pick up a decent 2.2 for $200-300 complete. If the car was a 1.8 you can run the 2.2 bottom end with the 1.8 intake manifold and not have to change anything.
This thread reminds me of why I hate Subarus. The expense gets insane when you start wanting to be competitive. Mitch Williams is going for the USRC again after winning Idaho. Their Cosworth engine is done after Idaho. They pulled another Cossie engine out of Ty's street car. The other option involved around $7k dollars.
If you're going open, I highly suggest never tallying all the money you've spent. You'll be surprised how quickly it approaches or exceeds $40-50k.
My suggestion would be to look into making a sweet 2.5 NA. Troy's daily (Suba Performance) up until a few weeks ago was a built 2.5 making well over 200 hp. Open Light is the place to be.
August 25, 2011 03:46PM
done all three setups. if you are going 2.2 on a 1.8 car its worth the gain of the 2.2 intake. swap over the 1.8 wiring, switch one plug and get the 2.2 throttle cable.
it will take an "o" out of the sloooow.
18 on top 22 on bottom
puckhead
Ken Lewis
August 25, 2011 05:22PM
I want to do open class but I lack the exp so I need to get something together if even for now so I can get some exp
Yeah, but you can get a 2.2 bottom end for $125 here. Add the intake mani and such and you're at $200+ usually. You also get slightly better gas mileage with the 1.8 manifold, which doesn't matter one bit.
Say, what're you doing with the old interior? Do you have it? Is it nice? Dave's convinced me so I've decided I'm going to replace some interior bits of my Impreza and sell it and buy myself a 325 or 328 for a daily and eventual rally build.
