Should all youse guys switch to column shift?
August 25, 2011 04:44PM
looking at how this guy goes (4th overall on this stage) maybe its worth thinking about:
http://rejsa.nu/forum/viewtopic.php?t=72011
<object width="420" height="345"><param name="movie" value="
?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always">
4th overall! Midnattsolrally 2010 (Midnight sun rally)
I betcha a nickle he has miles of toe out and is LFBing like mad.
Saab 96, världens bästa rallybil!
Re: Should all youse guys switch to column shift?
August 25, 2011 05:17PM
Seems like it'd be kinda annoying to try to drive one handed and rest your other hand on the shifter with that.
Yeah, lots of LFBing for sure in that video.
WTF. The thing just goes up and down? How do you know what gear you're in? Or is it a two speed? But then why would it be so fun to say, three on da tree.
August 25, 2011 05:48PM
It takes a little getting used to, but I admit I kinda dig the column shift on a 96, even though getting the damn thing into reverse was more an exercise in luck than skill. But I can see how nice it can be zooming down the road with the shift so close to the wheel. If it sucked, they wouldn't have been using the $300,000 version of the technology on WRC cars...
August 25, 2011 07:44PM
I learned to drive on a column-shift car. '59 Mercedes-Benz 190D. 3500lbs, maybe 50hp. Talk about having to learn to use momentum.
The column shift had so many links and swivels that it made a Golf's look simple.
Then there was the Rambler American, whose column shift rods had a tendency to intertwine and lock up if you tried to shift too fast. No biggee - just get out, open the hood, and pop them apart again - but it'd be hard to do on a rally stage.
August 25, 2011 08:08PM
The Saab 4 on the tree has 2 high quality u-joints to make the turn to go into the top of the gearbox. With a good u-joint the movement is quicker than sheeeut, even faster with the nice real close ratio gears....
j
Just spread your fingers to make a downshift while braking hard.....
cossunist
Stephane Hanna
what rally car?
August 25, 2011 08:35PM
I'd think the 3-2 and 3-4 shifts would be tricky and possibly get mixed up.
I'd also be inclined to think (if I could be bothered to) that one would use a shorter 'throw' version that didn't risk knuckles being busted on either the dash bar or your knee while shifting.
August 25, 2011 08:59PM
cossunist
Dare you to try it out next time you come over, almost as good as a Miata..
The guy in the piccie has a sloppy u-joint. MOST get sloppy after 40 years.
Funny thing is the shaft the u-joint sits on is 'merikanski 5/8" so decent u-joints are all over the place for cheap.
No more chance of flubbing shifts than any normal shifter--and at least this one is right at the wheel....
But did you boys notice the speed in the vid?
That guy was flying!
And sure seems sideways often enough, no understeering pig like so many faux wheel drivel.
August 25, 2011 09:30PM
My flatfender Willys has a column shift. I also remember using one on an F-150 2wd on the farm i worked at when I was 15.
modernbeat
Jason McDaniel
August 25, 2011 11:13PM
Already did!
And kept it two-stroke.
August 25, 2011 11:58PM
My first car, a 1965 Chevy II was 3spd column shift. You could shift that car lightning fast! Just hold slight pressure under the lever in 1st, and stab the clutch sliding your foot off at the bottom, and wham, it was in second. Good times.....
Gravel Spray
Location: ------------------------------------------------
August 26, 2011 02:18PM
Good driver, good car, DAMN good road!
August 27, 2011 12:18AM
Loves
Fried
Bacon
August 27, 2011 01:12PM
My grandfather's Simca 1300 had a column shifter.
Wasnt too bad at all, still the same H pattern as in all 4spd cars at the time.
1-3
2-4-R
At least column shiftger were better than the POS the Citroens had in the 2VC and Dyane! I remember bustin my knuckles on the freakin amp gauge on a quick 2>3 shift... Quelle merde!
August 27, 2011 03:07PM
1-3
2-4-R
Yeah I borrowed a 2CV once in France---hooooooly sheet figuring out that!!
It was bad, but, in a way, not horrible. Umbrella handle sticking straight horisontal outta the dash.....how appropriate when they did the Clio with sequential in the same place!
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
September 02, 2011 02:05PM
what i want to know is Is deep fried bacon better than pan fried?
I mean uhm. where do we set a set of those roads... thumbs up
